In-cabin microfilter
Old May 29, 2008 | 09:56 AM
aogburn's Avatar
I noticed yesterday that my ac wasn't blowing cold air when I went through the car wash. Could this be because I haven't replaced my in-cabin microfilter since I purchased the max over 40k miles ago? Can some of your max lovers help me out here?
Thanks!
Old May 29, 2008 | 10:28 AM
VigilanteMax's Avatar
not your in cabin filter, check the pressure that your compressor is functioning to full compacity and also freon levels. Will have to get a diagnostic but it is cheap. If your in cabin filter hasnt been changed in a while, getter done.
Old May 29, 2008 | 10:33 AM
Apollos2's Avatar
In-cabin won't affect that. I and other have had Freon leaks from the low pressure hose. They had to replace my twice within a 15mo period. I bet you have an A/C leak.
Old May 29, 2008 | 11:20 AM
DeusExMaxima's Avatar
Sounds like an AC leak. Also, ur filter should be replaced by 40K. My was filthy at around 50K.
Old May 29, 2008 | 11:45 AM
ramberg's Avatar
GrandPa
I don't know where you live but I change mine every 25,000 miles.
Old May 29, 2008 | 12:30 PM
jsmithsole's Avatar
*moderator*
Yeah it's not your problem but change it anyways...it probably looks like this (mine after 30k)
Mine stopped blowing cold air and they found a broken wire down by my intake (I'm sure it's something I did since I'm always messing around in there!)
Old May 29, 2008 | 08:19 PM
aogburn's Avatar
Yeah, but how much would an A/C leak cost to repair on average? (if that's what the problem is)
Old May 29, 2008 | 10:11 PM
SmokeNismo's Avatar
It aint cheap.
Mine had a leak a few months back. Without my extended warranty, my dealer quoted me I believe around 400. just to replace a hose. I still ended up paying $50 with the extended warranty.
Old May 30, 2008 | 01:25 AM
ramberg's Avatar
GrandPa
Are you till under warranty? If not find a place in your area that fixes AC for the car. It will cheaper than the dealer. Watch what they are doing when they check it out. You don't want to pay for something you didn't need.
Old May 30, 2008 | 04:59 AM
aogburn's Avatar
I'm at 42k right now. I was thinking the same thing! You know how the dealer just rips your pocket out of socket! Especially with these fuel prices now. I need to cut corners somhow. Thanks!
Old May 30, 2008 | 05:41 AM
Apollos2's Avatar
At 42k you are outside your warranty. Usually what they do is refill the system with an ltraviolet dye or freon with dye and then use the black light to see where the leak is. Just call around for prices, I think you are looking in $200-$300 price range. That's with a new hose and freon refill.
Here's a couple of previous threads, maybe something helpful in there too.
http://forums.maxima.org/showthread....=pressure+hose
http://forums.maxima.org/showthread.php?t=559675
Old May 30, 2008 | 06:09 AM
Lovemycar's Avatar
Dam my AC is still ice cold but i better change that filter but where is it? and where to buy
Old May 30, 2008 | 06:40 AM
spidgeon's Avatar
Filter is located right behind the glove box...You'll need physically remove the glove box to get to it. It took me about 10-15 minutes though, very easy. Courtesyparts has it for about $30, but you can pick up a puralator for about $12 at autozone.
Old May 30, 2008 | 07:17 AM
stcktnkid's Avatar
Yea I paid 12 at autozone had it replaced in about 15 mins. The dealership wanted 35 for it or 85 installed...hahha
Old May 30, 2008 | 11:31 AM
Shoey1's Avatar
if its not blowing at all then it may be the filter, or the fan, or fan resistor (if the resistor is at fault it ususally only works on high or low, no intermediate). but if its blowing but not cold its ur ac.
Old Jun 2, 2008 | 08:56 AM
spidgeon's Avatar
Gotta love the stealerships...
Old Jun 2, 2008 | 09:05 AM
Apollos2's Avatar
Any word on your AC?
Old Jun 7, 2008 | 08:13 AM
aogburn's Avatar
Went to the stealership the other day. They told me that I was extremely low on freon, and they would charge me $215 to charge it back up, put the dye in it and look for leaks under the U/V light.
Is there anyone in the D.M.V. (D.C., MD, VA) area that know where I could take my max to ang get a better deal for the same service?
Thanks!
OG
Old Jun 7, 2008 | 08:46 AM
WINTERFAUST's Avatar
Thanks!
OG
I am surprised people do not know me on this board... I am in Gaithersburg at the Criswell dealer (previously Victory). Bring it to me I will charge you less than $150... check the 6thgen board and ask around who I am and my integrity. Phone is 301-670-3900 x310 -chris
Old Jun 7, 2008 | 09:53 AM
fcoral 05's Avatar
Hey guys listen to winterfaust i read a lot of post from him on the other forums and he is always good with what he says. I wish he was in new york. Like he said if you're close to his store then take it to him.
Old Jun 7, 2008 | 12:32 PM
aogburn's Avatar
okay winterfaust, I will take you up on that. I live in columbia so it's not that long of a drive. The dealership told me that they didn't see anything visibly wrong with my a/c lines but I was really low on freon. I will give you a call monday morning!
OG
Old Jun 7, 2008 | 12:41 PM
OG
BRAVO!! I look forward to hearing from you!
Old Jun 7, 2008 | 12:47 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Your vehicle Operators and Maintenance manual is your friend!!!
fangorn
Nov 19, 2004 02:28 PM
ARVY
Jan 5, 2004 07:13 PM
issa3032
Nov 9, 2003 05:32 PM
GregP
Sep 14, 2003 03:27 PM
