Second Battery Install, Help
Old Jan 14, 2008 | 12:08 PM
mavssolja's Avatar
ok so i have my entire system installed, 15" eclipse sub and all, and now im thinking of installing a second battery to lessen the drain on my single battery and other electronics in the car. THis will solve the dimming of lights correct? ive read a million differnt things online, and hope this solves it because my 4HIDs arnt liking the contstant power drain. Anywyas I was hopeing someone could layout a diagram or the instructions on installing the second battery. I have a cap right now, is it the same as the cap, just adding an isolator? Do I add more fuses? Where? Any help would be great.
Old Jan 14, 2008 | 12:11 PM
jimmypronet's Avatar
all i can say is go to Maintenance, Tech, & Care section AUDIO and ELECTRONICS ... im preety sure youll get best answer ther......
Old Jan 14, 2008 | 01:40 PM
BigPete's Avatar
Incognito
adding another battery will make things worse, all its going to do is strain your alternator and burn it out. http://www.the12volt.com/installbay/...TID=73496&PN=1
^ the big 3 is your best bet. If that doesnt work get a better alternator.
Old Jan 14, 2008 | 02:29 PM
gen2000's Avatar
You may need a Audio Power Capacitor
Car Audio Power Capacitors
A car audio power capacitor is a secondary, passive (non-powered) storage device for electrical power. Sometimes simply called a power cap, cap or Stiffening Cap™. They typically come in cylindrical shapes that are three inches in diameter and about a foot long though rectangular shapes are also available for different technologies. There will be a positive and negative terminal and possibly a third remote turn on terminal that turns an LCD display on or off. Regardless of the shape or extras they come with they are designed for one thing, to store electrical power.
Why Does a Car Audio Power Capacitor Work?
A car audio power cap works by storing large amounts of electrical power which it can then deliver to power hungry components when called upon to do so. They have an advantage over typical lead acid storage batteries because they have very low internal resistance. This allows them to deliver large amounts of power (current) very quickly. Much faster than a car's charging system can deliver that same amount of current.
Car audio power amplifiers have can have very large current demands. This is dependent on the music being played through the amplifier. Typically these currents are only needed in short bursts during transient peaks (cannon shot, bass drum strike, etc.). If the amplifier tries to pull this current from the electrical system directly it may cause a drop in voltage called a sag. This sag is equivalent to a voltage drop in the system and the size of the drop depends on the resistance of the wire from the source (battery) to the amplifier.
As an example, let's say you have twenty feet of 8 gauge wire and your amplifier suddenly needs 100 amps for a bass hit. Using Ohm's Law where voltage, or in this case voltage drop, is equal to the current (100 amps) times the resistance. Using a power wire resistance table we can see that 8 gauge wire has a resistance of 0.000739 ohms per foot. Multiple that by the twenty foot length of wire we have to get a total resistance of .01478 ohms. That doesn't seem like much but relative to the voltage of a vehicle's electrical system it is. Here's the math:
E = I x R or voltage = current multiplied by resistance
E = 100 amps x .01478 ohms
E = 1.478 volts
So 100 amps running through a twenty foot long run of 8 gauge wire causes the voltage at the amplifier to drop about 1.5 volts. And if your vehicle's system is charging at 14 volts (13.5-14.5 is the "good" range) the voltage at your amplifier will be 12.5 volts. This also shows why you need to know the current draw and wire length in your system. If your amplifier(s) are capable of large current draws on a continuous basis you need to have large power wire to keep this voltage drop minimized.
So what does that have to do with a car audio power capacitor? Two things. First, a power capacitor is placed much closer to the amplifiers than the battery is so that voltage drop is going to be much less all other things being equal. But second, your charging system probably isn't designed to provide current draws that large at any time. So your amplifiers are going to have to get the power from the vehicle's battery as well as the alternator. And the battery has its own internal resistance which, as stated before, is much higher than that of a car audio power capacitor. Because of this extra internal resistance it is not an effective means of delivering large amounts of instantaneous current. The capacitor acts like a small tank with a large hose while a battery acts like a large tank with a small hose. So with a capacitor installed you can deliver a large current burst during a music transient and then the capacitor can recharge during the non-peak portions of the music.
See the diagram below which illustrates the capacitor as a water tank. The water represents the electrical energy that a capacitor stores. The tank has a slow moving input line which comes from the battery. The tank also has a large output line which goes to the amplifiers. This large output line let's the tank drain quickly. But if the amplifiers try to pull too much out the tank will empty and you will have to wait until the slow input line from the battery refills it. To avoid this you need to make sure your tank is big enough for your amplifiers. This capacity or "tank size" is measured in Farads.
