Tire Pressure!!
Old 10-06-2008, 01:16 PM
BETO6700's Avatar
Tire Pressure!!
What's the proper tire pressure on stock 18's?
BETO6700 is offline
Old 10-06-2008, 01:56 PM
MAXIN' ON
redls1's Avatar
http://www.tirerack.com/tires/Spec.j...um%3D445VR8RSA
Max presure is 44 psi. Everybody has their preference. I think 32 psi is what the dealer installs at.
redls1 is offline
Old 10-06-2008, 02:16 PM
Tommy Di Cat's Avatar
It should be on the sticker of your driver's b pillar for stock 17 and 18 psi.
Tommy Di Cat is offline
Old 10-06-2008, 02:23 PM
AEMAXIMA01's Avatar
maybe if you want really bad gas mileage. i wouldn't put less than 32 in them.
AEMAXIMA01 is offline
Old 10-06-2008, 02:33 PM
eK9aT10pSi's Avatar
i have mine at 34 psi.
eK9aT10pSi is offline
Old 10-06-2008, 03:15 PM
"Ok,Whats next?!?!"
Fastmax05's Avatar
35 for me !
Fastmax05 is offline
Old 10-06-2008, 03:22 PM
Shoey1's Avatar
look under the armrest in the center console compartment there is a sticker. at least on mine there. is i think it says 32
17 PSI is WAAAAAY TO LOW. the inside of your tires probably have rubber shavings all over from the side walls shedding under cornering from tire stretching and what not
Shoey1 is offline
Old 10-06-2008, 03:30 PM
Sorry I meant stock 17 inch and 18 inch psi# is label there.
Old 10-06-2008, 06:13 PM
Terrentius's Avatar
32psi, dude.
Terrentius is offline
Old 10-06-2008, 07:31 PM
Nations 1st 6th Gen Turbo
chernmax's Avatar
My recomended tire presure sticker is located on my center console glovebox!!!
chernmax is offline
Old 10-06-2008, 09:44 PM
Newbie
orlan85's Avatar
32 psi for me to.
orlan85 is offline
Old 10-06-2008, 10:21 PM
SuPeRmOd
NismoMax80's Avatar
lol at dude saying 17 and 18 referring to the 2 wheel sizes and everyone thinking he meant psi
like everyone stated, it's on the console, plus the manual. that temp is cold (in the the morning before driven)
NismoMax80 is offline
Old 10-08-2008, 03:16 PM
BETO6700's Avatar
I looked inside the console and for 17's is 33, but nothing for 18's. Thanks guys I guess i'll leave them with 33
BETO6700 is offline
Old 10-08-2008, 06:07 PM
blaxima06's Avatar
i have mine between 32-34 PSI...
blaxima06 is offline
Old 10-08-2008, 06:39 PM
DeusExMaxima's Avatar
Oh no!! Not another tire pressure thread!!! Which is worse, octane threads or tire pressure threads?? My tire pressure is 40 because I like it like that and the tires wear nicely at that level and you get better mileage . . oh and you get better handling . . . . . oh and ur steering is slightly lighter.
DeusExMaxima is offline
Old 10-08-2008, 11:42 PM
SmokeNismo's Avatar
Yours handles better at 40 than 32? hmm not for me, but whatever works for you i guess. I do agree with you about the lighter feel and gas mileage. but I'd rather have it more sticky.
SmokeNismo is offline
Old 10-09-2008, 01:07 AM
SilverMax_04's Avatar
Warning: You are likely to wear the tread on you tires much faster in the center than on the sides of the tread.
In my discussion, all tire pressure readings are made after the car has been sitting for at least 12 hours -- thus the tires are considered "cold." I ran my tires at 36-37 psi for about 7 K miles. At that point, the center tread then showed substantially higher wear than the sides of the tread. I went back to 32 psi, but the damage had already been done to all 4 tires. I ended up replacing my tires about 4 months and 5 K miles earlier than would likely have been the case had I stayed with the Nissan recommended pressure of 32 psi.
I now watch the pressure and keep them all between 31 and 33 psi -- with a goal of 32.
I watched the gas mileage when running the higher tire pressure, but did not see much if any improvement.
SilverMax_04 is offline
Old 10-09-2008, 01:45 AM
As I indicated, my tires wear very evenly at 40 psi. In fact, in competition, I pump em up to 45 in front and 42 in back and goodbye understeer!!!
