Outside air only when AC or Heat is on..
Old Mar 25, 2009 | 07:13 PM
slick101's Avatar
Everytime I turn on the HEAT for now Since winter
I can only turn it on when the air is comin from outside...
Everytime I press the button for the air to circulate in the car... and try to turn the heater on... The AC button goes on as well...
I dont understand why
Is this normal?
Old Mar 25, 2009 | 07:28 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Is this normal?
Yes, just adjust the red/blue temp button for desired temp...
Old Mar 25, 2009 | 08:37 PM
Wantastic's Avatar
yeah they do that. nissan said that in car air circulate mode will turn a/c on to keep moist off the front window and so... blah blah blah. i think it's stupid.
Old Mar 25, 2009 | 08:40 PM
nsnrider's Avatar
blowing dry air on the windshield FTW
Old Mar 26, 2009 | 08:12 AM
mynameispee's Avatar
a/c turns on because it is also a de-humidifier which will keep your inside windows from fogging up.
Old Mar 26, 2009 | 08:52 AM
ChipperX's Avatar
The air conditioning (A/C) is activated as a default when the recirculation option is chosen in conjunction with heat. Nissan programmed the computer within the car to work in this fashion so that the automobile's interior windows would not fog, and thus obscure your vision. There will usually be more heat, humidity and moisture inside your automobile when there is no exterior air circulation. The heat and moisture will form a fog on your windows under most recirculating / heating conditions. The A/C will usually compensate for this effect by keeping the warm air from forming into fog-like water droplets on your car's interior windows.
Old Mar 26, 2009 | 09:21 AM
njmaxseltd's Avatar
Owners Manual - Usually always in the car, but never read.
Old Mar 26, 2009 | 09:57 AM
slick101's Avatar
Checked... doesnt answer my question..
Old Mar 26, 2009 | 09:58 AM
slick101's Avatar
Gottchya!
So which way should I run the heat then?.... With the AC mode on and circulation... or AC mode off... and air from outside?
Old Mar 26, 2009 | 10:24 AM
Lovemycar's Avatar
Gottchya!
It also comes on to keep the desired temp you selected at that temp if you have it set to Auto and change the temp to 65 the AC will come on
Old Feb 15, 2011 | 09:20 PM
alayanna's Avatar
how can u fashion it so that when u hit the button to recirculate, the a/c doesn't automatically turn on. i understand the reason behind it but i don't care. i can turn the a/c on when i'm good and ready
Old Feb 15, 2011 | 09:40 PM
Tommiekatt916's Avatar
Yea its normal, pissed me right off when I got my 08. I broke my right hand and had to use the auto heat cause I couldnt play with the heat. I would always have to turn the A/C. off .... Winter in upstate ny.... Umm dont need the A/C please its already 4 deg... if I want it Ill turn it on. Sorry the a/c always turning on is the BIGGEST annoyance of the max
Old Feb 16, 2011 | 09:23 PM
officerfrasher's Avatar
This drives me crazy as well. I should be able to make it do exactly what I want! Not what Nissan thinks is best.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
