Methanol injection on a 6th gen?
My engine gets HOT AS HELL!! after a short drive, i pop my hood and the intake is already freakin hot... Will methanol injection work for a non boosted car? or is there just something wrong with my car? Any other 6th genners have this problem????
Originally Posted by mtrai760
You will lose power. It is normal for it to get hot under the hood, unless your temp gauge starts rising you are fine.
care to explain? i dont know what it is but it seems to be hotter than before... or maybe im going crazy...
These engines were designe to run hot -- and are not fully efficient until the engine reaches normal operating temperature.
Methanol is a nasty product that eats many rubbers and plastics. I would stay away from it.
Originally Posted by Hilbe
Just get the phenolic spacers sold at www.nissanworks.com. Should lower your temps 40 degrees....
Kamski
already have homey....
Originally Posted by Machinist
It's your Headers Phil, they are making the under hood temp higher
Well if we all can decide on a hood with either venting or small scoop, perhaps then the underhood temp will drop. In the mean time, make my cold air box and ur power should be better.
I have headers and even before installing the IM spacer kit from NissanWorks.com (awesome), my engine did not run hotter than normal...
If your temp gauge is running higher then half way, you may want to consider other possibilities as to your over-temp problem...
How will i love power though if it suppose to get cooler?
The temp gauge gets and points to it's 'normal' temp when the coolant temperature is @ or above 160*F, and starts moving after ~210 -215*F. So the coolant temp can be between 160 and 210, and STILL point in the exact same spot.
Methonal/water injection is used to cool down air heated up by forced induction. The point is to cool down the air so you can run more boost (more power) without detonating and destroying the engine. Let's say you were running at 6psi on a turbocharger, and had no problems with detonation. Now you add meth injection, and keep the boost level the same. The car will make less power. There has to be something to make up for the loss of power (boost) and being NA, it will only cause you to lose power, and will not serve to cool the car at all, that is not its purpose. Hope this makes sense.
If it's still unclear, a
could have it sorted out.
thanks for the explanation!
also sometimes while im driving i feel like the heat turns on under the dash. Any1 else get this?
Originally Posted by maX5
LOL Phil, you need a vacation bro.
cmon admir you cant see me!!! and we arent in your stomping grounds any more so you can do anything to me mr moderator...
Check the rear hood seal. If not tight, it could let hot air out and back in the car through the fan intake vent.
Get on a dyno and check if A/F is too lean. Can cause exhaust/cats to run much hotter.
http://forums.maxima.org/showthread.php?t=525075
imported_Nismo_max
Sep 21, 2015 07:24 PM
Max139617
Sep 20, 2015 07:09 PM
