"Clunking' Noise when the road is rough
Old May 16, 2008 | 09:02 PM
carcraze28's Avatar
When I am going through bad roads, i hear this "clunking" noise from the front suspension area. This noise can only be heard when the road is really bad, otherwise there is no noise. Any suggestions what is contributing to this before i go to the dealership.
Old May 16, 2008 | 09:28 PM
2LEET4U's Avatar
r u lowered????
if your all factory, then take it to the dealer for some warranty love...
Old May 16, 2008 | 09:33 PM
carcraze28's Avatar
i am not lowered. I brought it to the dealer once to have them inspect my suspension being too harsh. After the inspection, they said the suspension is good. And concluded that it is my tires that is making the ride harsh. I am using Good Year F1 All season.
Old May 17, 2008 | 08:32 AM
BadBlackMaxSL's Avatar
Struts and end links....... Imagine that, a Max with a bad front suspension.....
Old May 17, 2008 | 04:48 PM
331TwistedWedge's Avatar
yes definitely your struts ... my '04 is doing it right now, its time for some kyb's ...
Old May 17, 2008 | 05:58 PM
Solow1's Avatar
how many miles did u go with the stock struts?? and are u lowered?
Old May 19, 2008 | 06:49 PM
trini_maxima's Avatar
hi everyone........i havent posted many times before but i am having the same issue when i was on stock susp. and now im on ksport coils and the same noise.........everything is torqued down to spec and still over bumps it sounds like metal on metal..........oh yeh its the front right and i did change the linkage to a moog aftermarket one and still the noise is there
Old May 19, 2008 | 07:10 PM
spyydert's Avatar
I hope you can figure out a resolution to this problem, i'm dealing with the same thing here, i'm also in a 2004, had the problem with stock suspension, i work for a nissan dealership and they said change the struts, now im on K-sport coilovers and still getting the same problem. Now my steering is messed up also, makes a "clanging" noise when i spin the wheel at stop / low speeds.
Old May 20, 2008 | 01:33 PM
Shoey1's Avatar
im gonna have to go with sway bar links
Old May 21, 2008 | 07:08 PM
xorbitman's Avatar
Check out the other suspension problem thread here...most likely the front strut mounts and bearings need to be replaced.
Old May 22, 2008 | 04:40 PM
Libz's Avatar
..also had this problem lol.. brought it to the dealership i had to replace the struts... the noise came from the front right also... had it back for about 3 months now hasn't given me any trouble at all im just more careful of potholes etc.
Old May 30, 2008 | 01:03 PM
joffy's Avatar
I have the same noise. Might be the seat rubber for the front springs as discussed in another thread. I don't want to change struts and the noise still be there.
Old May 30, 2008 | 06:27 PM
VigilanteMax's Avatar
Sounds like endlinks which I will be replacing next week. Would have gotten the racingline but they are out of stock...
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
uttadms31
Sep 30, 2015 05:24 AM
