Help!!! Fog Lights Not Working...
Old Aug 21, 2007 | 09:15 PM
farzin1's Avatar
does anyone have any problems with their fog lights not working? I bought my 04 Maxima from this dude and he said they work, but i have not figured out how they work???? Are they suppose to come on automatically???
Old Aug 21, 2007 | 09:34 PM
!PrjctMax!'s Avatar
if this is what I think it is...
The same switch that you turn your head-lights on; there is another integrated switch for the fog-lights, flick it on!
dan
Old Aug 21, 2007 | 10:21 PM
whitem1ke88's Avatar
Mine were both burnt out when I bought my 04 used..
Old Aug 22, 2007 | 09:47 AM
farzin1's Avatar
so mine might be burnt out too. are they easy to replace?
Old Aug 22, 2007 | 09:53 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Just in case: You can only turn on the fog lights when the head lights are on. The fogs will not work alone...
Divewjason's Avatar
There's another switch by the switch that you use to turn your head lights on.
Old Aug 24, 2007 | 12:13 AM
jsmithsole's Avatar
*moderator*
Pretty easy, check the stickies....(but check the switch first!!)
http://forums.maxima.org/showthread....=1#post3734123
And don't forget to upgrade, might as well if you are replacing them anyways...I went with yellow...
Old Aug 25, 2007 | 05:42 PM
Ritz's Avatar
someone's got to say it and not hint at it... so I will...
just to be safe, you're not talking about the lights at the bottom of the bumper, right? those are cornering lights (comes on when you signal)..
the fog lights are right next to the headlight bulb..
hopefully I typed all that for no reason, but it's been mistaken before, so just clearing it up.
also, check fuses.. I don't know if there's a fuse just for fogs, but if they're both out, that's a little strange, and I'd check there first.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
