Engine help....
Old Jun 15, 2008 | 09:25 AM
Big Mike's Avatar
Engine help....
I have over 89K on my 04 Max and lately I have been experiencing weird idling fluxuations. A couple of times I was sitting at a traffic light and I watch the rpms drop and rise then I noticed the oil light idicator flash on and off. The car seemed as if it was going to stall but it didn't. I immediately pulled off the road and checked my oil, everything was fine, plenty of oil and no leaks. I only run synthetic oil since I've owned the car, is there a serious problem on the horizon? I am also hearing a dieseling sound at low rpms (valve chatter), when I punch it it goes away, is it low grade gas? I thought maybe I need to change the spark plugs, maybe I am misfiring but I would throw a cell if that was the case. I checked the ECM for codes but I didn't get anything. Diagnosis?...
Mike
Old Jun 15, 2008 | 09:46 AM
WINTERFAUST's Avatar
sounds like you need a timing chain set my friend. Just did one on a 6thgenmax.org members car which was doing the same thing at about the same mileage.
Old Jun 15, 2008 | 09:50 AM
Big Mike's Avatar
How much will the timing chain repalcement cost me?
Old Jun 15, 2008 | 09:51 AM
Big Mike's Avatar
How much will the timing chain replacement cost me?
Old Jun 15, 2008 | 10:33 AM
Shoey1's Avatar
the reason your oil light came on was because the rpm dropped so low it wasnt making enough oil pressure. the idle issue could be alot of things, spark plugs, timing, fuel, bad coil. i can go on but i would just take it to a trusted tech and have them diagnose it. dont just start throwing parts at it if your dont know for sure what the issue is
Old Jun 15, 2008 | 10:41 AM
Apollos2's Avatar
So when you do a timing chain? (belt?) What are some other good things to maintenance while you are in there.
Old Jun 15, 2008 | 10:59 AM
Big Mike's Avatar
I will take it to the stealership tomorrow and have them look it over.
Thanks,
Mike
Old Jun 15, 2008 | 11:48 AM
!PrjctMax!'s Avatar
VQ's only have timing chains
Old Jun 17, 2008 | 10:50 AM
Big Mike's Avatar
Does this sound logical? I have been running 87 octane fuel in my car for about two months since the gas prices are sky high. Well yesterday I filled up with 92 octane and the dieseling sounds went away and the fluxuations at idle have gone also. I know this car is design to operate on regular 87 octane gas but would it make that much of a difference using the lower octane fuel. Since I've owned the car I have used 91 or better fuel but lately I switch to save some money, the car drove fine, the mileage was still around 23-25 combined city/highway.
Anyone else experienced this problem besides me....
Mike
Old Jun 17, 2008 | 11:00 AM
PapaL's Avatar
Mike
The car is designed for optimum performance use optimum gas. Says so on the gas door.
How much money are you saving at the pump? 20cents x 10 gallons = $2. Is that worth other possible problems?
Old Jun 17, 2008 | 11:10 AM
ramberg's Avatar
GrandPa
Mike
Big Mike put a couple of tank fulls of high test gas in the car and see whats happens before changing parts.
Old Jun 19, 2008 | 07:02 AM
trini_maxima's Avatar
not to alarm you or anything..........but i had the same exact idling issue and dip in rpm, then one week later my timing guides broke.loud crazy ticking noise like a tracktor and I was so sol, then had to get a whole timing job done. 12 hours labor plus parts. get it checked out my friend. oh and once u in there its good to change the chains as well, they stretch after a while.
Old Jun 19, 2008 | 07:13 AM
Big Mike's Avatar
Thanks for the information!! You would think that having a timing chain would be better huh....How much did you have to pay for the timing chain replacement?
Old Jun 19, 2008 | 08:45 AM
NmexMAX's Avatar
dot dot dot ...
How's your oil level? Sometimes the chatter is attributed to low oil level.
There is a TSB on the subject.
Old Jun 22, 2008 | 06:45 AM
Big Mike's Avatar
Oil level is fine, I even used royal purple during my last oil change. I actually picked up a couple of extra MPG with the royal purple!!!
Mike
Old Apr 29, 2010 | 09:51 PM
CWatson's Avatar
??royal purple increased you gas mileage??
Old Apr 30, 2010 | 10:34 PM
NmexMAX's Avatar
dot dot dot ...
Really? From 2 years ago, you bumped this to ask that?
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
