Any good grills for the 07 Max
http://www.6thgenmaxima.org/forums/viewtopic.php?t=3919
yeah but I plan to get the chrome 18's of the maxima if i can find them and of course the back of the car has chrome. But I was thinking of going black rims with machined lip and black grill.
I am going to get a grill because the black stock grill looks basic. It seems everyting on Ebay is screwy being tht the grill cost 40 bucks by the shipping is 60 bucks what kinda crap is that?
Its easy enough just wanted to emphasize the prep work. I didnt tape up my install and ended up with a little scratch when tightening the nuts down. Also with a light colored car, mines silver, you should paint behind the grill to hide the color.
Oh,ok I was worried it was going to need professional installation.
07 Custom Grille
Hay! Guys & Gals my custom 07 Grille is finally complete, it just needs some slight wet sanding that should only take 30 mins or less. Then the entire Grille Frame will be paint the same color[bw9] as the vehicle except for the mesh, which will be paint a glossy or flat black. Few pics below with a link of the entire process:
![](http://memimage.cardomain.net/member_images/4/web/2512000-2512999/2512663_308_full.jpg)
![](http://memimage.cardomain.net/member_images/4/web/2512000-2512999/2512663_302_full.jpg)
http://www.6thgenmaxima.org/forums/v...?p=62644#62644
Deus! Thanks for the compliment man the mesh was purchased @ a friends Wheel & Accessories shop here in town. It's a really good grade of Diamond Mesh cut, I almost don't want to paint it but that's the process of this project. Besides if it doesn't look the part I'll just replace it as needed. Plus I notice a thicker grade of mesh @ my friends shop, more "Expensive" but looks really good like the Strut Grilles.
http://www.6thgenmaxima.org/forums/v...er=asc&start=0
Deus! You gotta check out the link below that shows all the materials involved in creating this Custom Fabricated 07 Grille. The 07 O.E.M Grille is actually a 2 piece unit consisting of a hard plastic frame[chrome out-line] an the actually grille [grey portion] that is hard plastic as well.
EK9AT10Psi! It shouldn't be a problem @ all fabricating one of these grilles once again, it's actually pretty easy to design just a bit time consuming. Would only take a few days to build an structure properly. I had several request already which makes me really consider designing some more for the 07 Front End.
![BowDown](https://maxima.org/forums/images/smilies/bowdown.gif)
![Drool1](https://maxima.org/forums/images/smilies/drool1.gif)
That looks unbelievable man.
How about if I send you my '07 grille and you send me that one? I know you like projects
![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
PhotoGus! I'm glad you ask how the Custom Grille fits because it lines up perfect. No rubbing, shifting, or any additional modification needed for proper installation. It lines up exactly how the 07 O.E.M Front Grille would with "No" complication. I actually applied the grille onto the bumper today an the results look better then the photo-shop sketches from earlier. Everything is aligned in original placement just like the O.E.M Grille an tomorrow I'll have a few pics for you guys.
OH! Since the entire grille will be painted Blue(Bw9) except for the mesh I decided to spray one or two layers of Low Glossy Black Paint (Ceramic). Few new pics below:
![](http://memimage.cardomain.net/member_images/4/web/2512000-2512999/2512663_312_full.jpg)
![](http://memimage.cardomain.net/member_images/4/web/2512000-2512999/2512663_311_full.jpg)
![](http://memimage.cardomain.net/member_images/4/web/2512000-2512999/2512663_310_full.jpg)
Custom 07 Grille
Sorry to bring back a slightly faded out post but I wanted to share the final Custom 07 Grill pics before the Piaa Fogs are installed. Around that time I'll just begin a New Thread pertaining to the matter of the Piaa Halo Lights.
Below are just a few pics of the 07 Grille Project almost complete.
I still have to do a simple design for the bottom portion of the Bumper.
![](http://memimage.cardomain.net/member_images/4/web/2512000-2512999/2512663_378_full.jpg)
![](http://memimage.cardomain.net/member_images/4/web/2512000-2512999/2512663_352_full.jpg)
![](http://memimage.cardomain.net/member_images/4/web/2512000-2512999/2512663_354_full.jpg)
![](http://memimage.cardomain.net/member_images/4/web/2512000-2512999/2512663_386_full.jpg)
Also, someone is selling a Bose headunit for my 2007 maxima on ebay. Does anyone know if I can just swap headunits or do I have to make other modifications for the Bose to work? Currently, my car does not have the Bose system.
The 05 Hood & 07 Front Bumper Project was painted and completed.
But, I really wanted the hood extended more which would require sanding
back down to the metal & fiberglass. Extending it from 1 1/2 inches to
a full 3 inches to capture a way better appearance with a slight
aggressive appeal. Now for any of you concerned about the 07
Front bumper fitting properly, Don't be! It matches up 100% along
with the 2004-2006 Hood opening & closing perfect. The minor issue
for some including my-self is that the vertical hood lines @ the
base near the bumper don't line up with the 07 bumper lines.
The measurements are around an inch or two apart.
Below is a link to 6thgenmaxima.org showing all the details on how the
project can be performed in your garage with the proper tools.
Having "Some" Body Shop Skills will help you out tremendously.
Any question feel free to ask!
![](http://memimage.cardomain.net/member_images/4/web/2512000-2512999/2512663_412_full.jpg)
![](http://memimage.cardomain.net/member_images/4/web/2512000-2512999/2512663_415_full.jpg)
![](http://memimage.cardomain.net/member_images/4/web/2512000-2512999/2512663_414_full.jpg)
Viralkill
08-17-2015 10:54 AM
