RI FS: UpRev Cipher proprietary cable
Old Dec 30, 2012 | 12:07 PM
inspiredbykev's Avatar
You should thank my D***
UpRev Cipher proprietary cable. You will have to download the drivers and program on their site for free.
$150 picked up; additional $5.95 shipping.
Cipher communicates using Nissan’s proprietary communication protocol which enables you to view data with more speed than generic OBDII scan tools giving the user better insight into how the vehicle is running. Sample rates of 20 times per second can be achieved on more than 15 sensors at a time.
Simple ECU and BCM Control
Cipher also provides the user with basic dealership work support routines for the ECU and BCM including:
  • Target Idle RPM
  • +/- 2 degree static timing adjustment
  • Cylinder power testing
  • Clear Learned Fuel settings
  • Manual control of BCM functions, ie. Windows UP/Down, Activate Locks, Wipers, Lamps, etc.
  • Fuel Pressure purge
  • Ethanol Adjustments (if vehicle is equipped)
  • Coolant Test
Supported Parameters:
Below is a short list of available data parameters...
  • Engine Speed - RPM
  • Throttle Position Sensor
  • Vehicle Speed
  • MAF Sensor
  • Calculated Load Value
  • Oxygen Sensor
  • Ignition Timing
  • Accelerator Position
  • Wide Band A/F Voltage (equipped vehicles)
  • Coolant Temperature
Old Jan 6, 2013 | 08:42 AM
Ttt
Old Jan 12, 2013 | 02:27 PM
still available
Old Feb 4, 2013 | 06:50 PM
bump
Old Mar 17, 2013 | 11:47 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
:/ I want it :/
Old Mar 19, 2013 | 07:02 PM
Originally Posted by Cant_Get_Ryte
:/ I want it :/
Still avail
Old Mar 28, 2013 | 08:37 PM
ttt
Old Mar 29, 2013 | 08:16 AM
JWatZ's Avatar
Interested, but I only see the Osiris install, nothing for Cipher.
http://www.uprev.com/support.php
Old Mar 30, 2013 | 09:04 PM
Cipher is included in the Osiris executable file below.
Osiris Installer 11-16-2012.exe
Old May 2, 2013 | 07:11 PM
Maverick4189's Avatar
Update?
Old May 16, 2013 | 05:37 AM
JWatZ's Avatar
Sent PM a couple days ago.
Old May 21, 2013 | 05:33 PM
sold
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
carid
Sep 9, 2015 05:06 AM
pktaske
Sep 4, 2015 08:40 AM
