Driving/Fog light Rewire with Stalk Control ** Write Up **
Old Nov 3, 2008 | 08:56 PM
BlackSpeed's Avatar
Driving/Fog light Rewire with Stalk Control ** Write Up DONE !!!!!!**
Guys, I am attempting to do Driving/Fog light rewire with stalk control. The key to this install is find the wire (negative ground) on the stalk that controls the lights. Here is the deal, the ground isn't active until the headlights are activated in returns provide the ground for the coil on the relay. The two positives on the relay are always hot. We can get past that by putting a relay on the stalk that activates ground when the driving/fog light switch on the stalk is activated. (Please beware that the lights will be on when the high beams are activated) I will be working on the stalk wire location after the Presidential Election. Here is what I have so far:
Relay Location
Next, the relay layout.
Old Nov 3, 2008 | 09:00 PM
BlackSpeed's Avatar
Almost forgot --> There will be a NO relay (ground as load) on the Stalk until the key is either switched to ACC or the on position. Lets work together to make this mod a Maxima.org original ...
Old Nov 3, 2008 | 09:13 PM
I VIK I's Avatar
Wait wait waittt a min, your saying you just figured out how to make the fog lights turn on without having the headlights on... with the original stalk?
Old Nov 3, 2008 | 09:14 PM
BlackSpeed's Avatar
Getting pretty darn close to it...
Old Nov 3, 2008 | 09:18 PM
I VIK I's Avatar
Hope this works, please keep us updated.
Old Nov 4, 2008 | 12:57 AM
kamski's Avatar
.org extraordinaire
Tap/Wire the fog positive into the rear light positive.
LIKE THIS
OR THIS WAY INTO THE PARKING LIGHTS
PROBLEM SOLVED
Old Nov 4, 2008 | 05:32 AM
BlackSpeed's Avatar
LIKE THIS
PROBLEM SOLVED
Your method would require the park lights to be on in order to control the driving/fogs. The new method would allow you to use the OEM switch without having the parks on..
Old Nov 4, 2008 | 05:50 AM
Kryogen's Avatar
well tell us if you find out, I am looking for something like this for the 04
Old Nov 4, 2008 | 07:31 AM
I VIK I's Avatar
LIKE THIS
PROBLEM SOLVED
+1
and I also heard that this wasnt gonna work for the 6th gens.
Old Nov 4, 2008 | 08:33 AM
jsmithsole's Avatar
*moderator*
Subscribed...
Old Nov 4, 2008 | 09:04 AM
m_turner_02's Avatar
subscribed...I will have to show some of the guys on the altima boards and see what they think
Old Nov 4, 2008 | 12:30 PM
BlackSpeed's Avatar
Here is a small outline of what has been and will be done:
1. Locate the Relay (Done)
2. Fab a 1/2 (Heat shrunk) wire extension from the relay to the original
socket (with female recept connected to the relay and male that plugs
into the original relay socket. The relay holder is soldered into the
board so you cant snip or tie a wire into the ground peg of the coil
(Done)
3. Find the two wires on the stalk that goes to/from light controller. Snip
those two wires and ground one. Connect the other to the negative
(Coil) of the relay that will be placed between the ground of the stalk
and main relay.
This is what will happen:
a. You turn the ignition on. The ground is closed going to the
main relay but not activated until you twist the stalk,
grounding the coil of the main relay which inturns
make the fogs pop on. In that moment, you will then clean
your pants after all the excitement that you will experience
for completing this project
I am soo close. If someone would like to assist by locating the two wires on the stalk, we could have this completed in no time..
Old Nov 4, 2008 | 12:39 PM
BlackSpeed's Avatar
For those that are worried about burning out the switch on the stalk, never fear -> the amps that pass through the stalk to the coil isnt enough to make a fly fart. You guys are probably wondering how a guy who flunked third grade four times come up with this cockamaimy idea --> I slept at a Holiday Inn last night.
Old Nov 4, 2008 | 12:45 PM
xoomer.com's Avatar
I Donate! Why Don't You?
I was wondering if you actually know the numbers required.
Old Nov 4, 2008 | 12:57 PM
BlackSpeed's Avatar
Nissan Specific, I dont know, but most mini relays that i have dealt with normally draw about .5 amps on the coil. Correct me if I am wrong..
Old Nov 4, 2008 | 12:59 PM
xoomer.com's Avatar
I was actually asking for numbers required to make a fly fart
Old Nov 4, 2008 | 05:04 PM
BlackSpeed's Avatar
Does anyone know if there is a ground that is activated when the ignition is switched? This would totally eliminate the need for a servo on the stalk..
Old Nov 4, 2008 | 05:15 PM
Ap0calyps3's Avatar
I wired mine to go on along with the parking lights. It doesnt look that bad.
Just my two cents.
Old Nov 4, 2008 | 06:23 PM
Kryogen's Avatar
I'll wire mine with the parking lights tomorrow too I guess, but stalk won't work anymore. Honestly I dont really care. What I hate is having the fogs turn off when I switch high beams on.
Anyone knows which colour of wire is the+12v to the parking lights ???? There are 3 and I dont know which one to cut. (one ground, one flasher and one parking light....)
Thx
Old Nov 4, 2008 | 07:00 PM
BlackSpeed's Avatar
Me personally, I like the fog only look. It's only my expression.
Old Nov 4, 2008 | 09:38 PM
Ap0calyps3's Avatar
Green Wire.
