Issue with Hazards
Old Mar 25, 2009 | 07:42 PM
Propa Teknique's Avatar
Issue with Hazards
I swapped out my 04 stock center console with an 06 console. Everything works perfectly but today the info screen said the trunk was ajar. I was on the interstate and had to stop. I tried putting on my hazard lights, NOTHING! I turned the car off then back on... STILL NOTHING! Anybody knows what can be wrong? I didnt mess with that part at all, I just took the plate off.
Any ideas?
Old Mar 26, 2009 | 10:23 AM
Someone's gotta know something!
Old Mar 26, 2009 | 02:18 PM
Lovemycar's Avatar
Did you unplug something maybe? did they work the day you installed the new center console? check fuses
Old Mar 26, 2009 | 03:14 PM
nyana107's Avatar
when you install the new center console did you unplug the battery? if no, unplug it and replug. if that's not the case. most likely it's the fuse
Old Mar 26, 2009 | 03:42 PM
jsmithsole's Avatar
*moderator*
Yeah double check that you plugged back in the wire that goes to the hazards on the shifter plate...
Old Mar 26, 2009 | 04:49 PM
Nope didnt unplug the battery... that maaaay be the issue... I'll check when it stops raining. It worked the day before I installed it.
Mar 12, 2020 12:06 AM
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
intimidator
Sep 5, 2015 07:23 PM
