How do you disconnect the ABS actuator to bleed the brakes?
Old Mar 18, 2009 | 01:12 PM
Kryogen's Avatar
How do you disconnect the ABS actuator to bleed the brakes? It seems to be on the passenger side firewall but I dont see any easy connector to unplug and the access is really limited. Advice? I hate to unplug the battery cause you lose the memory seats and radio, etc.
Old Mar 18, 2009 | 01:30 PM
KCMAXX's Avatar
KC's FINEST
Call the dealership dolt.
Old Mar 18, 2009 | 03:20 PM
Kryogen's Avatar
Hey, here's a pic of KC at the lastest track event:
And him winning the comp:
Old Mar 18, 2009 | 04:26 PM
Shoey1's Avatar
you don't need to disconnect it to bleed them just have some one pump them up 5-10 times and hold the pedal down then you unscrew the bleeder screw to let out the fluid//air. repeat until all air is purged from system. also don't let the brake fluid resevior run down or it will suck more air in. if there is air in the ABS actuator...which there more then likely wont be unless you changed a brake line on it...it will get pushed out through on of the caliper bleeder screws but ti will take some time
bleed RR, LR, LF, RF in that order.
Old Mar 18, 2009 | 05:07 PM
KCMAXX's Avatar
KC's FINEST
See, you know what Google is...
Why can't you answer your own questions?
Great comeback BTW, I see you're still learning.
While we're at it, can we close the other 6 threads you've started about your fu©king brakes?
Old Mar 18, 2009 | 05:15 PM
Kryogen's Avatar
Old Mar 18, 2009 | 05:21 PM
KCMAXX's Avatar
KC's FINEST
LOL, I forgot you just found the internet...
Carry on.
Old Mar 20, 2010 | 06:36 AM
Phillypub's Avatar
how do I disconnect the actuator?
Old Mar 20, 2010 | 02:02 PM
STARR's Avatar
Why not just pay a shop to do it, it cost like 50 bucks including fluid and they can do it in their sleep, I could of swore I read Kryogen was a dentist, why are you working on your car
Old Mar 21, 2010 | 05:12 AM
lobewiper's Avatar
I don't know the history here between you guys and Kryogen, but I am here to tell you that I am sick of your childishness! It is a waste of time listening to your bullying and verbal abuse. K-man asks a simple question and you guys are all over him saying how stupid he was for asking it. What did he ever do to you guys that has led you to this continuing abuse?
Old Mar 21, 2010 | 11:26 AM
STARR's Avatar
Old Nov 22, 2024 | 12:59 PM
Arlene Reid's Avatar
easy way is disconnect ground cable
Old Nov 22, 2024 | 02:22 PM
Turbobink's Avatar
As was stated in the ‘other’ one of these:
Wow … just … wow.
Maximusdriver
Apr 12, 2016 09:32 AM
dynamicfigure
22
May 15, 2012 04:27 PM
Nismo
Jul 3, 2005 06:39 AM
MaXtUneD
Nov 2, 2004 09:24 AM
Jeff92se
Sep 6, 2001 10:14 AM
