UDP damage...
Old Jan 21, 2008 | 05:45 PM
  #41
redls1's Avatar
MAXIN' ON
Yeah it can only go on one way , just dont remember those being on mine.
Old Jan 21, 2008 | 08:05 PM
  #42
!PrjctMax!'s Avatar
If people could check theirs just to make sure, then that would be great.
coolmax05-that's what I also thought too, since the BIG notch in the middle would place it there...and I didn't know that one had to make it TDC to install the pulley...
Old Jan 21, 2008 | 09:12 PM
  #43
coolmax05's Avatar
It's not for the pulley/belt itself, per se...it's for the replacement of the timing chain I believe (at a later point).
The timing on our cars is controlled by the computer using crank sensors. But the crank has to positioned correctly in reference to the cam. To accomplish this, both the cam and (in this case) the UDP must be in a certain position to each other. You do this using the marks on the UDP and the cam.
The cam opens and closes the valves at particular time relationship to the pistons.
Ultimately the timing chain determines the relationship between the pistons and valves in the engine. That's why you want it replaced before taking any chances on it slipping or breaking.
The UDP itself has no bearing on the relationship between the cam and the crankshaft.
Your question was answered by post #6 a while ago. He just didn't elaborate. That's why the thread was deemed dead on arrival. Why the others didn't see marks on their UDP's is a mystery. Consider yourself lucky!
Old Jan 22, 2008 | 06:03 AM
  #44
DONS459's Avatar
Every car i have owned has had a timing mark on the pulley. That's the first thing i thought it was when i saw the picture of his pulley.
Old Jan 22, 2008 | 06:10 AM
  #45
AceofSpds's Avatar
wat
Originally Posted by coolmax05
Someone correct me if I'm wrong but, I believe without marks on the UDP, you would have to take the head off to know "Top Dead Center" when you replace the timing belt.
Keep in mind the UDP only goes on one way due to the "notch" even though it's circular.
VQ's use timing chains, no need for setting it to TDC if you are changing the pulley, the pully just runs the accesorries (a/c, steering, etc..)
And to think i almost bought that UDP too lol. Thats some pretty half assed work on the "timing marks"
Old Jan 22, 2008 | 06:17 AM
  #46
redls1's Avatar
MAXIN' ON
Just did a quick search and HIBE took some pictures of his before he put it on. In his first picture you can see the marks.
http://forums.maxima.org/showthread....ighlight=cosmo
Old Jan 22, 2008 | 06:47 AM
  #47
!PrjctMax!'s Avatar
That's exactly what I told them too! Looks like they just took a dremel and zapped a few lines in it without cleaning them up!
hmmm, I guess I'm just going to try and clean the lines up a little bit, and call it a day.
Old Jan 22, 2008 | 07:46 AM
  #48
redmaxpa007's Avatar
i SeE what you did therE
hmmm.........
have you changed out your canadian ruler to an american one yet??
Old Jan 22, 2008 | 07:58 AM
  #49
!PrjctMax!'s Avatar
Originally Posted by redmaxpa007
hmmm.........
<---Canadian colors funny since the company is from Canada!
Old Jan 22, 2008 | 08:25 AM
  #50
QwikKota's Avatar
hmmm.........
Its right next to his metric crescent wrench.
Old Jan 22, 2008 | 08:28 AM
  #51
i knew they were from canada... that is what made me think of your ruler..
we had the conversations about UDPs...
i just snagged a udp from ebay..
greg proved that a 4th gen pulley would fit his 3.5l
www.greghome.com
Old Jan 22, 2008 | 08:29 AM
  #52
got a link?
Old Jan 22, 2008 | 08:36 AM
  #53
QwikKota's Avatar
got a link?
I think Big Lots is running a sale, lmao
Old Jan 22, 2008 | 09:47 AM
  #54
!PrjctMax!'s Avatar
har har har guys
We talked about UDP's, but what's your point on that?
