How do I tighten this clear plastic dash cover?
Old Dec 9, 2008 | 07:08 PM
hmr1979's Avatar
this thing makes a lot of noise on bumps, it has gotten way looser just last week. Any thoughts on how i can tighten it? thanks
http://img531.imageshack.us/my.php?i...8250223bg5.flv
Old Dec 9, 2008 | 07:37 PM
chris350's Avatar
simple way...maybe to stick something in between like a piece of paper...
worse comes to worse...glue...a little dap of krazy glue
or open it up...close it back up tighter....
Old Dec 9, 2008 | 09:07 PM
whitem1ke88's Avatar
Proper way: Open it up and secure it from the inside without making your modifications visible
Old Dec 9, 2008 | 09:42 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
For a quick temporary fix, cut small pieces of rubber type gasket material (like bicycle inner tube, none adhesive) and using a very small flat tip screw driver push the pieces into the seam at four points (top/bottom/left/right). Cut pieces small enough that once wedged inside they cannot be seen. Just my .02
Old Dec 10, 2008 | 06:42 AM
hmr1979's Avatar
Ill do these first. And it still makes noise, i will unscrew.
Old Dec 10, 2008 | 04:20 PM
KCMAXX's Avatar
KC's FINEST
Stick a picture of a loved one in there..?
I would steer clear of of taking apart the speedo. Needle trouble would not be worth it.
Old Dec 10, 2008 | 06:57 PM
chris350's Avatar
go here :
http://www.vqpower.com/v2/articles.php?article_id=118
follow instructions...see if you can place something in between the clear plastic and the gauge bezel.
hope that helps dude.
Old Dec 10, 2008 | 07:21 PM
hmr1979's Avatar
go here :
It does help a lot.
I Am hesitant to have to recalibrate my needles so I'll opt the other options for now. I Mean if i was changing my dash panel then it would be worth it, but not to correct this noise
thanks though
Old Dec 10, 2008 | 07:34 PM
IIvIIoNsTeR MaX's Avatar
+1 to Chern's idea
Old Dec 11, 2008 | 06:04 PM
chris350's Avatar
It does help a lot.
thanks though
well technically you dont have to do the guage swap thing. thats just to show you how to get at the clear plastic from both sides..not just the front....
but
+1 for Cerns idea also...
use the knowledge of how to open the dash and use cerns idea if you want a better fix....
Old Dec 11, 2008 | 06:26 PM
2theMaX05's Avatar
i agree with this
Old Dec 12, 2008 | 09:47 AM
CanadianMoFo's Avatar
Tiny dab of draft stop caulking, the kind that can be peeled off later.
Old Dec 12, 2008 | 03:28 PM
Y2k2maxse's Avatar
wasnt there a tsb on this? i remember seeing it somewhere..about an excessive amount of dust in the gauges because of that.
mvm062
Nov 30, 2020 09:00 AM
doctorpullit
Apr 23, 2017 05:35 AM
Kingofmaximas24
Nov 12, 2015 04:40 PM
carid
Sep 17, 2015 05:00 AM
thenewguyy
Sep 12, 2015 11:12 AM
