HELP with heater issue please.
Old Oct 28, 2008 | 06:34 AM
cobrar97's Avatar
I have an '04 SE. Obviously it has automatic climate control. Problem is...even after the engine is warm enough to produce hot air from the heater; when the car is at idle, it blows cool air. When you drive, it's hot as it should be.
For example: it's cold in Ohio this morning, so I start for to warm-up and melt frost on windshield. 15 minutes later, when I get into car, it's blowing cool air. When I start to drive it heats right up. Then when I stop for a train, after I'm sitting there about 3 minutes, it starts to get cool again.
Any ideas on what might be wrong or what I can do? Thanks!
Old Oct 28, 2008 | 09:03 AM
Lovemycar's Avatar
There's a TSB on this also a post already open
with the same issue we feel your pain easy fix just read
Old Oct 28, 2008 | 09:06 AM
cobrar97's Avatar
I just found it...thanks. I'll give it a shot.
Old Nov 3, 2008 | 09:11 AM
cobrar97's Avatar
Need some more idea. I did the Nissan TSB just like it said, but the car is still having the problem. If I give it any gas at all, it heats right up...just not at idle. After doing the TSB, I thought it was ok, but when I stopped to get gas, I let the car run, and sure enough, by the time I got back in, it was blowing cold again.
Any thoughts? Is it possible to do the TSB wrong? I was pretty straight-forward and easy to do. I even bought the actually bleeder funnel.
Old Nov 3, 2008 | 07:32 PM
po8pimp's Avatar
try what i posted to do in the other heating problems thread that is open.
Mar 12, 2020 12:06 AM
Excalibur23
Oct 13, 2015 04:33 PM
RWCreative
Sep 21, 2015 11:01 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
