Rear Camber Arms?
Old Sep 27, 2008 | 02:01 PM
mynameispee's Avatar
Rear Camber Arms?
I just installed a set of D2 Coilovers and now my camber is out of whack. According to courtesyparts.com the 350z rear camber arm has the same part number as the rear camber arm for our maximas. Would i be correct to be assume that the rear camber arm kits for the 350z fit our maximas? has anyone tried? i'm checking out a set of rear camber arms from spl. they're pretty
Old Sep 27, 2008 | 09:14 PM
sloonz's Avatar
Great question. I'd like to know too because I just had my car aligned yesterday and the tech couldn't do anything with the rear. It's way out. The front is at the max spec. and could use a camber kit as well. This is on Progress springs.
Old Sep 27, 2008 | 10:46 PM
eK9aT10pSi's Avatar
id wouldnt be surprised if the z's concentric bolts for the rear would swap out for ours. same concept as the front.
Old Sep 27, 2008 | 11:54 PM
jsmithsole's Avatar
*moderator*
I just had my car up on the lift and my rears are maxed out, my mechanic is going to look into seeing if there a camber kit or if he can find one that will work. I'll have him look into that...
Old Sep 28, 2008 | 06:40 AM
i e-mailed spl, hopefully they're be able to verify if not i'll probably take the dive and make the purchase with my fingers crossed!
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
bbsitum
Sep 11, 2015 04:55 PM
