Splitter - Final Pics!
Old Dec 30, 2007 | 06:08 PM
  #81
larsim's Avatar
Wink. I'll do the rest.
Originally Posted by DeusExMaxima
Haters who "claim" to be informed minds
Old Dec 30, 2007 | 07:07 PM
  #82
philoforlife's Avatar
Well, let's just take a look at this then.
First of all, let's dispel the myth that the splitter creates downforce. It does not. The purpose of a splitter is to channel the air into two paths, one low pressure (under the car) and one high pressure (over the car). Thus, the car isn't forced towards the ground, its sucked down from below, much like an inverse plane wing (as they use a low pressure area above the wing to provide lift). You are, in essence, providing reverse lift to the vehicle.
Now that we've dispelled the myth of "downforce", lets talk about its functionality.
I do believe splitters are very effective. I don't believe yours is, for a variety of reasons. But before we get into those, let me just say that it LOOKS very good (now that you've done various cosmetic additions to it). However, I doubt it functions well at all. Why? Splitters are usual additions to race cars, very light cars that need to be glued down to the ground. Your Maxima is VERY heavy. A lighter car might benefit, but yours will not.
Now, lets look at the equation Force= Pressure x Area. The more area at the front of the splitter, the more force you'll have pulling the car down. However, your also going to be decreasing the pressure under the car substantially. Let's just assume that you are in fact generating high pressure in the front. Unlike a race car, you have a FWD car. What does that do? It creates a dangerous condition of oversteer. (I don't believe this will happen to you because I don't believe your splitter really functions, but I'll get to that). This is what happens with a functioning splitter in a FWD car:
Originally Posted by guy from E36 boards
Not taking the hint, I continued to drive my car around with the splitter extended for a few weeks until my appointment to have my LTW and wing extensions painted and installed. While driving at some pretty aggressive speeds through a nice sweeper on my way home from a friend's house, I encountered a road hazard of the large live animal variety. I quickly tried to bring my speed down but I was still in the turn. I thought I was ok, I had been in a similar situation on this road at even greater speeds and the car should respond just like normal. The car exhibited some very intense oversteer characteristics, more than any car I had ever driven, and I wound up backwards in a ditch. Not the most nerve calming incident in my life.. heh. Had the ditch been much deeper or the velocity any greater, I can tell you for sure, I might not be here right now.
Since that point, the wing has been on my car, and the splitter is Never fully extended unless the LTW wing extensions are in place.
Notice his splitter was at full extension, bumping up the area, effectively increasing the pressure. This is why FWD cars don't generally use splitters.
Now, for the functionality.
The funny thing about splitters is called "deflection". A front splitter must be EXTREMELY strong to handle the pressure created while driving at high speeds. So strong in fact, that most use plywood or high yield fiberglass. Hence the turnbuckles, which help keep the splitter in place. If the splitter bends, even just a little, it creates deflection, which simply means it destroys the low pressure area under the car and causes it to lose functionality completely.
Lets go back to the equation "Force = Pressure x Area". You need to have a lot of area to give you the force and drop the pressure under the car. You get your force, but at a price - the splitter absorbs the force. Your ABS plastic is nowhere near the strength needed to absorb 200-300lbs of force. I mean, you had to shim it to get the bends out of it. Let me repeat that, you had to shim it to get it straight. Most people are using plywood.
Originally Posted by tentenths.com
Rob, the splitter on kit car which balances out a 100lb of downforce at 100MPH rear wing was originally made out of ply coated in green Cuprinol to match the cars colour. It extended fowarded about 3 inches at the front and an inch round the sides to help stop the displaced air slipping back under the car.
Coupled with a two inch 'step' at the front to form a simple venturi this is producing more downforce than the rear wing and is going to require a venturi at the rear to balance out.
The steering is also now so heavy due to downforce in fast corners that the car can be difficult to steer. Hopefully the forthcoming baby lifting exercise will fix that!
The splitter is now fiberglass and slightly lighter as a result but works the same.
Note that a real working splitter MUST have supports or it either isn't working or it will vibrate, reduce efficiency and break after a while.
I tried a splitter on the Corolla and it wasn't really deep enough to have a massive effect. The 40mm allowed by the regs was too little for a car with such poor underbody aerodynamics.
