Losing coolant
Old Mar 4, 2008 | 02:32 PM
Kryogen's Avatar
Losing coolant
Hi, I got my car 2 weeks ago. I week ago I checked the fluids and coolant was below minimum, so I filled it to the full line.
I checked it today after 700km of highway, and it's below the minimum line again ?!?
What could be causing coolant loss like that? doesnt seem to be dropping under the car.
I think I got a coolant smell when driving, not sure.
And another question, when I turn on the front defogger, it turns on AC to dehumidify, but it blows cool air even though the temp is set to 73-74. Normal?
Thx
Old Mar 4, 2008 | 02:41 PM
redls1's Avatar
MAXIN' ON
When you checked the fluid was it cold or hot? It will be at different levels depending on when you checked it. You could also have you radiator presssure tested for a leak.
Old Mar 4, 2008 | 03:23 PM
Kryogen's Avatar
checked it cold both times... there has to be a leak, weird. 04 max loosing coolant. ill bring it to the dealership. got 3 more years of warranty.
Old Mar 4, 2008 | 03:26 PM
mtrai760's Avatar
'Trynna' is not a word
You have more 'problems' with your car than a 1st gen with 1,000,000 miles
Old Mar 4, 2008 | 06:04 PM
KCMAXX's Avatar
KC's FINEST
LOL²
I feel sorry for your service advisor...
Old Mar 4, 2008 | 07:59 PM
larsim's Avatar
Wink. I'll do the rest.
Thx
Dude - look into my eyes and tell me. Are you really having all these issues? or you just playing with us?
Old Mar 5, 2008 | 02:04 AM
lightonthehill's Avatar
Kryogen - Sorry about your coolant leak. That is something that is going to have to be fixed. I assume there are places (maybe the dealer) who have a way to find where the leak is (maybe by applying pressure?).
As to your HVAC system putting out cool air whenever your windshield defroster is on, I have found the 'conversion point' where it switches to warm air when defrosting is between 76 and 78 degrees on my Maxima. Yours is probably the same. Since it is very consistent with this cutoff point, I have grown used to it, and have no problem with it.
Old Mar 5, 2008 | 10:00 AM
STARR's Avatar
Had an Altima that was losing coolant in the overflow, it was leaking out slowly but not leaving a puddle on the ground, the radiator was fine and always full so I never questioned it, problem started at around 20k, probably put another 60k on the car and traded it in
Old Mar 5, 2008 | 10:14 AM
brio_max's Avatar
Learning English...
Bad head gasket?
Old Mar 7, 2008 | 11:21 AM
Kryogen's Avatar
Rad leaking, dealer will change it under warranty tuesday
Old Mar 7, 2008 | 12:05 PM
ramberg's Avatar
GrandPa
Please tell me whats wrong with you? You must love to get flamed.
Old Mar 7, 2008 | 04:09 PM
larsim's Avatar
Ramberg. I'll bet you a $1 that his answer is
Old Mar 7, 2008 | 06:33 PM
farzin1's Avatar
somebody needs to give this guy a limit of posting threads, like one thread a month. he is just posting threads one after another.
Old Mar 7, 2008 | 06:40 PM
KCMAXX's Avatar
KC's FINEST
The mods are laughing instead of compressing...
Old Mar 7, 2008 | 07:48 PM
SilverMax_04's Avatar
Glad the answer was this simple.
In my Dodge pickup truck I had a slow anti-freeze leak into the motor oil. I only found it because I sent in an oil sample to be tested. The old oil was just fine, but they found the anti-freeze in the oil. Turns out that both heads had small cracks around the holes for the bolts that bolt the head to the block. While head gaskets have been known to leak, this crack problem is probably more prevalent.
Bottom line: Get you old (just drained) motor oil into the lab for a test. This test will tell you if you have anti-freeze in the oil and also how much life remains in the oil that you are throwing away. The test is definitely worth the small cost.
Old Mar 7, 2008 | 08:10 PM
Kryogen's Avatar
Whats wrong about a thread talking about losing coolant on a 04 max? I dont get it.
I'll tell you if problem is fixed once they change the rad on tuesday.
Thanks guys.
Old Mar 8, 2008 | 05:27 AM
larsim's Avatar
Thanks guys.
Kryogen - no one has issues about you asking questions as that is what forums are for - for us to exchange information, right? BUT, have you noticed how many threads you have opened in the last few days with most of answers that can be found in the car's manual? Now, I am not saying to never discuss anything that's on the manual, but you may want to word it differently.
Here is an example. Let's just say you have a question regarding how often you should change the car's oil.
"Guys, how often should I change my car's oil"?
OR
"Guys, I know that the ""MANUAL""" says I need to change my car's oil at xxxx miles, what do you think? What have you guys been doing?"
Which one do you think sound best and will get you the most reply?
Also - you may want to try using this when opening your threads "Guys, I know this question may sound stupid, BUT......."
I haven't been in this forum for very long, but I have found that the people here are for the most part friendly, you just have to word your questions intelligently.
Old Mar 8, 2008 | 07:23 AM
KCMAXX's Avatar
KC's FINEST
He told me he was a dentist.
Good to see they will fix it.
Old Mar 8, 2008 | 07:35 AM
jgrabina's Avatar
That pic of the girl with 4 eyes is crazy
Miket2006
Mar 1, 2021 03:55 AM
gigabyte
Jan 6, 2017 06:05 PM
captchaos
Mar 15, 2016 12:18 PM
msellas
Sep 23, 2015 09:16 PM
junito1
Sep 23, 2015 12:14 PM
