Unique Problem
Old Apr 2, 2009 | 02:54 PM
uavscrappy's Avatar
Unique Problem
Hey guys I think I have a unique problem with my Maxima and was seeing if anybody wanted to give me their input before I have it put up on the lift. At 2000 RPM and in drive, I get what I describe as a grinding sound or metal on metal sound on the right front side of the vehicle. It is pretty pronounced and only happens at 2000 RPM. If I go below or above that it stops. If the car is in neutral it does not make that sound either. I have yet to put it in reverse and get it up to 2000 RPM to see if it makes that sound as well lol.
Figured I would throw it out there and see what yall think or maybe this problem isn't as unique as I think it is.
Thanks in advanced
Scrappy.
Old Apr 2, 2009 | 03:35 PM
SmokinMaxSE's Avatar
SmokinMaxSE
Thanks in advanced
Scrappy.
If you rev it in neutral no sound? What about reverse? If thats the case then maybe a seized caliper?
Old Apr 2, 2009 | 03:51 PM
uavscrappy's Avatar
Yeah Neutral Nothing of a sort, and reverse though I haven't tried figured would be difficult to get it up to 2000 on the dot. I thought of the seized caliper but I mean it is so spot on the 2000 rpm mark that it didn't seem plausible.
Old Apr 2, 2009 | 04:34 PM
SmokinMaxSE
If you have it on a lift than can't you rev it and have someone look ? It's got to be something on that side. Maybe the trans. Does it jerk? I think one of the gears shifts at 2K. The belt is one side and I think its the passenger side.
Old Apr 2, 2009 | 05:01 PM
STARR's Avatar
either an exhaust rattle or loose heat shield rattling in the wind, anything wrong with the trans will not really make noise, it will result in weird shifting
Old Apr 2, 2009 | 06:06 PM
KCMAXX's Avatar
KC's FINEST
Theres an exhaust/heat shield flange thats known to break and cause noise.
Best bet is to go to a dealership/shop and take a look underneath.
Old Apr 3, 2009 | 04:45 AM
po8pimp's Avatar
if it is at a specific rpm than it could be a broken motor mount causing the engine to move at that specific rpm and rattle against something. Sounds are hard to diagnose over the internet without sound clips.
Old Apr 3, 2009 | 07:03 PM
uavscrappy's Avatar
Hey guys thanks for the inputs, I am planning on taking my car over to a trusted shop to have new struts, lowering springs and rotors replaced. With that I will most certainly ask them to check it out. I am praying it is something simple that just at that particular RPM that the heat shield rattles or something stupid. I just figured I would have thrown this out there since I have learned so much just browsing through. I will definitely update this post when I find out what the problem is.
Old Apr 25, 2009 | 06:49 AM
uavscrappy's Avatar
Okay so an update. Had the Struts replaced, Springs Replaced, all 4 rotors replaced. Sound still existed. Then found a hook-up at Discount Auto who is a Nissan Tech. He told me about this bracket that is under the catalytic converter that cracks and vibrates. Sound plausible but still just at a certain rpm? Went and had my alignment done and sure enough the bracket was completely broke on what side cracked on the other. Had it removed and first started driving off didn't hear the sound. But it has since returned. Things that I have noticed are that when I was on vacation for a week and came back the sound was gone for a while. Each time they had it on the lift and took it back down the sound disappeared for a bit but came back. I am really starting to wonder if it is a Transmission issue and just happens to be grinding at that particular gear. If anybody knows someone who has had this problem I really would appreciate some feedback.
Old Apr 27, 2009 | 05:37 AM
MadMax07SL's Avatar
I didn't see you say what specific year you've got. Since there's a couple different 6th gen cars, post the year might help people narrow down what you're up against.
Old Apr 27, 2009 | 08:48 AM
Domestic Violence's Avatar
This Space for Rent
p***enger
This Space for Rent
wow- cant say pa$$enger here
Old Apr 27, 2009 | 09:02 AM
nst6563's Avatar
I had a similar issue with a noise around a certain rpm range. What solved mine was replacing that broken bracket, as well as fixing the rattling heat-shield around the y-pipe.
Old Apr 27, 2009 | 09:59 AM
the macedonian's Avatar
you also can't say pa$$, had that issue on another thread bro...
Old Apr 27, 2009 | 12:55 PM
uavscrappy's Avatar
2005 was the year.
Old Apr 27, 2009 | 01:01 PM
SmokeNismo's Avatar
its not that unique of a problem. It's the infamous exhaust rattle. theres a TSB on it too. I'm having my broken bracket replaced in a few days ($200 from stealership). God only knows when It'll crack again, the thing looks so flimsy.
Did u just take the bracket off without replacing?
Old Apr 29, 2009 | 06:31 AM
05 Max 09's Avatar
I just bought my max a little over 2 months ago and i notice the same noise, so its the exhuast braket rattling?
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