I am in the sign business and we use a very versatile material called Foamulux, which is similar to the white cladding used in building and is a plastic close cell struture material with a finished outer skin, This stuff can be cut, planed, heat bent and retains its shape and I have sold sheets of it in the past to car prep companies, it comes in 8 x 4 sheets or 10 x 5 feet. I have used it to make up internal door pannels including bending over the top and shaped foot wells, cut to size then apply heat with a heat gun and push into the well, great. It is available in different colours. I don't know where you are but I always have a few scraps lying about you could use. Another great material although not so workable but a lot strionger is 3mm Raynobond which is an ally faced composite material with a resin core, light and strong.
I am not forgetting anything; I asked IS Lexan as stiff as plywood; If a lexan splitter has to be thicker that a plywood one to get the same stiffness then it may end up weighing more than a plywood one. If someone has the stiffness figures for each material we can work it out. We use lexan windows 4mm thick and I believe plywood 5mm thick is stiffer, so a plywood splitter would be stiffer, weight for weight, than lexan.
Ridgidity of the splitter is very important; it generates a lot of downforce but if it becomes deformed under pressure a significant amount of downforce can be lost. I am sure lexan is stronger weight for weight than plywood i.e. it has a higher strength under bending loads and will not break so easily, but I think this is largely because it is a more flexible material and it will be deflected easier than plywood; the laminations make plywood very stiff. Properly layed up carbon would be the stiffest I am sure, weight for weight, I have seen carbon splitters and wing endplates shatter on impact.
I have first hand experience in playing around with splitters. I ran an OW autocross car and after totalling a wing once I decided to build a splitter for an upcoming event.
I used 5mm Meranti mahogany plywood (real cheap) I found in the garage cut to 22 inch and 48 inch wide. My front track was 56 inches so I had to notch out a bit to clear the inside on the tires. The leading edge was 15 inches from the front tires.
I bent a 50thou Al channel 1.5"x1"and epoxied and rivetted it halfway across the span.
For the venturi I bent up a 50thou Al angle to provide an exit height of 1.75inches (I couldn't get the angle to hold more than that).
I mounted the whole thing with .125 Al plate to the nose box.
The thing was NOT fragile.
You know what....it produced more downforce at lower speed than the front wing. Enough that I had to increase the rear wing flap(s) angle....and it looked ugly....
So much so my kids told me to build a new wing !!!!
Total weight was 10.5 pounds. Weight for the wing (Aluminum, foam and FG) 18 pounds. The splitter has a lower CG too...
These people have tested splitters at the track and many are using Lexan. Lexan. It's like low weight concrete. No bends, no shifting, no pulsing. From above you see that this is a science. Much more than just attaching a piece of plastic to the front of the car. I'll admit, it looks much better than it first time around and it did give it an air of aggressiveness. However, it is no where near strong enough to do anything but look nice. (to some).
(I did research this long before this thread when I has an IS300, I don't make claims without proof).
A Not-so-Genuine Hater,
Joshua
Old Dec 30, 2007 | 08:56 PM
  #83
redls1's Avatar
MAXIN' ON
Nice informative post!
Old Dec 30, 2007 | 09:24 PM
  #84
DrunkieTheBear's Avatar
Turbo'd Saab
Joshua
Dude if you so concerned about his car and train of thought, then you must lead a stressful life. Just let it be, it makes him happy and thats how it should be. You may not like it, so here's a novel idea don't do it on your car so we all can go oooooo and aaaaaaaah at it later.
Old Dec 30, 2007 | 09:35 PM
  #85
DeusExMaxima's Avatar
Silly statement. Downforce or reverse lift IS THE SAME THING!!!
No we have NOT dispelled shzit, lol
Also not true. What is the relevance of wieght. Downforce is downforce irrespective of HOW MUCH THE CAR WEIGHS
Now, lets look at the equation Force= Pressure x Area. Yes, lets look at that The more area at the front of the splitter, the more force you'll have pulling the car down. However, your also going to be decreasing the pressure under the car substantially. Let's just assume that you are in fact generating high pressure in the front. Unlike a race car, you have a FWD car. What does that do? It creates a dangerous condition of oversteer.Dangerous????? Nothing dangerous about it if you know how to drive (like I do, hehe) Oversteer is not good for people who dont know how to drive, or are not expecting it. But for performance cars, slight oversteer is GOOD. In fact, if you can dial in oversteer on ur FWD car, "u done good." (I don't believe this will happen to you because I don't believe your splitter really functions, but I'll get to that). This is what happens with a functioning splitter in a FWD car:
I have 3/8" ABS plastic securely bolted WITH Stillen turnbuckles securely bolted.
