Spark Plugs... WHICH ONES ARE GOOD?
Old Apr 12, 2007 | 08:01 AM
tinuc's Avatar
I need to get new plugs but I don't konw which ones I should buy. Every place you go to tells you something different. Any one have any ideas?
Old Apr 12, 2007 | 08:07 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Ask a Stealership!!!
Old Apr 12, 2007 | 09:59 AM
vir420's Avatar
How many miles you got tinuc??? I think I heard / read somewhere that we should change the plugs every 100K, is that right??
Old Apr 12, 2007 | 11:53 AM
xoomer.com's Avatar
I Donate! Why Don't You?
105K I think.
Ask the dealer because you have to be very specific as far as specs go. I had a jeep and went out and bought 6 BOSCH platinum with 4 of those tips (don't know exact term) and after a while my engine began idling funny. I went to see a mechanic and the minute I told hime I did the tune-up myself he knew whats up. He told me to get some cheap Champion or some other plugs of specific spec which were like 4-5 times cheaper and after changing it the problem went away.
Moral of the story: You can't shave yourself with a rotten tomato!
Old Apr 12, 2007 | 11:59 AM
NmexMAX's Avatar
dot dot dot ...
Ngk
Lfr5a-11
Old Apr 12, 2007 | 04:22 PM
Albert's Avatar
I tend to stick with the OEM NGK.
If the recommended change interval is at 100k miles,
you'll notice a difference by changing the plugs at 90k.
Old Apr 12, 2007 | 04:29 PM
I VIK I's Avatar
Yea, I use bosch in my audi. And I belive like everyone here NGK is good for Nissan. It tends to work out that If you have a german car, then you use german plugs. and the same goes for japanese.
Old Apr 13, 2007 | 05:07 PM
madmik's Avatar
This thread has basic plug info.
www.dodgeforum.com/m_610347/tm.htm
OEM is NGK Platinum PLFR5A-11. Not recommended with nitrous.
NGK Iridium IX LFR5AIX-11 or Denso IKH16 - Ok with nitrous
I use NGK when possible.
Old Apr 15, 2007 | 04:46 PM
DTinVA's Avatar
So, are changing the plugs on our engines a diy job or is it better to go to a mechanic? Don't know how hard the back 3 plugs are to reach to change.
Also, what are good plug wires? Should we change the wires when we change the plugs?
Old Apr 15, 2007 | 06:00 PM
NmexMAX's Avatar
dot dot dot ...
Plug wires
Here's a place to start.
http://forums.maxima.org/showthread....79#post2918979
Old Apr 15, 2007 | 08:17 PM
DTinVA's Avatar
Hey NmexMAX, thanks for the link. That's an awesome writeup! Think I can handle the plug change myself now.
Oh, and I didn't know about the wires. <insert embarrassed icon here>
Old Apr 21, 2007 | 05:12 PM
DTinVA's Avatar
Just an update. Changed the plugs today using the info from the link that NmexMax posted. That link is for VQ35's in 5.5 gen but works for the 6th gen with a couple of minor differences.
On the 6th gen you can't reach the 2 bolts behind the collector with a socket from above because the area where the wiper blades go comes way out over the collector. I used a closed end 10mm wrench and eventually got the bolts out. There is one other bolt to the left of the first two which holds a wire harness. This bolt should come out too -- get to it from the other side of the collector. I also found it easier to remove the unit that the black air box connects to(throttle body, maybe? 4 allen bolts) as it has a bracket which keeps will keep you from removing the collector. There is one other L shaped pipe which bolts to the side of our 6th gen manifolds which does not appear in any of the 5.5 gen photos I've seen. This needs to come off too.
The whole job took about 3 hours.
Old Apr 21, 2007 | 06:29 PM
SR20DEN's Avatar
VQ Wizard
Many BMW shops use ONLY NGK plugs. The bosch name isn't what it used to be and even BMW Motorsport uses NGK plugs instead of Bosch.
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
