Steering wheel problems!!!
Old Dec 21, 2008 | 03:42 PM
alxdagreat1's Avatar
Hello guys I have a problem with my telescoping steering column. Sometimes my steering wheel will move up or down after I turn the ignition on but sometimes it don't and it pisses me off. Any of you had this problem? I can hear the relay engage when I try to move the steering wheel but it wont move. Any idea what wrong or how to fix it? THANKS.
Old Dec 22, 2008 | 07:45 AM
VigilanteMax's Avatar
Either a relay or a steering column problem. This has been a reported issue in the past.
Old Dec 22, 2008 | 08:37 AM
Is there old threads about this that you know of? Any idea where this relay is located? Just wondering cuz I'll like to look at it, I try my best not to go to the stealership!!!
Old Dec 22, 2008 | 12:26 PM
Either under the steering wheel or under the hood...couldnt tell you. My whole steering column needed to be replaced. If there is a little movement when the motor is done, then it could be your column. It is expensive.
Old Dec 22, 2008 | 07:10 PM
ImperfectMax's Avatar
it also depends if your door is open or not.
Old Dec 23, 2008 | 05:34 PM
How expensive?
Old Dec 23, 2008 | 05:36 PM
Door closed my friend, it just acts up every once in a while but still I don't like it. I don't know if this was a major issue for this year.
Old Dec 24, 2008 | 08:35 AM
Sorry but I thought it was a click i the column. The problem you are having is the computer behind the information display that controls the steering complex is acting up. Mine used to do that but it has been a while.
Old Dec 24, 2008 | 08:48 AM
How did you fix it? Did you have to go the stealership?
Old Dec 24, 2008 | 08:49 AM
yes, but never got it replaced. Never happene\d again after a while
Old Dec 24, 2008 | 08:55 AM
Ok I guess I'll head to the stealership and see what they tell me? Do you know if there are any old threads about this or where I can get more info?? Thanks.
Old Sep 3, 2011 | 11:55 AM
Daddyhunt's Avatar
My steering column is stuck in the down position. It goes in or out, but not up. Any quick fixes???
MAXSE5SPD
Sep 17, 2022 04:00 AM
trasmadean
Feb 1, 2017 08:20 PM
intimidator
Sep 5, 2015 07:23 PM
maximusrising
Sep 2, 2015 09:55 AM
tnewbs
Aug 28, 2015 10:15 AM
