Cleaned TB - now idle problems. Please help
Old Oct 11, 2007 | 11:50 PM
betep's Avatar
My car started to stall when I start it and my mechanic suggested to clean throttle body. I did it. Now my idle RPM is 1200 and 0507 code comes up.
I did reset ECU and did 3 learning procedures from here, but my rpms are still the same. when I do last procedure - the rpm go to ~900 and no CEL, but if I shut off and start again - everything is back! I have a 04 6 speed and when I'm in the gear and depress the clutch rpms jump erratically, it wasn't like this before.
Has anyone had the same problem? could I damage TB with carb cleaner?
Old Oct 12, 2007 | 07:15 AM
NmexMAX's Avatar
dot dot dot ...
This sounds so familiar.
http://forums.maxima.org/showthread.php?t=394257
http://forums.maxima.org/showthread....=Throttle+body
Old Oct 12, 2007 | 07:20 AM
SoonerFan's Avatar
Cletus
get a new throttle body
Old Oct 12, 2007 | 08:14 AM
xoomer.com's Avatar
I Donate! Why Don't You?
Thats just sad that this was actually suggested by a mechanic. It sucks man.
Old Oct 12, 2007 | 08:57 AM
Lovemycar's Avatar
would have never put that **** in my car make him pay for it
Old Oct 12, 2007 | 09:06 AM
Glude's Avatar
lol, so true. why its important for people to get outa the 6th gen forum and READ.
Old Oct 12, 2007 | 12:27 PM
NmexMAX's Avatar
dot dot dot ...
Funny thing is, I let the car sit w/ the battery d/c'd for bout 38 hours, and it did fine. Some have seen it not be an issue, some have replaced the TB, some have replaced the ECU, some have let the car sit w/ the battery dc'd like and have had it be fine again.
And I also agree, venture out of the 6th generation forum once in a while. I always find it strange that 98% of the new Generation Maxima threads originate in here. I'd say General Discussion would be a better place
Old Oct 15, 2007 | 04:49 AM
betep's Avatar
I ended up reflashing ECU with a newer software and my rpms are ~800-850.
In the shop where I did it they said that ECU didn't want to learn the codes for some reason.
Old Oct 15, 2007 | 06:03 AM
xoomer.com's Avatar
I'm in Brooklyn too. Can you provide shop/address for future reference?
Old Oct 15, 2007 | 06:27 AM
NmexMAX's Avatar
dot dot dot ...
That value is still above stock specs.
Old Oct 15, 2007 | 07:37 AM
betep's Avatar
Well... That's what my tach shows, he said that his computer shows 725rpm
Old Oct 15, 2007 | 07:39 AM
betep's Avatar
Its called Platinum, located on McDonald Avenue and avenue N. they're moving to I think 101 Avenue M in Jan. It's off McDonald avenue - 1 block away
Old Oct 15, 2007 | 09:24 AM
NmexMAX's Avatar
dot dot dot ...
When fully warmed up.
http://forums.maxima.org/showpost.ph...4&postcount=18
Old Oct 15, 2007 | 01:01 PM
STARR's Avatar
when you need a state inspection with emissions you think you will pass
litch
123
Jan 4, 2024 07:01 PM
fx4five
Oct 1, 2015 04:58 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
