Osiris from UpRev
Osiris from UpRev
http://forums.maxima.org/showthread.php?t=551565
Mods-Please allow this since not everyone checks the "All Motor" section
thanks,
dan
thanks,
dan
I was thinking the SAME EXACT thing...but shrug...lol
Once I have all of my mods and if there is nothing going on, then I might just buy it out of chance and see if it works
For the 6th genners, it should be a "go," since the data that we would send them would be for OUR car, and no problem should arise with it.
prjct,
I still haven't decided yet between the UTEC and Osiris. But if you end up getting Osiris and I haven't gotten anything by the time you do I wanna try to hook up with you to check out the program up close before I buy it. Only thing really making the UTEC tempting is the fact that you can get them for so cheap. You know what I mean you saw how much they go for sometimes.
For sure...BUT for me...early 04' model, I would have to get a Wideband sensor welded into my y-pipe...I'm sure it's not that big of a deal, but more time/money...I wonder if I would have to do that for UTEC and Osiris. More research will show, until then...bolt-ons galore here I come
Well I know that the UTEC has that Tuner XS that comes with the wideband. But it's not cheap. I wanted to get the AEM UEGO after I go my tuning device just to keep track of the A/F. I did some reading and some of the guys were getting alot of ping after their initial tune from Osiris. They said they were using 93 octane but turned out it really wasn't. Either that or they had too much timing or not enough fuel. I wonder if Uprev will release it at the end of this month like they said.
And just how many threads about tuning are you going to start without knowing anything about tuning.
Joshua
EDIT: Nevermind, Nietzche popped up.
You told me that I would need a wide-band for the UTEC...didn't know that I would need one regardless. What wide-band do you have?
At least I'm searching, getting info, and willing to take chances on products unlike a lot of people.
I look at it this way...I'm not afraid to ask questions and "**** up" along the way because either way, I will get good info out of it. ftw
I figured that the UTEC already had a built in wide-band if it was compatible with the car.
I didn't realize you needed further clarification, my apologies. I still say just get the UTEC and have some fun. You can use any number of WB's with the MPSlogger software and record the AFR. Plus, you can't mess with osiris by yourself, it's always send files and get a flash. I like having the ability to adjust whenever I want. Although the set it and forget it method is nice at times.
There's a thing in there called "temperature compensation," and if not done right you will have lean cuts on different days...friend with RSX has it all the time, unless it's set right, which it almost never is.
This is also another reason why I would want the Osiris for the most part
inspiredbykev
Audio/Video/Electronics
May 21, 2013 05:33 PM