Lets go back to the equation "Force = Pressure x Area". You need to have a lot of area to give you the force and drop the pressure under the car. HOw much is "a lot" The length of the splitter is over SIX FEET long averaging about 3 inches or more in width which is about 220 square inches. Ur hand is about 18 square inches which means the splitter is about 12 times bigger. U ever stick ur hand out of the window at 60 mph and can barely control it due to the force. Now increase that force 12 TIMES!! You get your force, but at a price - the splitter absorbs the force. Your ABS plastic is nowhere near the strength needed to absorb 200-300lbs of force.3/8" thick with turnbuckles, so not true I mean, you had to shim it to get the bends out of it. Let me repeat that, you had to shim it to get it straight. Yeah, so? I shimmed it cuz I used 5/16" BOLTS to bolt it down so it did bend. What kind of force do u think THOSE BOLTS generated?? LOTS Most people are using plywood.
NOt sure what ur proof is since i dont know who these people are, and where they got their info from specifically. Did they measure it? Did someone else measure it. Im not saying I am right, but I am saying that there is uncertainty as to whether or not they are significantly effective. Like a dyno is to an engine, the only true way to test it is to test it on and off the car, use a high speed wind generator and a scale, right??
Joshua
I still love ya!!
Old Dec 30, 2007 | 09:36 PM
  #86
Ah, another one of these posts. Brilliant.
I won't waste the time responding. Posting on a message board does not lead to a stressful life. More like an exchange of ideas. Here's a novel idea, posting factual information is what this forum needs more than anything else.
Have a swell day,
Joshua
Old Dec 30, 2007 | 09:38 PM
  #87
I still love ya!!
Hahahah I love you too man.
Obviously there are too many variables on too many levels. Who cares anyway? You can obviously autocross, it doesn't really matter what the splitter does.
But just so you know, it doesn't really do anything
Hehe,
Joshua
Old Dec 30, 2007 | 09:41 PM
  #88
Hehe,
Joshua
U may be right. Just like most spoilers dont function either.
Old Dec 30, 2007 | 10:00 PM
  #89
!PrjctMax!'s Avatar
holly **** this place was like a family feud going on! lol
Old Dec 30, 2007 | 10:23 PM
  #90
We had to have some fun...its New Years Eve!!!!!!!!!!!
Old Dec 30, 2007 | 10:46 PM
  #91
Not at all. This is exactly why we have forums - to express opinions in respectful way, as is occurring here.
Old Dec 31, 2007 | 08:24 AM
  #92
bb700092's Avatar
I have always wondered about the function of spoilers in our everyday cars. The 07-08 max has a aerodynamic drag coefficient of .31 without spoiler and .30 with rear spoiler. Now does that .01 make any difference in day to day driving even in highways? At what situation does it really make a difference?
I have seen some spoilers that look like bison's horns or even wierder. Some have multiple spoilers. Some spoilers seem to inhibit performance rather than enhancing it. But I am no spoiler expert.
Old Dec 31, 2007 | 10:26 AM
  #93
I just read an article in Nissan Motorsports magazine last night regarding aerodynamics. Although it was very narrow in terms of testing, sicne they used 3 different 280Z cars, it was more for example. A lot of aerodynamics create significant downforce but at the expense of gas mileage. Like a lot of car products, I do think there are a lot of myths regarding spoilers and the like. Sounds like a show for Mythbusters.
The difference between .31 and .30 is negligible. There are many ways to get better gas mileage other than aerodynamic aids.
Old Dec 31, 2007 | 10:31 AM
  #94
redmaxpa007's Avatar
i SeE what you did therE
Old Dec 31, 2007 | 02:50 PM
  #95
madmik's Avatar
Wow. Excellent work. Looks like a professional job. I think the red turnbuckles match well with the red details of the car.
The splitter may or may not work but it will surely make the other racer nervous. SportCompact has a good article on aerodynamics of cars, dams, splitters, etc:
http://www.sportcompactcarweb.com/te...t_1/index.html
http://www.sportcompactcarweb.com/te...t_2/index.html
Old Dec 31, 2007 | 03:10 PM
  #96
06maxSE's Avatar
More pics:
See spacer in middle:
The rear end of splitter aligns with edge of front part of fender:
looks awesome man question where did you get your grille i have been lookin for a mesh one like that for a while please let me know happy new year
Old Jan 8, 2008 | 02:40 PM
  #97
Mack's Avatar
Deus, saw this while trolling ebay. Thought you might want to take a gander just for S&G's.
