Fluid change in an 04 SE 6MT. Has anyone done it??
Old Dec 5, 2007 | 10:54 AM
BlackSpeed's Avatar
According to the mileage and out of pure preventive maintenance, I would like to change my MT fluid. Has anyone done it on the 6th gen MT and if so, what fluid should I use????
Thanks in Advance
Old Dec 5, 2007 | 04:56 PM
Patsky's Avatar
I used The Amsoil 75W-90 synthetic fluid. Pretty darn good stuff, even goes into gear easier when cold than it used to.
Old Dec 5, 2007 | 05:19 PM
DeusExMaxima's Avatar
I used Valvoline Synthetic 75-90 and it works nicely too. It also goes into gear easier when surviving our freezing Southern California weather when it drops into the high 30's.
Old Dec 5, 2007 | 05:37 PM
BlackSpeed's Avatar
Is this a job that I can pull off in my garage?
Old Dec 5, 2007 | 05:41 PM
kamski's Avatar
.org extraordinaire
Bro your a superhero. Come visit me here in Canada for some skiing, we'll go and i'll show you -30C weather
Make sure that your valvoline stuff isnt GL5, otherwise it will chew the bronze metals in your tranny.
Kamski
Old Dec 5, 2007 | 05:42 PM
eK9aT10pSi's Avatar
yes you can, about a 30 min job. i use redline mt-90 gl-4 ftw!
Old Dec 5, 2007 | 05:54 PM
Kamski
I'd love to.
Old Dec 5, 2007 | 07:12 PM
BlackSpeed's Avatar
Thanks to all who contributed. I have decided to go with the Redline MT90 synthetic fluid. Looks like I will get the fluid from Summit Racing which is actually a stones throw from my crib. The service manual is self explanitory regarding the changing of the fluid..
Old Dec 6, 2007 | 02:35 AM
brio_max's Avatar
Learning English...
Has anyone noitced that the FSM says using API GL-4 Viscosity SAE 75W-85 oil is required?
What is the difference between 75W-85 and 75W-90?
Old Dec 6, 2007 | 03:00 PM
marshallc's Avatar
redline mt90
i dont think my trans fluid was changed in the 84k miles that were on it when i got her, so i flushed a bottle of it through before filling
shifts, like, butter, BUTTERRRRRRRRRR
best bang for the buck mod
you will need a torqx bit to take the fill/drain plugs off, and one of those fluid pumps they sell at murrays to make it easier.
Old Dec 7, 2007 | 02:53 AM
Patsky's Avatar
Not a torx bit, but an allen socket is needed... forget which size.
Old Dec 7, 2007 | 04:34 AM
kamski's Avatar
.org extraordinaire
Ideally, you want to mix, MTL and MT-90
il_signorre from the nissanclub.com is a guru in fluids and I went with his recomendation 40/60 mix of MTL/MT90 for the closest match to the nissan spec. Boy let me tell you. ITS PIMP smooth.
You will need 2.5 liters of the stuff..... yeah that means 4 bottles for an ideal mixture.
OR...
U can get amsoil GL4 spec manual gear lube. I had that before the Redline mix. Its also FRIGGIN WHICKED.
Speak to Talkinghorse in our GB sections for a great deal on that stuff.
ALL THE BEST.
Kamski
Old Dec 7, 2007 | 07:25 AM
BlackSpeed's Avatar
I appreciate all the great input and thanks for not TEARING ME A NEW HOLE (for not using the search function) I just saw the stickie under the ALL Motor section.....
Old Dec 7, 2007 | 09:06 AM
jbpadayao's Avatar
How did you do the M/T fluid? I'm reading the service manual and one of the procedure is to remove the "speedometer pinior gear", what is it and where is it located? Thanks for the help
Jeff
Old Dec 7, 2007 | 10:12 AM
BlackSpeed's Avatar
Jeff
No need to remove anything but the drain/fill plugs. Check it http://forums.maxima.org/showthread.php?t=164708
Old Dec 8, 2007 | 12:28 PM
SilverMax_04's Avatar
This site has more than the 6th Gen Forum. This whole thread belongs in the Fluids and Lubes Forum on this site. There is a stickie there for changing manual trannie fluids. Check out the link on that thread that has pictures for changing the fluid in a 6-speed that is the same as our 04 6-speed. I used the pictures and the discussion and did not have any problems. I did buy a funnel with a long neck so that I could pour the fluid in the funnel (located next to the battery) and have it flow into the trannie.
I think you will be fine with either Redline or Amsoil fluid. But be certain that it is rated GL-4 ONLY. You don't want an multiple rated fluid like GL-4 & GL-5.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
iamute
Sep 20, 2015 05:22 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxxx10
Sep 13, 2015 03:16 PM
