Wiring and color codes
Old Jan 14, 2008 | 04:02 PM
jreilly04's Avatar
I am gonna be wiring a aftermarket alarm in with the transponder bypass. Anyone have the color and wiring information for a 2004 maxima.
Old Jan 14, 2008 | 04:37 PM
jreilly04's Avatar
2006 Nissan Maxima Car Alarm Auto Security Remote Starter Wiring Diagram
Car Constant 12v+ Positive Wire (+): Green
Car Constant 12v+ Positive Wire Location: Ignition Switch Harness
Car Accessory Wire (+): White/Blue
Car accessory Wire Location: Ignition Switch Harness
Car Ignition 1 Positive Wire (+): Red
Car Ignition 1 Positive Wire Location: Ignition Switch Harness
Car Ignition 2 Positive Wire (+): N/A
Car Ignition 2 Positive Wire Location: N/A
Car Starter 1 Positive Wire (+): Black/Red
Car Starter 1 Positive Wire Location: Ignition Switch Harness
Car Starter 2 Positive Wire (+): Black/Yellow
Car Starter 2 Positive Wire Location: Ignition Switch Harness
Car Key Sense Positive Wire (+): Black/Red
Car Starter 2 Positive Wire Location: Pin #37 at BCM module, next to the fuse panel and behind the left side of the dash.
Car Door Lock Positive Wire (+): Green/Yellow
Car Door Lock Positive Wire Location: Pin #51 at BCM module, next to the fuse panel and behind the left side of the dash.
Car Door Unlock Positive Wire (+): Gray
Car Door Unlock Positive Wire Location: Pin #50 at BCM module, next to the fuse panel and behind the left side of the dash.
Auto Door Trigger Positive Wire (+): Red
Auto Door Trigger Positive Wire Location: Pin #48 at BCM module, next to the fuse panel and behind the left side of the dash.
Auto Trunk Trigger Negative Wire (-): Violet/White
Auto Trunk Trigger Negative Wire Location: Pin #57 at BCM module, next to the fuse panel and behind the left side of the dash.
Car Parking Lights Positive Wire (+): Red/Blue
Car Parking Lights Positive Wire Location: At vehicle fuse panel.
Vehicle Tachometer Wire: N/A
Vehicle Tachometer Wire Location: N/A
Vehicle Neutral Safety Positive Wire (+): Red/Black
Vehicle Neutral Safety Positive Wire Location: At vehicle fuse panel. This wire will test 12+ volts when an automatic transmission equipped car is in park or neutral.
Vehicle Crankshaft Wire: White
Vehicle Crankshaft Wire Location: Pin #13 at the ECM module behind the glove box to the right.
Vehicle Speed Sense Wire: Brown
Vehicle Speed Sense Wire Location: In instrument panel harness.
Vehicle Brake Light Wire (+): Red/Green
Vehicle Brake Light Wire Location: Brake switch above brake pedal.
Vehicle Horn Negative Wire (-): Green/White
Vehicle Horn Negative Wire Location: AT BCM module next to the fuse panel behind the left side of the dash.
IS THIS CORRECT ?????????
Old Jan 14, 2008 | 06:29 PM
carlosr's Avatar
Here's a helpful link.
http://64.85.6.121/diagrams/diagram....5&link=BULLDOG
Old Oct 15, 2010 | 10:05 AM
Goliath27's Avatar
Bringing back an old thread
Would you say it's hard to do the install? I'm looking to do one on the maxi before the winter comes but everyone here wants over 250 for one installed and it's just an auto.
ALi
Old Sep 1, 2011 | 07:48 PM
HollowTips's Avatar
Hey all im new here just wanted to know how to hook up some LED lights to my parking lights but im confused about the wiring the LED lights only have the Red(positive) and the Black(ground) but my parking lights have a BLUE, RED with BLACK STRIPE and GREEN with YELLOW STRIPE. I have a 2006 Nissan Maxima any help would be appreciated.
Old Sep 2, 2011 | 03:22 PM
dee.signs's Avatar
not sure of the color codes, but an easy way to tell which is ground is to use an ohmmeter. One of those wires might be for the highbeam flapper..But both using common ground
I have my head lamps torn apart as we speak, but i hav an 07.
The Frye
Sep 2, 2021 11:03 AM
Maxima.KsA
Sep 8, 2015 11:33 PM
