New shift light install
Old Oct 6, 2008 | 08:39 PM
myer84's Avatar
Hey everyone,
I finally finished installing my last mod. For a while I’ve been searching for a shift light indicator, but nothing as big as a Monster Tach or anything that would make the car look ricey. My idea of a shift light was something that would be small and inconspicuous.
I came across a shift light module from Raptor Performance that allows you to connect a single L.E.D or more. The module is small and can be hidden under the dash and the L.E.D or L.E.D’s can be mounted anywhere in the car. With this module you can have a shift light that is not noticeable and does not take up any space or block your view like a monster tach.
I spoke to Rick from Raptor Performance and told me that he can give us all a discount if any of us would be interested on the module. The cost of the module is $105, but if there are 10 buyers the price drops to $90. If 15 or more buy, shipping will be free. Shipping is $7 anywhere in the states. If you are interested visit http://raptorperformance.com/products/RPM_Switch.htmor email Rick at sales@raptorperformance.comand tell him you are a member of the forum.
Here are the instructions on how to install the shift light. Total install time was 1 hour and quite simple.
Old Oct 6, 2008 | 08:46 PM
myer84's Avatar
The green wire connects to the tach signal. In our cars this can be found at any ignition coil. Each coil has three wires running to them. Each coil has a red and black wire and the third wire is of a solid color with a stripe. Below is the color configuration for each coil
(coil driver #1)----->Brown/Red stripe
(coil driver #3)----->Blue/Red stripe
(coil driver #5)----->Pink/White stripe
(coil driver #2)----->Green/Red stripe
(coil driver #4)----->Grey
(coil driver #6)----->Grey/Red stripe
In my install I went with coil # 6
I tapped the Grey/Red wire with a 22 AWG wire tap and ran a 22 AWG wire into the cabin.
Old Oct 6, 2008 | 08:48 PM
myer84's Avatar
Once I finish running the other end of the wire through the firewall, the next step was to find a 12 volt source and ground. For my 12 volt source I choose the fuse for the rear power sockets
In order to use that same fuse I added a fuse tap
Old Oct 6, 2008 | 08:51 PM
myer84's Avatar
The tap has two slots to add fuses. One slot is used for the original fuse to work with the rear power sockets and the other is used for my new 12 volt source (tack module).
Next step was to find a good grounding point
Now with the ground, 12 volt source, and tach signal connected we can now tap these wires into the harness that comes with the module. The harness has a green, red, and black wire. Green is for the tach signal and of course red for 12 volt and black for ground. The L.E.D ground will connect to the Normal Open Contact (see below ).
Old Oct 6, 2008 | 08:52 PM
myer84's Avatar
I decided to install a switch so that I can turn on and off the module. I mounted the switch on the bottom of the panel below next to where the courtesy bulb connects. The 12 volt source from the fuse box connects to the switch and from the switch to the module.
The next step is to find a spot where you want to mount your L.E.D’s. The spot I chose was on the bezel that surrounds the odometer and tach. To connect the L.E.D’s you can connect the + wire to the 12 volt tap we are using for the module and the ground you will need to connect on the Normal Open Contact.
Old Oct 6, 2008 | 08:55 PM
myer84's Avatar
Now that we have all of this installed we can now adjust the dial on the module to your desire settings. In my case I wanted the module to send the signal to the L.E.D's when the RPM would hit 6,100k. At 6,100K the L.E.D should light up and give me enough time to react and shift before redline.
To do this I set the RPM X 1000 at 6 and the RPM X100 at 1. This gives me a dial of 6,100 RPM. If you want to do 6,500 you would set RPM X 1000 at 6 and RPM X100 at 5.
Since we are only using one coil lead in our install you will only leave the cylinder setting at 1 on the dial.
You will notice that there is a small toggle switch on the module. This switch was installed on the module in order to read a low volt signal from the coil.
Old Oct 6, 2008 | 08:56 PM
AZombiePENGUIN's Avatar
i saw the end product on the link...looks bomb...kinda reminds me of the enzo's or any F1...the racepak looks pretty mean but i think thats more for serious track cars
Old Oct 6, 2008 | 08:57 PM
myer84's Avatar
Once you set your signal point on the module hook the harness to the module and turn on your ignition.
If the rpm switch isn't picking up a signal after you program it (noted by
rapid green LED flash), slide the small slide switch to the alternate position. Also, make sure your power switch is also on the “ON” position.
If the install was done correctly you will see the following
A: The status LED will turn yellow and will flash the number of times which is representative of the RPM X 1000 setting
B: There will be a pause for about two seconds (no status LED flash)
C: The status LED will turn red and will flash the number of time which is representative of the RPM X 100 setting
D: There will be another pause of two seconds (no status LED flash)
E: The status LED will turn orange and will flash the number of time which is representative of the “cylinder setting” (in our case 1), and finally the module will do an LED test (alternating red & yellow) and be ready for use.
