Rear Endlinks - Installation???
Old Oct 27, 2007 | 06:30 AM
philoforlife's Avatar
Check out these two different pictures of the rear endlinks installation. One is from Prjctmax and one is from cyclops (I believe):
In the first one the endlink is mounted on the outside of the swaybar, in the second, its mounted on the inside???
Which is the correct way?
Joshua
Old Oct 27, 2007 | 10:46 AM
TAZ's Avatar
TAZ
Because there are multiple suspension setups there really isn't a wrong way in terms of in or outboard. Just as long as they are put in a straight (vertically as possible).
Old Oct 27, 2007 | 11:41 AM
ramberg's Avatar
GrandPa
This is how it looks on my car.
Old Oct 27, 2007 | 12:20 PM
VigilanteMax's Avatar
I believe one of those is the stock sway bar and the other progress, so there would be a difference.
Old Oct 27, 2007 | 02:19 PM
Both are Progress.
Joshua
Old Oct 28, 2007 | 10:59 AM
cyclopsmd's Avatar
Thanks for the credit, but those aren't my pictures. I have a stillen RSB, and I installed my endlinks inside (to the rear of) the swaybar. That top picture makes me nervous with the endlink being so close to the brake line. Probably won't touch, but I am kind of a freak about brakes....
Old Oct 28, 2007 | 12:35 PM
Mack's Avatar
Isn't the top pic from Chern's ride?
Old Oct 28, 2007 | 07:03 PM
Prjctmax, but Chern did the same thing.
Joshua
Old Oct 28, 2007 | 07:06 PM
I installed today. Not as easy as it would see (for me). Couldn't get the bolts to get the stock endlinks off of the frame, so I had to unbolt the piece that bolts to the frame off to get off the stock sway bar. Then had to burn out the bearing and use vice grips to hold it while I took off the nut. Almost put the new RSB on backwards.
Luckily, after screaming "NOOB" under the car for about an hour, I got it done. Car handles phenomenal. Progress RSB and rear endlinks are certainly the way to go.
Thank you Taz.
Joshua
Old Oct 28, 2007 | 07:30 PM
ramberg's Avatar
GrandPa
Chermax has a Stillen RSB.
Old Oct 29, 2007 | 04:40 AM
cyclopsmd's Avatar
Thank you Taz.
Joshua
hahahahahahahhahahaha - I had the same problem when I put in my RSB for the first time! Those stupid stock endlinks were melted on there, it seemed. I had to use one of those special Bolt-Out sockets to remove the nut, because I stripped it from trying to break the stupid thing loose! I, however, screamed much worse things than NOOB and almost gave myself away (you see, I am married to a woman who thinks all of these upgrades are for 17 year olds, so I have to try to hide all of my mods from her )
Old Oct 29, 2007 | 05:12 AM
Mack's Avatar
I feel your pain brother...
Old Nov 2, 2007 | 12:22 PM
Mack's Avatar
Joshua
Guys, I'm putting on my links now. However I was curious, in this shot it shows the washer going between the rubber element and the swaybar. However I put my washer on the outside of the swaybar (that way the rubber element is between the endlink and the swaybar). Does this matter much? I haven't taken it for a drive yet but that just seemed the most logical to me. Taz, any comments here?
Old Nov 2, 2007 | 12:42 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Both are Progress.
Joshua
My rear sway is STILLEN...
Old Nov 2, 2007 | 12:46 PM
chernmax's Avatar
The racing bushing kit I bought states to install them that way, I also have a washer on the opposite side on the sway bar before the nut. I used stainless 3-1/2 inch grade 8 bolts.
Old Nov 2, 2007 | 12:48 PM
chernmax's Avatar
That bottom picture does not look very vertical for max energy transfer to the sway...
Joshua
Old Nov 2, 2007 | 12:51 PM
Mack's Avatar
Thanks Chern. Just before I came up to read this I actually went looking for some extra washers in order to have them on both sides as well. Thanks man!
Old Nov 2, 2007 | 01:36 PM
Sorry about confusing your sway bars Chern
I agree. I put mine on like the top picture.
