Whistling noise
Old Mar 31, 2009 | 12:46 PM
6thGenSmoke's Avatar
Whistling noise
This morning driving to school i noticed a whistling noise at around 85 mph but i am not sure where it is coming from. This is the first time that I have heard it. Anyone one else experience this or know what it may be?
Old Mar 31, 2009 | 01:22 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
What y pipe do u have ..
Old Mar 31, 2009 | 01:27 PM
my car is all stock
Old Mar 31, 2009 | 02:25 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
no idea then... when i had my cattman y pipe .. i had a nice whistle.. it was teh flexs on the pipe itself
Old Mar 31, 2009 | 02:59 PM
Asav's Avatar
Check your dust cover. It may be loose or rubbing somewhere. Have you had any suspension work done recently? They may not have put it back on properly.
Old Mar 31, 2009 | 03:13 PM
Sarara's Avatar
Ohh dear.....I really hope your car is not over 50k-60k miles and you are now started experiencing timing chain tensioners crapp. Try to look around all four tires and belts first.
Nice car mate
Old Mar 31, 2009 | 03:27 PM
Longhorn101's Avatar
I have what I describe as a whistling noise. Mine occurs at ~30mph but seems to be more tied to the RPM at ~2000. I think it is something resonating on the engine or exhaust. I've tightened some of the heat shield bolts to fix it but it is still there. I've heard others say it might have something to do with a particular after-market grille. See if you can re-create it at a particular RPM or speed.
Old Mar 31, 2009 | 04:46 PM
Fiddy Yen's Avatar
its your turbo spooling
is it a constant whistling? regardless of RPM?
Old Mar 31, 2009 | 06:19 PM
haha...from what i heard it kept on whistling so i would let go of the accelerator to slow down so im really not sure how long it keeps going for at those speeds. i didn't really pay attention to RPM but i do know it starts around 85
Old Mar 31, 2009 | 07:59 PM
mynameispee's Avatar
whistling from a loose weatherstrip from one of the doors possibly? is it definitely coming from the engine compartment?
Old Mar 31, 2009 | 08:08 PM
im not really sure where it is coming from..couldn't really pin point it...i was trying but did not know where it was coming from.
Old Mar 31, 2009 | 08:37 PM
grab a passenger and ask them to help listen for the whistle. check windows and doors to make sure the weatherstripping is tight. if you find the whistling coming from a certain door, start taping off areas of the door/window to try to eliminate the whistle.
you could also try driving with the windows down to hear if its coming from the engine. one member mentioned the timing chain tensioners. it will sound much more like a whine that increases with the rpm. it is the secondary timing chain tensioner, there is a TSB.
Old Mar 31, 2009 | 08:47 PM
thanks for the suggestion...i will take a look at this
Old Mar 31, 2009 | 10:26 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
wtf? turbo?
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
