Keyless entry
Old Jun 19, 2007 | 07:49 AM
turbodub's Avatar
Keyless entry
When i bought my car it didnt come with the keyless remote, so i bought one on ebay, and i have the instructions. I follow all the steps and the lights flash the first time, but when i press the buttons nothing happens. What else can i do?
I have been to the dealership 3 times and they never have a tech that can program it.
its starting to **** me off.
Old Jul 7, 2007 | 11:03 AM
MAJ_Jimbo's Avatar
Turbodub:
Not sure of your instructions, but if it's a true Nissan FOB...try these, if not the same:
NISSAN Maxima Key Remote Control Programming
The Central Door locking is controlled by the Multi-Remote Control system which controls the door locking, door super locking and hazard reminder. When the doors are locked and unlocked the unit flashes the hazard lights once for lock and twice for unlock.
A maximum of four remote controls are allowed to be programmed.
Ensure all the doors have been unlocked, either by using a good transponder key or remote control plip key.
1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds.
2. Then turn ignition switch to OFF position. Leave key in ignition switch.
3. After 2 seconds, the system will enter programming mode and will flash the warning lights twice.
4. Press and HOLD the unlock button on the Plip.
5. While pressing the unlock button, press the lock button 3 times.
6. Release the unlock button.
7. The warning lights will flash once to indicate successful programming.
8. Repeat procedure 4 to 7 for up to 4 plip key’s.
9. When completed turn ignition ON, and the warning lights will flash 2 times.
10. Remove key, and check all plip key’s for operation.
NOTE : The programming mode will stop when either the ignition is switch ON, 4 plip keys have been programmed or no input signal either from the switch or plip keys has been received for 120 seconds.
BTW - this came from http://www.programyourkeys.com/Nissa...ogramming.html
Jimbo
ah2002
Mar 9, 2016 01:42 PM
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
Hailstatejig
Sep 2, 2015 06:52 AM
