Official UTEC thread for 6th gens
It doesn't work "with" the UTEC, I use cipher exclusively for datalogging. I only use the UTEC/UTI when monitoring knock because cipher lacks that function.
Also, your timing readings from the ECU will be incorrect when running a UTEC. The ECU will read really low because the UTEC is taking control and the ECU doesn't know what's going on.
No, when you are running the hard timing with the UTEC, ie 29 BTDC @ 6500, then ECU is no longer controlling the timing and will throw you a reading of 18 BTDC or something like that. Basically the UTEC adjusts timing after the signal leaves the ECU so the ECU has no idea what the timing actually is at that point.
Clarified enough?
Clarified enough?
MAXSE5SPD
Sep 17, 2022 04:00 AM