Once this is done close you module with its cover and install anywhere under the dash. I installed mine with double sided tape. Clean up the mess and enjoy.
Here is a video of how it works on my car. BTW, I want to thank my other half for helping me record the vid.
Old Oct 6, 2008 | 09:20 PM
I VIK I's Avatar
Originally Posted by myer84
Now that we have all of this installed we can now adjust the dial on the module to your desire settings. In my case I wanted the module indicate when the RPM would hit 61,000. At 61K the L.E.D should light up and give me enough time to react and shift before redline.
Didnt know your car was capable of hitting 61K?
More like 6.1K
Good install tho, helpful on the 6 speeds, otherwise we'd be telling our autos when to shift.
Old Oct 6, 2008 | 09:24 PM
myer84's Avatar
More like 6.1K
LOL, let me make the corrections. Thanks for pointing that out
Old Oct 6, 2008 | 09:33 PM
JonBlz's Avatar
a.k.a. STuNtMAN
that looks hot
Old Oct 6, 2008 | 09:34 PM
orlan85's Avatar
Newbie
Nice detailed install. great pics too. To bad I can't use this install cuz I have a CVT.
Old Oct 6, 2008 | 10:20 PM
mynameispee's Avatar
much props to you sir, very innovated!
Old Oct 6, 2008 | 10:54 PM
whitem1ke88's Avatar
Glad you went thru with this even tho everyone did nothing but put you down. Turned out nice, kinda bright tho!
Old Oct 7, 2008 | 05:41 AM
myer84's Avatar
Thanks guys. I know some thought of this as a joke, but I wanted to do something different that no one had done before. I now a few of us go to the track and have 6MT. It's a nice feature to have if you want to keep your eyes on the road and not hit the redline.
This module also works with all Gens, so if you are interested email Rick at Raptor Performance for the hook up.
Old Oct 7, 2008 | 05:50 AM
anm6's Avatar
Grear job and wirte up. I like it alot. Sticky...
Old Oct 7, 2008 | 04:11 PM
Shoey1's Avatar
if i didnt know any better i would have thought that was a factory install from the finish quality but yeah those are bright. i wish i had a 6 speed
Old Oct 7, 2008 | 08:34 PM
Wantastic's Avatar
nice job
Old Oct 7, 2008 | 08:57 PM
maxboy325's Avatar
Super Clean install I may do this if Im bored one day but man they are BRIGHT
Old Oct 7, 2008 | 09:56 PM
myer84's Avatar
LED's are bright, but they are not emitting the light directly to your eyes at that location. The flash does not blind you. Camera on video was facing directly at the LED's
Old Oct 8, 2008 | 07:21 PM
STARR's Avatar
nice but does it have different settings, shifting at 6100rpm is gonna kill the gas mileage
Old Oct 8, 2008 | 08:01 PM
myer84's Avatar
You can change to any setting you want.
I'm not going to use the shift light all the time. I'm only using it at the track. Even if I keep the module on, it doesn't mean that I have to shift at 6100 RPM. I could shift at any point. The light just helps me shift before I redline when I'm at the track
Old Oct 8, 2008 | 08:50 PM
farzin1's Avatar
looks good. but i think is completly useless. its not worth it.
good job tho
Old Oct 8, 2008 | 09:37 PM
[TexMex]'s Avatar
nice job. i would do it..but i dont really take mine to the track or anything. yet..
Old Oct 8, 2008 | 09:39 PM
SEmy2K2go's Avatar
Go BUCKS!!!
good job tho
+1. Kinda annoying for a DD IMO.
Old Oct 8, 2008 | 10:02 PM
FrostMaxima's Avatar
looks really good, great install, it WILL be useful at the track.
Now for the haters...
-Yall are correct, this would be useless in an auto, this is a 6 speed.
-This would not be annoying in a DD, you can turn it OFF, hence the switch.
-How the F&*% would this kill gas mileage? Your not required to shift at that point all the time.
I much rather see a thread like this than... WOOO hear my Fujita.
The maxima community (esp. the 5th and 6th gen) never cease to amaze me with their ignorance!
Old Oct 8, 2008 | 10:15 PM
accordingtou's Avatar
VQ30 DE T
Nice write up / job
I was going to wire it to the dome light like a org member suggested but this looks much better. Two bright dummy lights ftw.lol
Old Oct 9, 2008 | 04:58 AM
myer84's Avatar
Thank you sir. Couldn't say it any better
Old Oct 9, 2008 | 09:14 AM
mist max2000's Avatar
very professional clean install .. nice job
Old Oct 9, 2008 | 10:43 AM
airMaxSL's Avatar
if i had a manual, i would def. do this mod. good work!
CorollaULEV
30
Aug 9, 2021 08:11 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Viralkill
Aug 16, 2015 05:09 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