Will a Power Capacitor Help You?
I don't know, it depends. How's that for an answer? The degree of help a power capacitor will give you depends on your specific vehicle, car audio amplifier(s) current draw, music type and listening habits.
1. If the electrical system has a lot of additional reserve capacity (large alternator and battery) then you will benefit less then one that has a marginally acceptable charging system.
2. If you have large amplifiers with large current draw capability then you are more likely to need a car audio power capacitor. Smaller systems may not benefit at all or at least not enough to justify the cost.
3. If you listen to AM talk radio then you probably aren't going to have large transient peaks in your program material. But if you listen to bass heavy music then you are more likely to benefit from a power cap. This is especially true of classical music which has very large peaks and dynamic range.
4. You can have the biggest amps in the world but if you don't crank it up then you're not going to ever reach the large current draws those amps can require. Of course I don't really know anyone who buys big amps to let them idle. So if your system is being asked to reach loud volume levels a power capacitor can be a good supplement.
How Do You Know if You Need a Power Capacitor?
The first way most people know if their system is in trouble is headlights dimming. To most car audio enthusiasts with a passing knowledge of electrical systems this means a capacitor is needed. Headlights dimming? Get a cap. And that's a pretty good guess but not always true and certainly not a guaranteed cure. A power capacitor can only do so much. If your electrical system only has a scrape it's a good band-aid but if it's really bleeding you need stitches. And stitches come in the form of an upgraded alternator and battery. If the headlight dimming only occurs at idle then it probably isn't much to worry about and a power capacitor may help. An idling vehicle puts out much less current from the alternator while the current draw from the audio system remains the same.
What Size Car Audio Power Capacitor Do You Need?
Since the beginning of car audio power capacitor time (late 1980's) the accepted rule has been one Farad of capacitance per 1,000 watts of power with a minimum of one Farad (that last part is often forgotten). I've never seen any details on how they came up with that so I don't know what it's based on. But no one seems to have offered a better guideline so that's what we still use today. More isn't necessarily better but it doesn't hurt either.
So Do You Need One or Not?
If your system doesn't exhibit any problems such as dimming headlights then it probably isn't worth the added expense. I've done vehicles that benefited tremendously from caps and others that appeared to have not benefit at all. As always the only way to find out is to try it. Though every car audio shop is different it's unlikely that they will let you test drive a power capacitor. An easier way may be to borrow one from a friend that may already have one installed. Just remember to observe the same safety rules for uninstalling and installing a capacitor as you would for a battery (disconnect the negative terminal of the battery, remove the main power wire fuse, etc.). If installing the power capacitor doesn't help with dimming headlights then you either have a faulty charging system or an inadequate charging system. A qualified mechanic can tell you if the electrical system is not charging correctly. Be sure they check the grounds for the battery too.
In some cases you can determine for yourself if the factory charging system is adequate even under ideal conditions. Find the output rating (amps) of your alternator and figure about 30% of that may be available for your audio system. Remember that an alternator's output is not constant and the rated output will not be available when idling. The faster the alternator spins the more current it puts out. If you use an underdrive pulley on your engine then the alternator will put out less than its rated current. Now determine the current draw of your audio system under the conditions you will use it. The amplifier(s) manufacturer should provide this in the owner's manual or by request through telephone or email. If you crank it to the max then use the maximum current draw. Otherwise you'll probably want to use the "typical" or "with music" rating. If your alternator is rated at 80 amps then you probably have 24 amps available under ideal conditions. More when current drawing devices like lights and fans are off. This means your typical current draw needs to be less than 24 amps. Anything more than that are you'll be pulling the additional current from a storage device (battery and/or capacitor). Depending on the degree of additional current you need this can cause the dimming headlights syndrome. Small overages can often be helped with a capacitor while large overages need the upgraded alternator and battery.
E = 1.478 volts
http://www.caraudiohelp.com/newslett...citor_myth.htm
Old Jan 14, 2008 | 03:14 PM
redls1's Avatar
MAXIN' ON
In his post it says he has a cap.
Old Jan 14, 2008 | 03:16 PM
BigPete's Avatar
Incognito
using a cap is like putting a bandaid on a broken leg. It helps but theres no point. Do the big3 if that doesnt work upgrade your alternator. Adding a battery/cap will only put more strain on your current alternator and cause it to wear down faster.
