Steering Creaking Noise
Old Mar 25, 2008 | 05:32 PM
Hilbe's Avatar
I just noticed today when I turn left there is a creaking coming from the front. Anyone have any suggestions on where to start? I'm clueless when it comes to this stuff...
Old Mar 25, 2008 | 06:33 PM
VigilanteMax's Avatar
Steering rack, strut mount, steering column. Spray some silicone in the joint under the dash if you think the column.
Old Mar 25, 2008 | 06:40 PM
Hilbe's Avatar
Its definitely coming from outside of the cabin. Pictures would be great where I need to spray
Old Mar 25, 2008 | 07:51 PM
!PrjctMax!'s Avatar
on which joint...I believe there is only one, but more insight would be great.
Old Mar 26, 2008 | 05:50 AM
If its comming from outside, its not your column. Sounds like a strut mount as I have this issue as well. Sounds like rubber on rubber, or rubber on metal? I took my struts and springs off again this past week and greased everything. The issue is the bushing within the mount. Oh and by the way, if you look under the dash you will see that coulmn joint deep inside. Nothing to remove.
Old Mar 26, 2008 | 02:39 PM
!PrjctMax!'s Avatar
For me it's both...depending on the temperatures outside lol
I know it's my mounts and I am going to replace them soon...what EXACT part is the one that "breaks" the most?
Steering column also squeaks and I've looked down there before seeing the main joint, so I will def. put some grease on it.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