Old 10-09-2008, 09:56 AM
airMaxSL's Avatar
i put 32-34 on mine.
airMaxSL is offline
Old 10-09-2008, 12:12 PM
STARR's Avatar
I usually keep, 32-34 in all for corners checked cold, during the summer months with 32 in the tires the heat increases the pressure up to 38psi so just keep in mind what kind of driving you do
STARR is offline
Old 10-09-2008, 12:19 PM
Agree. Depending on the outside temp, the actual tire pressure after 1 hour of highway driving will easily be 38 to 40 psi. This is why it is so important to measure the pressure when the tire is cold. I have to drive about 2 miles to get to the closest (free) air compressor. By then, the 32 psi has already increased to 34-35 psi. So I determine, when the tire is cold, how much air I need, and then add that when I get to the compressor.
Old 10-09-2008, 01:04 PM
V_Drift's Avatar
32 seems too less for me..
I have mine with 34
V_Drift is offline
Old 10-09-2008, 01:27 PM
SmokeNismo's Avatar
Yeah you're running different suspension and tire width specs from factory, so the factory psi recommendation doesnt apply to you anymore. It's whatever you're comfortable with.
Old 10-09-2008, 07:23 PM
Even with stock suspension and tires, Id still pump them up to not less than 35 and probably more like 37-38.
Old 10-10-2008, 02:33 PM
cklamer's Avatar
Look inside of your drivers door there is a label for tire pressure.
cklamer is offline
Old 10-21-2008, 01:49 PM
largepkg25's Avatar
OK, check this out. I had my oil changed Saturday and spoke to the owner (an ASE mechanic) about uneven wear on my front tires. I figured I needed an alignment which they offer but he told me that the issue I was having was due to under inflated tires. My front tires wear a bit faster on the outsides but only the outsides. It's not even or a sloped wear pattern. I was positive he would sell me on the alignment which I thought I needed anyway but he told me it wasn't an alignment issue. He bumped the tire pressure to 40psi and said that should take care of the issue. I have 25K on the tires now and they're in damn good shape. Also, the car seems to drive better at the higher psi. I was running at 32-34psi.
Does this sound right to you guys?
largepkg25 is offline
Old 10-21-2008, 06:32 PM
That is possible, but I doubt it. Nissan goes to some care selecting the correct cold tire pressure for the tires on their cars. This pressure should give correct tire wear (across the whole tread of the tire) for most drivers.
I suspect (not having seen your tires -- but only what you have written) that what you are seeing is likely a combination of slightly out of allignment wheels along with the wear that comes from cornering fast.
You don't say what the wear has been on your rear tires -- or when you last rotated tires from front to back. That, too, can have an impact on tire wear.
But if you can run your tires at 40 PSI cold and not wear the center of the tread much faster than the sides of the tread, you certainly should get better gas mileage than those of us who need to stay between 32 and 34 PSI to get proper tire wear.
Old 10-22-2008, 06:38 AM
largepkg25's Avatar
Rear tire wear seems completely normal. I've rotated twice since purchasing the car 25k ago. I drive fairly conservatively day to day, but on the weekends a play a bit. I'll keep a close eye on center tire wear with the inflated pressure. I definitely notice a difference in handling especially with the steering. It's obviously a tad more sensitive but nothing crazy.
Old 10-22-2008, 10:44 AM
You should be rotating tires on your Max at least every 10 K miles -- and every 5 to 7.5 K miles would be even better. I roatate my tires every time I change motor oil -- which was every 7.5 K miles until the extended warrenty expired. It is now every 10 K miles.
With tire rotation, it is often harder to notice that there is a mis-allignment of your wheels. I did not catch that my rear wheels were out of allignment until it was too late -- there were cups worn in the tread of the original tires that were there until I replaced them. If you have not had the wheels alligned in 25 K miles, I would recommend that you get an allignment -- at a place with the most modern allignment equipment. (Here in Colorado Springs my dealer has this equipment, so I go there.)
Old 10-22-2008, 12:23 PM
largepkg25's Avatar
Um...I said I rotated them twice in 25k. Each at 10k.
I noticed the slight outside wearing at the first rotation. When the rears that I brought to front starting showing it was when I spoke to the mechanic. Again, it's only the front that are wearing this way. It's so slight that I'm going to see how the suggested 40 psi works. I have plenty of life left in them.
Old 10-22-2008, 04:37 PM
08MaxCash's Avatar
i keep mine at 34 psi
08MaxCash is offline
Old 10-22-2008, 05:47 PM
maktro's Avatar
...anything in the mid 30's is good....have to check around winter time also, because they tend to get low when it gets cold....temp goes down, air pressure tends to follow.
maktro is offline
Miket2006
03-01-2021 03:55 AM
06-06-2017 02:01 PM
Fbana41
08-29-2016 12:18 PM
Quick Reply: Tire Pressure!!
