possible water in oil
Old Apr 8, 2007 | 08:51 PM
eK9aT10pSi's Avatar
long story short, cliff notes:
max w/ CAI
-raining real bad; construction in the middle lane, so i switched to the right lane.
-as i drove through the water, felt the water was high, so let off the gas, put the car in netral and let it coast.
-got to a gas station, touched the filter, felt dry but the car felt sluggish to accelerate.
-went home, disconnected teh batt, put in oem intake, hoping that the system would reset [just a thought]; didnt do anything.
-going to do oil change and see what happens, i dont think there is any water but damaging a motor over a jug of syn oil isnt worth the headache.
ideas anyone?
Old Apr 8, 2007 | 08:55 PM
Ankit69's Avatar
how many miles on the car ?
Old Apr 8, 2007 | 09:30 PM
eK9aT10pSi's Avatar
51,xxx miles. its an 04
Old Apr 8, 2007 | 09:38 PM
Ankit69's Avatar
i was gonna say just take it to the dealer but never mind that
Old Apr 8, 2007 | 09:47 PM
eK9aT10pSi's Avatar
im hopin no water comes out when i drain/refill the oil. im hoping nothing happened to the MAF sensor.
Old Apr 8, 2007 | 10:26 PM
lightonthehill's Avatar
The only way I know that water could get in the oil system while you were driving would be if something gave way in the engine. Driving a hot engine into cold water can sometimes cause something like an engine block or cylinder head to crack, allowing fluids to intermingle. Or maybe a gasket gave way.
I hope you find no water in your oil, or oil in your coolant. Either is a bad sign.
Old Apr 9, 2007 | 05:28 AM
4MySwee's Avatar
If your MAF was bad, wouldn't you be 'throwing' a code?
Old Apr 9, 2007 | 06:23 AM
xoomer.com's Avatar
I Donate! Why Don't You?
Correct, Water getting into your oil through CAI, NO way.
If the CAI sucked water (which it didn't, you said filter was dry) you would be done, well done. Let us all know what happens.
Another thought, maybe its some electronics that got floded.
Old Apr 9, 2007 | 12:19 PM
M&M's Avatar
M&M
Like already said, there's no way water mixed with oil through the intake.
Old Apr 9, 2007 | 06:47 PM
eK9aT10pSi's Avatar
i got off work late today so i didnt get a chance to do an oil change.
lightonthehill. good point, i almost forgot about checking the coolant. i will do that as well. ill do that in about a couple of hrs so the car will cool down.
xoomer.com - i was thinking that as well, maybe some water got on something and caused some effect
4myswee - i am not getting any codes.
i disconnected teh battery and going to let the car "reset" and see what happens when i go to work in the monring.
when i checked teh oil before i left and when i got home, it was between the L and H [more towards teh H] so i know i didnt lose any.
wish me luck ...
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
uttadms31
Sep 30, 2015 05:24 AM