CF Splitter
Old Jan 8, 2008 | 02:56 PM
  #98
Class Max's Avatar
PIMPIN
I really like the look but the red stands out a little, would probably look different from farther away. Overall, I like the ride. I see you a left on the red pinstripe on the mirrors. Different and a nice touch.
Old Jan 8, 2008 | 03:00 PM
  #99
Mack: I already checked it out. Its too small for our wide car. My splitter measures 72" wide; the one on ebay is 65". But thanks. I do want CF overlay cuz I like the look. If I get a CF hood and I put a CF overlay on my GTR rear valence that I'm building, I think that will look pretty nice.
Classmax: Thanks!! The red turnbuckles a different than what I have seen out there but they dont stand out too much in person.
Old Jan 8, 2008 | 03:10 PM
  #100
Class Max's Avatar
PIMPIN
Might be a dumb question but is that att. to a factory bumper or..
Old Jan 8, 2008 | 03:21 PM
  #101
04MAX_ILLIN's Avatar
Looks like a factory bumper to me...with a Stillen lip in the front ?? Eh Deus??
Old Jan 8, 2008 | 03:23 PM
  #102
Are u asking if it is attached to factory bumper? If so, it is attached to my Stillen lip which is attached to the factory bumper. I can get a pic from underneath if you like. Let me know.
Old Jan 8, 2008 | 03:32 PM
  #103
Class Max's Avatar
PIMPIN
nah, just curious I have an 07 and noticed the fog lights set back like the older bumper. Thanx though. BTW like the photoshop on the clean car.
Old Jan 13, 2008 | 07:53 PM
  #104
VQPRO's Avatar
I love the finish product looks great
Old Jan 13, 2008 | 10:56 PM
  #105
Thanks guys!!! Appreciate comments, good or bad. I like the good ones better
Old Jul 10, 2008 | 09:46 AM
  #106
Update: As much as I love the look of the splitter, I keep hitting curbs. The ABS plastic does a great job of resisting breakage. The problem is that the turnbuckles resist flexibility and I hit a sharp dip in the road and a chunk of the splitter broke off (a small triangle shape about 2 inches on each side. I fixed it by grafting a piece of the original plastic into the opening of the break and epoxy gluing it, sanding it and painting. It looked ok (better than before). Then I nudged a curb again this morning and it cracked again. Ill glue it again. Its all worth it.
Old Jul 10, 2008 | 10:32 AM
  #107
Mack's Avatar
The best things in life are always a pain and usually worth it. I see the bat mobile is still lookin' good Deus!
Old Jul 16, 2008 | 08:45 AM
  #108
sclev99's Avatar
Looks like you're ready for Nascar with that splitter.
Old Jul 16, 2008 | 08:54 AM
  #109
Thats what someone told me once, lol.
Old Sep 29, 2008 | 02:03 PM
  #110
I decided to paint the turnbuckles black. The red made them stand out but I like the simpler look of the black:
Old Sep 29, 2008 | 02:10 PM
  #111
ajcool2's Avatar
Nice.
Old Sep 29, 2008 | 02:29 PM
  #112
Fastmax05's Avatar
"Ok,Whats next?!?!"
Looks good mark ... always doing something haha
Old Sep 29, 2008 | 02:47 PM
  #113
Yeah well if I get that carbon fiber rear WRX spoiler it would go nicely with a CF hood
Old Sep 29, 2008 | 02:48 PM
  #114
jsmithsole's Avatar
*moderator*
Looks good, more subtle for sure....
Old Sep 29, 2008 | 02:50 PM
  #115
Fastmax05's Avatar
"Ok,Whats next?!?!"
well you know how i feel about getting a CF hood..... obviously i like the idea LOL ..
Old Sep 29, 2008 | 02:58 PM
  #116
What do u think of the idea of a CF spoiler to match - and maybe cf overlay on splitter? Photchop anyone?
Old Sep 29, 2008 | 08:36 PM
  #117
Wantastic's Avatar
i like it
Old Sep 29, 2008 | 09:34 PM
  #118
Black is sooooo much better. Definitely a step in the right direction.
Old Oct 1, 2008 | 01:13 PM
  #119
Wish I could make this in CF. Anyone know where I can get a sheet of CF real cheap?
Old Oct 1, 2008 | 01:22 PM
  #120
Fastmax05's Avatar
"Ok,Whats next?!?!"
hmmm.... u got my attention lol
