Rotors Moaning Bad
Rotors Moaning Bad
Like a lot of you I installed the rotorpros drilled/slotted rotors over 2 months ago with Hawk pads but after more then 4K miles my rotors are still making a loud moaning noice when I hit them hard. It even sends vibration up through the steering wheel its so bad. I have asked Rotorpros about it and they said that I should have installed my rotors with the slots like this /. I installed them the other way like this \. I read many threads saying that it did not matter which direction to go before I installed and only installed them the way I did based on a thread saying it cooled better. I will try and reverse the direction of my rotors but I don't know if that will help and the fact that I probably have a wear pattern on my brakes by now doesn't help. I don't know what to do except possibly going back to OEM.
Anybody having the same problem any ideas?
I have about 4000 miles on my new brake setup and any loud noise is gone, but under heavy braking I do have a slight moan, my brother described it as a turbine effect, mine are pointed \
As for any vibration in the wheel, you might want to get your tires balanced, and changing the direction of the rotors, from what I read and asked of people with cross drilled/slotted rotors they are not quiet like blanks, the noise is created by the air between the pads
regarding the subject, i also bought these but havent had a chance to isntall them. i plan on it when summer school is done. what is the correct way? slots / or like \ ? what is the correct way, not the cool way? lol
Yes I did and I was really easy on them for the first 500 miles. The majority of the pictures and threads I have read have them going like this /. But there are threads that have them going the other way like mine and have no problems.
I will turn the front rotors around this weekend and see what happens.
If anyone is going to get the Brembo blanks make sure and paint them or get them zinc coated. I had a set on my max and they rusted after the first rainstorm. But now im on drilled rotorpros all around with no probs.
Hawk pads have known to be loud. I dont think its your rotors, I suspect your pads. I have the rotorpros and EBC. After about 4k miles it makes a hum only on intense highway or street braking. You will have to understand that you will not get the OEM smoothness with the performance pads and the drilled/slotted rotors. If you want soft/smooth braking get blanks and some regular non-ceramic pads. There is always a trade off.
the way the slot is pointing will only help with braking vibration. my suggestion is do what the manufacturer says and put them on right. doing that you might find other problems which could solve the humming. new pads will usually hum with new rotors if they weren't turned prior to using. I think you should take them off and take them to a shop that turns rotors and have them turned. Put them back on and they should work and sound better. if they are still too loud just get rid of the rotors for only slotted not drilled and you will notice a huge difference in sound.
I tend to watch the high performance shows on TV and I noticed the other day they had slotted and drilled rotors already mounted on this frame with no body or tires to block the view and what I noticed is all of their slots were facing / toward the front.
Plus I believe it was Deus or Chern that posted a link to a website that pretty much explained this as being the correct way to mount your rotors. I just bought the drilled and dimpled rotors and tyhe EBC Red pads so i am hoping that I don't have a lot of braking noise but then again it can't be any worse than my brakes now that are squeeling.
+1 on that. I had the rotorpro / EBC red setup and regardless of what others have said, they were noisy from the time I put them on until I ripped them off 3 weeks later. If anyone is interested I have the whole setup front rotors and brakes in the garage. 50 bux.
I have blanks on there now with Hawk HPS and they're good but the rotors still warp after 5000 miles. Never had this problem with any car i've owned besides the Max.
I think everything from the suspension down on these cars is an issue. I've had my car in multiple times 10+ for these issues.
Did switch the rotors around this weekend and there was a difference in the sound. The vibration is gone and the sound is not as loud but it is still there. I will give it another 2K miles and see what happens.
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
Andy29
Sep 29, 2015 05:32 AM
