NOOBIE Dictionary
Old Nov 2, 2007 | 08:18 AM
xoomer.com's Avatar
I Donate! Why Don't You?
NOOBIE Dictionary
If something is missing, just post and I wil update the list.
Last Updated: November 5, 2007
Here we go.
Acronyms & Basic Terminology
    Old Nov 2, 2007 | 12:23 PM
    farzin1's Avatar
    thx for the hard work man. i think everyone would need that.
    Old Nov 2, 2007 | 01:54 PM
    TAZ's Avatar
    TAZ
    FSTB- Front Strut Tower Bar
    MMI- Motor Mount Insert
    had to add my own
    But good post A+
    Old Nov 2, 2007 | 02:06 PM
    NmexMAX's Avatar
    dot dot dot ...
    4AT > 4EAT.
    5AT > 5EAT.
    http://forums.maxima.org/showthread.php?t=382799
    http://forums.maxima.org/showpost.ph...0&postcount=60
    Old Nov 2, 2007 | 02:27 PM
    00SEMAX19's Avatar
    NOS=brand
    N2O=nitrous oxide
    Correct me if I'm wrong
    Old Nov 2, 2007 | 02:36 PM
    Mack's Avatar
    Add NA = Naturally Aspirated
    FYI in some circles NOS also stands for New Old Stock (like in my old corvette parts catalogs). However don't some folks also use NOS when referring to Nitrous Oxide?
    Old Nov 2, 2007 | 02:41 PM
    NmexMAX's Avatar
    dot dot dot ...
    Originally Posted by 00SEMAX19
    NOS=brand
    N2O=nitrous oxide
    Well said.
    Old Nov 2, 2007 | 03:05 PM
    pmohr's Avatar
    No more Maximas...
    Sadly yes, they do. NOS has always meant your meaning for me as well.
    Half of the stuff in that list doesn't apply to us, like 'controlled center differential'.
    Old Nov 3, 2007 | 12:56 AM
    lightonthehill's Avatar
    Here are a few, including some that probably don't belong in the list because they are already known by all.
    MPH - miles per hour
    KPH - kilometers per hour
    PSI - pounds per square inch (tire pressure)
    ET - elapsed time (usually referring to quarter mile time)
    FP -foot pounds (used in torquing wheels)
    HP - horsepower
    CC - cubic centimeter (engine displacement; generally used with smaller engines)
    TC or TCS - traction control system
    EBD - electronic brake force distribution
    SRS - supplemental restraint system (airbags, etc)
    LATCH - lower anchors and tethers for children
    CVT - continuously variable transmission
    TPMS - tire pressure monitoring system
    Cd - Nissan's terminology for Cf (drag coefficient)
    Old Nov 3, 2007 | 04:47 AM
    Patsky's Avatar
    Cd is coefficient of drag, not Cf. Cf is an oversimplification, as drag includes impact and pressure resistance as well as skin friction.
    FI = Forced Induction or Fuel Injection
    RTFM = Read the f'in manual.
    Old Nov 3, 2007 | 04:50 AM
    Patsky's Avatar
    EGR = Exhaust gas recirculation.
    PCV = Positive crankcase ventilation.
    Old Nov 3, 2007 | 08:54 AM
    DeusExMaxima's Avatar
    SS= stainless steel, as in brake lines
    Xoomer: are you going to edit your first post by adding all the suggestions so there is one comprehensive list?
    Old Nov 3, 2007 | 09:56 PM
    xoomer.com's Avatar
    yessir, all up to here has been added
    Old Nov 3, 2007 | 10:20 PM
    xoomer.com's Avatar
    Don't hate, PARTICIPATE!
    Old Nov 3, 2007 | 10:42 PM
    Mods: Make this a sticky
    Xoomer: Add R&R= remove and replace
    Old Nov 3, 2007 | 11:22 PM
    scooby68's Avatar
    More awackronyms to add.....
    IACV Intake air control valve
    CTS Coolant Temp sensor
    ?CPS Crankshaft Postion Sensor
    CRPS ??
    EGR Exhaust Gas Recirc
    FIC Fast Idle Cam
    FPR Fuel Pressure Regualtor
    POS Piece of ****
    TB Throttle body
    Old Nov 4, 2007 | 09:27 AM
    FSM
    I dont know what it means but it has something to do with piggy back computers. Check the UTEC thread on here.
    Old Nov 4, 2007 | 11:27 AM
    4MySwee's Avatar
    Fsm=Factory service manual.
    Old Nov 4, 2007 | 12:32 PM
    OOOh, ok, thanks Swee!!!
    Old Nov 4, 2007 | 01:15 PM
    mowgli29's Avatar
    Horizontally opposed.
    Thought that was "idle air control valve"
    EDIT: also add, IAT=intake air temp sensor
    and what about 00VI = 2000 variable intake and MEVI = middle eastern variable intake
    Old Nov 4, 2007 | 04:31 PM
    xoomer.com's Avatar
    can someone confirm?
    Old Nov 4, 2007 | 07:33 PM
    4MySwee's Avatar
    You bet Deus.
    Old Nov 4, 2007 | 09:01 PM
    It is Idle Air Control Valve = IACV. I had to mess with one on my Celica when I cleaned my throttle plate.
    Old Nov 5, 2007 | 10:23 AM
    NmexMAX's Avatar
    dot dot dot ...
    6th gens do not have an IACV.
    irish44j
    23
    Aug 2, 2005 05:10 PM
