How can i add an amp to a Bose HU
Old Jun 30, 2007 | 10:42 PM
Kashanova's Avatar
i've been trying to connect my amp to the stock bose HU but the wires aren't doing me justice the remote goes on for a few and goes back off spilt second later, anyone know a site i can use to help me with the wiring
Old Jun 30, 2007 | 11:01 PM
RHMax's Avatar
Newbie just Registered
I got signal from the Bose sub amp under the rear deck. Check in the stickies up top, there's a wiring diagram. link
Old Jul 1, 2007 | 06:25 AM
Kashanova's Avatar
thanks hopefully this works
Old Jul 1, 2007 | 02:02 PM
jsmithsole's Avatar
*moderator*
Hi-Lo convertors will do the trick. Hi/Low adapters are devices that installers use to convert a speaker level stereo to RCA levels so it can be hooked to an external car stereo amplifier. You can cut the speaker wires and hook the hi/lo adapter right up or you can tap onto existing speaker wires without cutting them so the speakers still play while the tap gives you a connection to the hi/lo device for adding something like a subwoofer amp to the existing speakers....
Look here: Part # AOEM-NIS2
http://www.pac-audio.com/oem1kits/ao...or+AOEM-1+kits
Old Jul 1, 2007 | 04:29 PM
campione's Avatar
if i added an extra amp to my stock speakers and oem amp..would the speakers be able to handle it, if i also add the PAC AOEM-NIS2?
wanted to keep everything basically stock except add an extra amp...thanxx
Old Jul 1, 2007 | 05:36 PM
NismoMax80's Avatar
SuPeRmOd
It's in the STICKY "How To/Specs" under audio... imagine that
lots of info in there
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