Old Jan 14, 2008 | 05:04 PM
mavssolja's Avatar
ive read that our alternators can handle a second batt without a problem. Especially with an isolator. There are a handful of people on the other .org that have second batteries on stock alternators and they say it helps alot, and they have zero dimming etc. Ive read the same thing online a number of places, but then there are others that say different. There arnt very many options id figure i will try the second battery route, after i in stall a grounding kit, and see the outcome, i figure that will run me at most 300 bucks for high quality stuff, but a good high output alternator will run me twice that without install. Id also end up doing a second block if i upgrade alternator anyways, so it seems to be a good idea as of now.
Old Jan 14, 2008 | 05:26 PM
myer84's Avatar
A cap is not going to do much. I have one my self, but that is becuase I installed before doing the big three. The cap is just hooked up for looks. Try doing the big three and I'm sure your problem will be solved.
Old Jan 14, 2008 | 06:47 PM
mavssolja's Avatar
will do, thanx
Old Jan 15, 2008 | 12:07 AM
whitem1ke88's Avatar
Skep has 2 yellow tops and stock alt. I believe.
Old Jan 15, 2008 | 01:37 AM
bigmike8771's Avatar
i have 2 deep cycle bats with no isolator, and stock alt and have NO problems with dimmin lights. i only have 0 guage runnin from one to the other. and i CRANK my sh*t.
Old Jan 19, 2008 | 09:56 PM
xoomer.com's Avatar
I Donate! Why Don't You?
I don't see how two batteries would wear the alternator, can someone elaborate on the magic behind it.
Some dimming can be fixed with a grounding kit as noticed by other members.
Old Jan 19, 2008 | 10:56 PM
BigPete's Avatar
Incognito
when your pulling power from 2 sources it has to recharge both of them... 2 batterys doesnt do anything. If your pulling more power then your alternator can produce all your doing is maxing it out by adding an additional battery. You make up for the lack of power with an additional source, only to have to charge the extra source.
just do the big 3 and watch the problem go away.
Old Jan 19, 2008 | 11:40 PM
ramberg's Avatar
GrandPa
Just get one yellow top battery and you should have no problems.
Old Jan 20, 2008 | 05:45 AM
04MAX_ILLIN's Avatar
Maybe i missed something or i am just plain retarded but what is "the big 3" ??
Old Jan 20, 2008 | 06:07 AM
redls1's Avatar
MAXIN' ON
Definition: the "Big Three" upgrade means improving the current capacity of three cables: 1) alternator positive to battery positive, 2) battery negative to chassis, and 3) engine ground to chassis. Some people replace the factory wiring; others add additional cables to the factory wiring.
Old Jan 20, 2008 | 05:14 PM
xoomer.com's Avatar
Correct!
I'd have to disagree here; Adding additional battery effectively doubles the capacity of the system. Since they are installed in parallel there is load equalizing and the battery isn't drained as much nor is the high current damaging as much. Not to mention other benefits like backup (hidden) battery for an alarm.
The lack of power (electrical juice) is apparent in any high end car. Because the cars are loaded with all the extras there is more discharge than there is charge, especially on short city trips (think battery stratification as number one cause of battery failure). Adding a bigger alternator robs the engine of power and adds to engine load thus decreasing MPG.
As far as charging is concerned, you are not charging an additional source. I understand there is power loss just from the battery standing but the point I am trying to make is that as far as chargin is concerned, nothing changes. If you were drawing 5000 mAh from one battery, the alternator has to charge it back. If you draw the same amount from 2 batteries, its the same. Each battery gives up 2500 mAh and the alternator has to replenish the 5000 drawn, but split in half between two batteries.
In high demand where you draw more than you charge this same logic applies, the fact that an alternator will not be able to charge both batteries is the same as with not being able to re-charge one. If you draw 5000 mAh from one and charge only 3750, there is a loss of 1250 to the battery. Apply this to two batteries and each battery is short about 625 mAh (1250 per system as whole). This once again can be only fixed with longer trips or stronger alternator. However, the power reserve is doubled with an additional battery, meaning that if normally the batteries will fully discharge after on year, now it will be close to two.
Correct. Doing the "big three" is always beneficial, no matter the demand, as larger dia wires decrease resistance and increase conductivity.
Old Jan 20, 2008 | 07:37 PM
mavssolja's Avatar
thank you Xoomer, i have everyhting to do the "big three" but still plan on doing a second battery install. Thanks for clearing things up for those that doubt a second battery install. Sooooo many ppl wouldnt have done it if it was just robbing power/killing the alternator. a second battery is basically a SUPER cap ahah
DJLAX152
May 4, 2021 11:46 AM
MaxLife17
Jun 27, 2019 01:37 PM
markevans999
Sep 10, 2015 04:29 PM
Colossus
Sep 9, 2015 05:46 AM
Johnny9595
Sep 3, 2015 05:18 AM
