Can I use 17 inch winter tires?
I am rollin on 17” winters, and have seen 18” winters, so
It changes handling, not very tight, speed rating typically drops down to Q, if you're lucky S.
17" wheels/tire are easier to move, so you get a little more power to the ground and better MPG.
Here are some calculations showing the rim+tire diameter of the stock 17" and 18" wheels. Surprisingly, the 17" has the larger diameter (just 0.06" larger).
[Ref: http://www.tirerack.com/tires/tirete....jsp?techid=7]
section height = width * aspect ratio
section height of P225/55R17 = 225/25.4 * 0.55 = 4.87"
section height of P245/45R18 = 245/25.4 * 0.45 = 4.34"
Overall rim+tire diameters:
17" + 2*4.87" = 26.74"
18" + 2*4.34" = 26.68"
Note that each 18" rim+tire weighs a few more lbs than each of the 17" rim+tire.