Old Jan 22, 2008 | 09:57 AM
  #55
QwikKota's Avatar
har har har guys
Just trying to be funny, not directed at anyone! I wouldn't do any more than just run a flat file on the belt side of the pulley lip. Other than That I'd leave it alone.
Old Jan 22, 2008 | 01:57 PM
  #56
Apollos2's Avatar
Looks more like the wacked it with a chisel. I'll see if I can check my stock pulley when I get home and look over my pics of my UR SCpulley as well.
Here a pic of an UR UDP, I wonder if the little tabs that stick out off the edger are the timing marks?
Installed pic but nothing clear in this one
Old Jan 23, 2008 | 11:08 PM
  #57
Outlawd's Avatar
Does Cosmoracing's UDP have the hollowed out holes like the unorthodox UDP?
Old Jan 24, 2008 | 03:25 AM
  #58
har har har guys
you sir, need a sense of humor...
Old Jan 24, 2008 | 05:29 AM
  #59
redls1's Avatar
MAXIN' ON
Nope see picture on first page.
Old Jan 24, 2008 | 08:24 AM
  #60
!PrjctMax!'s Avatar
Do I need emo cons after my "har har har" to signify humor?
Old Jan 24, 2008 | 08:33 AM
  #61
Old Jan 24, 2008 | 09:11 AM
  #62
Hilbe's Avatar
Here is a picture of mine for those wanting better pictures of the Cosmo Racing UDP:
Old Jan 24, 2008 | 10:18 AM
  #63
mowgli29's Avatar
Horizontally opposed.
those are for the crank position sensor. without those tabs, the crank position sensor would go
Old Jan 24, 2008 | 10:26 AM
  #64
QwikKota's Avatar
Lol, CPS works off reluctance. Needs steel not aluminum. Those sensors are behind timing covers or some nature of protection 99% of the time. They are just timing alignment marks.
Old Jan 24, 2008 | 11:01 AM
  #65
!PrjctMax!'s Avatar
So if the CosmoRacing pulley doesn't have that then what...I'm doubtful on that, since a few have already installed with no problem
Old Jan 25, 2008 | 12:05 AM
  #66
NiZMo1o1's Avatar
I might be a little late , but you do get what you pay for , Unorthodx have markings on their pulleys like AEM .. Cosmo or Top Speed , Arospeed Pulleys dont have acutally engraving markings.. Dan those arent damage markings.. those are for the timming.
your perfectly fine ..
Old Jan 25, 2008 | 05:42 AM
  #67
!PrjctMax!'s Avatar
I'd rather save $150 some and get 3 little half-assed markings than pay $150 more to get some laser etched ones!
Old Jan 25, 2008 | 06:33 AM
  #68
Apollos2's Avatar
See, he does have a sense of humor! Let us know if you notice a diff once it's installed.
Old Jan 25, 2008 | 02:37 PM
  #69
NiZMo1o1's Avatar
Yeah Keep us updated Dan .. I Think im going to order mines Monday..
Old Jan 25, 2008 | 07:18 PM
  #70
!PrjctMax!'s Avatar
I'm sure I'll notice a HUGE difference since this is not the only power mod going on... but all of this won't be installed till' sometime in the spring... lol
Old Jan 27, 2008 | 04:59 PM
  #71
cefiro80's Avatar
This is hilarious
Old Jan 27, 2008 | 07:47 PM
  #72
NiZMo1o1's Avatar
Originally Posted by cefiro80
This is hilarious
Old Jan 27, 2008 | 10:52 PM
  #73
Outlawd's Avatar
For those who have installed the UDP on their max....Did you notice any electrical power issues to any components of the car or any other issues associated with the UDP upgrade?
Old Jan 28, 2008 | 04:57 AM
  #74
redls1's Avatar
MAXIN' ON
nope.
Dave B
May 29, 2001 11:07 AM
y2kse
Feb 25, 2001 08:47 PM
Andrew91SE
Nov 26, 2000 03:05 AM
ohboiya
Oct 9, 2000 12:23 PM
