Racingline FRONT end links - INSTALLED!!!!
#42
Just read this about front strut bars.
Adding strut tower braces has this effect...
The car is more responsive to suspension adjustment; car feels more solid, ride improves, suspension seems to work better; a stiffer suspension can be tolerated by driver.
Can't wait for the "TAZ" special to arrive. Combined with the new front endlinks it's going to be white knuckle city (and I'm black).
#44
Your forgetting Dues has the SE-R front sway.......his is already more responsive then your without pre-load. Plus the fact that they will react faster does not mean you have too preload them, only that you get even more response.
My advise to all is to install as recieved, then adjust as necc. the more you preload the more you'll tune out oversteer and the more twitchy the car will become.
More pre-load = more fun.
Kamski
#47
#50
I just checked my account on Racingline and my endlinks are IN TRANSIT!!!!!
Sorry for yelling but I am so pumped. I cant wait to give y'all the good word on how great they are once installed.
#52
Nations 1st 6th Gen Turbo
Based on your location I would recommend you keep them the same size because it's that added thickness that transfers energy faster not shortness, Shorter may cause more undue stress on the bolts causing them to sheer on the hard NYC roads.
#54
Get rid off your RSB and sell it to me Joke apart, your RSB is the main reason for your car is very responsive.
#55
From what Chernmax said earlier, I would guess you would need to make them longer. But I'm no expert on the subject, just an interpretation of the comment.
#56
Wow, this thread is full of false information. First and foremost you can't preload the sway bars on a 6th gen Max (you can left to right but that's another topic). When you lengthen or shorten the front/rear endlinks the only thing that happens is the sway bar rotates in the sway bar bushings. What you've effectively changed is the angle of the force acting on the sway bar to what it wasn't intended to be. If your car is lowered you want to lengthen the end links to return the car's sway bar geometry back to as close to OE as possible. The front is easy. If you lower the car 1" then you need to lengthen the end link 1" and so on and so forth. Because of how attachment points differ in the rear it needs to be adjusted ~1/2 of what you lower the car by.
MaximaDrvr
08-19-2015 08:20 PM
laparka66
08-06-2015 09:36 AM