Old Nov 4, 2008 | 10:07 PM
kamski's Avatar
.org extraordinaire
Originally Posted by Ap0calyps3
Green Wire.
Or is it the blue wire? Last time we cut the green wire the building exploded!
I dont know Riggs, I dont know.
Old Nov 5, 2008 | 06:25 AM
Ap0calyps3's Avatar
Lol. As far as i know the green power has the juice. As for the building exploding....
Old Nov 5, 2008 | 02:33 PM
I VIK I's Avatar
So which one is the write up for the parkinglight to fog wire?
Old Nov 5, 2008 | 03:39 PM
KCMAXX's Avatar
KC's FINEST
I just ran a hidden switch.
I have other plans for the hot wires from the stalk.
Old Nov 5, 2008 | 03:54 PM
Kryogen's Avatar
Wheres the easiest place to cut that green wire ?
Old Nov 5, 2008 | 08:09 PM
xTeCaOx's Avatar
oh im soooooo subscribed ive been dieing to do this since i got my 6th gen maxima........ i had it done on my previous max which was a 5thgen
Old Nov 7, 2008 | 12:18 PM
MDeeze's Avatar
How do you wire the fogs to go on with the parking lights? The link above was for a 4th gen.
Old Nov 7, 2008 | 04:45 PM
Kryogen's Avatar
well I have an HID kit so there's already a relay, just take the +12v from parking lights to relay of the HID fogs.
For regular fogs, I dont know.
Old Nov 8, 2008 | 09:13 PM
BlackSpeed's Avatar
DONE Part 1 !!!
1. First, remove the three screws from underneath the steering column cover
2.Next, press the tab on the top and bottom of the stalk and pull towards the door
3.Remove the two screws from the stalk cover and lift the cover from the stalk
4. Snip the Blue and green wire (04 6th gen) and solder one wire that will reach the relay in the fuse box and another that will be grounded to the column (shown in second picture.
Old Nov 8, 2008 | 09:14 PM
BlackSpeed's Avatar
Done Part 2!!!
5. Next, you would stage your internal relay and attach wires as illustrated. I used a relay to only allow me to turn the fog/driving lights on while the key was switched to either the ACC or the on position due to the fact there is no alert to let you know if the lights are on if you turn the car off (drained battery)
6. Here is a picture of where the fog/driving lights relay is located in the fuse box under the hood.
I attached extensions that stretched from the relay to the relay holder. I did this because unlike the other generations, the fuse holder is soldered on the circuit board, not allowing you to tap into the wires.
Old Nov 8, 2008 | 09:15 PM
BlackSpeed's Avatar
Done Part 3!! Finally
The finished product !!!
(Note - I noticed a slight click sound in my speakers when switching the lights on and off. Not enough bother me though)
Good Luck !!!
Old Nov 9, 2008 | 09:57 AM
Playa_FL's Avatar
holy crap now i'm going to have to read over this several times and try and do it to my 6.5 Gen!
Old Nov 10, 2008 | 03:35 PM
Ap0calyps3's Avatar
Very nice write up, well done. I might do it when i get the ***** to open up my steering wheel column and stalk.
Old Nov 11, 2008 | 03:00 PM
eK9aT10pSi's Avatar
just a q on your relay setup,
for the blue & green wire, it doesnt matter which one you use for ground and power, right?
just cuorious, what does the blue & green wires do?
you are using a spst relay, correct? im used to using spdt relays [even though i sometimes dont use the the 87a, but oh well]
positive to fuse coil is 85
grounded to chasis is 87
grounded to stalk is 86
wire to driving light relay is 30
iirc, when 12v is applied between 85 & 86, it closes the circuit between 30 & 87, right?
so from my understanding of your thought process is that 86 is grounded so once you turn the key to acc or on, it sends 12v to 85 from the ________ fuse thus closing the circuit bewteen 30 and 87 to turn on the fogs?
sorry if this sounds redundant, i just like to understand the logistics so i can learn!
on another note, couldnt 85 be hooked up to the same the the headlights are wired to when no key is present to work the same way? that way, itll be independent like the headlights.
but again, thanks for your time for the write up, ive been meaning to do this for a while but didnt have time to read the fsm and figure out the wiring
Old Nov 12, 2008 | 07:24 AM
BlackSpeed's Avatar
Doesnt matter which one you use..
The blue and green wires are actually connected to the switch on the stalk. This closes the loop on the ground to the relay, which inturns activates the coil --> turning on the lights
This is also correct
YOu could in fact use your method. I chose to connect to the ACC/On fuse because I am getting old and feable. I just cant remember to turn the lights off everytime I exit the car. The original light system has dumb-proofed the possiblity of the lights draining the battery..
Buenos Suerte
Old Nov 26, 2008 | 12:59 PM
gtr_rider's Avatar
192.168.1.1
awesome, dont know why i didnt think of doing it this way.
Old Nov 26, 2008 | 01:02 PM
Very detailed. Good work.
Old Nov 28, 2008 | 06:31 PM
bdmaxima's Avatar
ehhhh electrical work....how i hate wires
nice work though. if i build up enough courage to do this myself i thank you for the write up.
Old Nov 29, 2008 | 06:37 AM
po8pimp's Avatar
the pop sound from your speakers sounds like you might have tapped the same acc for your stereo. that would create something like that. I would verify the radio acc wire and maybe go to another source for pwr to get rid of that. don't have wiring diagrams here at work so I will try and check later. Nice write up though will be doing this one because for the most part it sounds free and I like free mods.