Joshua
Old Nov 2, 2007 | 01:39 PM
TAZ's Avatar
TAZ
You do not need to put an extra washer. The reason the ES ones come like that is because they are meant for cars that install like this:
Old Nov 2, 2007 | 02:05 PM
Mack's Avatar
Hmm, ok I couldn't find any extra washers. I put the endlinks on as in the picture of them with the red bushings. It feels as if there should've been an extra set of washers to put between the swaybar (bottom) and the mount (top) as well instead of mounting the nut flush against them. I may pick some up at some point to put on there.
Otherwise these babies are certainly MUCHO higher quality than stock. Fronts next!
Old Nov 2, 2007 | 02:08 PM
TAZ's Avatar
TAZ
the washer supplied is supposed to go with the nut. the bushing mounts to the sway bar directly
Old Nov 2, 2007 | 02:12 PM
Mack's Avatar
Damn, I wish you would have mentioned that an hour ago. So I guess my initial instincts to have the bushing sit softly against the swaybar was correct. Man, I shoulda just went with that. Thanks Taz....
One last question. I'm assuming the bushings will expand and contract a bit. Should I go back in, in a week or two to re-tighten everything?
Old Nov 2, 2007 | 03:45 PM
In reference to the re-tightening, yes you should. I'd give it a full two weeks.
Joshua
Old Nov 2, 2007 | 05:42 PM
Mack's Avatar
Awesome. Thanks Josh.
Old Nov 2, 2007 | 06:25 PM
No problem. If you do go with the TS reflash, PM me the results - I'd love to see how much power you've made.
Joshua
Old Nov 2, 2007 | 08:08 PM
sloonz's Avatar
Taz,
Any reason why Racingline didn't use heim spacers instead of urethane bushings?
Old Nov 2, 2007 | 08:44 PM
Mack's Avatar
Joshua
LOL I think you posted in the wrong thread bro. But I get ya...
Old Nov 3, 2007 | 06:23 AM
TAZ's Avatar
TAZ
Originally Posted by sloonz
Taz,
2 reasons:
-spacers leave the hiem bearing exposed, meaning it'll wear alot faster, especially for northern regions where snow exists.
-the bushing, while adding longevity also add a little extra stiffness to the hiem allowing it to respond even faster.
Old Nov 3, 2007 | 09:34 AM
RHMax's Avatar
Newbie just Registered
I'm geting some clicking noise when I go up an down drive ways. Any tricks to get rid of it?
Old Nov 3, 2007 | 11:17 AM
TAZ's Avatar
TAZ
V1 or V2, washer with bushing or with nut?
Old Nov 3, 2007 | 11:56 AM
RHMax's Avatar
v2, washer w/ nut. Only get the noise when going slow on uneven surface.
Old Nov 3, 2007 | 12:41 PM
When I first initiated the ES upgrade and posted the results, I thought my troubles were over. Either Im taking turns at 90 degrees at 90 MPH or Im just unlucky. Ive got V2s on order and am re doing the whole back with my progress. The washer is not needed on the bar itself Mack as directed.
Old Nov 4, 2007 | 09:28 PM
sloonz's Avatar
2 reasons:
Makes sense...thanks
Old Nov 5, 2007 | 04:38 AM
cyclopsmd's Avatar
I had that same problem when I had the V1 endlinks - I couldn't tighten them down enough. I bet you just don't have it snugged down enough... My noise went away when I upgraded to the v2 endlinks... The bolts I had with the v1 endlinks weren't threaded all the way, so I couldn't get the bushings compressed enough (at least that is my theory). Have you tried tightening them down some?
Old Nov 5, 2007 | 05:59 AM
xoomer.com's Avatar
I Donate! Why Don't You?
I still have this unresolved and am currently on OEM endlinks. Couldn't stand the noise anymore. I had V1 setup and its just laying in the basement. TAZ whats is the fix for this and can you provide support?
Matt93SE
May 24, 2019 02:58 PM
kingw323
20
Oct 21, 2015 08:36 AM
Huttig2009
Sep 25, 2015 03:31 PM
ef9
Aug 27, 2015 07:21 AM
Maxboy23
Aug 20, 2015 09:33 AM
