CATTMAN HEADERS iNSTALLED 'OH MYYYY'
Old Apr 29, 2009 | 07:23 PM
  #81
whitem1ke88's Avatar
QUESTION!
WHY do both o2's from the manifolds have to be extended behind the cat if only ONE was AFTER the pre-cat? The other sensor wouldn't know the difference since it was before the precat anyways, so why does it have to be extended?
Old Apr 29, 2009 | 08:24 PM
  #82
xorbitman's Avatar
What an awsome post and thread! ***** Five star! Excellent work and follow-up! Enjoy the sweet ride!
Old Apr 29, 2009 | 08:54 PM
  #83
Oolatec's Avatar
Originally Posted by whitem1ke88
QUESTION!
4 sensors total... 2 pre-cat and 2 before the stock y-pipe. With the removal of the cats in the headers, both rear sensors need to be extended.
Old Apr 30, 2009 | 04:47 PM
  #84
The Presence's Avatar
Oolatec, I understand completely that the green and blue colored
o2 sensor/wires need to be extended. But it looks like that isn't
necessary if you go the o2 Sims route. What's your opinion on
the o2 Sims? It really looks like great alternative to extending
wires so far back.
Old May 3, 2009 | 09:00 AM
  #85
Oolatec's Avatar
wires so far back.
Yeah... with a dual channel sim, you should be fine. I'm still working on getting mine functioning correctly. I think my first sim is bad... just haven't had the time to bring it to my guy so he can try the other one. But members have had success, so it does work.
Old May 4, 2009 | 10:31 AM
  #86
Nismo_max04's Avatar
def looking into getting new hearder and cleaning out the pre cat and EGR valve from seeing this thread.
Old May 5, 2009 | 03:39 PM
  #87
athlon omega's Avatar
Is is best to clean the EGR valve or just replace it when doing the headers? I'm wondering if doing so would clear the EGR code.
Old May 5, 2009 | 04:19 PM
  #88
I would recommend inspecting the part to begin with.
My mechanic suggested that I take the EGR valve apart
and thoroughly clean it first. Once it's taken apart you really
get an idea if it's shot or not. If you notice below the most
important part is the steel or metal with the spring on top.
That has to open and close so that it efficiently and completely
burn fuel by recirculating a portion of your exhaust and running
it through the combustion process again. Bad pre-cat particles
can jam it up pretty bad.
Old Nov 20, 2009 | 02:11 AM
  #89
redmaxpa007's Avatar
i SeE what you did therE
good stuff here... makes me want headers again
Old Dec 17, 2009 | 07:44 PM
  #90
Les7311's Avatar
Am game for this mod. Wish i was in Florida.... my brother would def take care of this and more.....
Old Dec 22, 2009 | 06:31 PM
  #91
DineroDave's Avatar
Looks good brother!
Old Jan 2, 2010 | 11:50 AM
  #92
bxsvx's Avatar
If only my Maxima wasn't on a lease
Old Jan 6, 2010 | 10:08 AM
  #93
whorufool's Avatar
good stuff
Old Jan 20, 2010 | 02:01 PM
  #94
EVESNAKE1's Avatar
is a tune necessary after headers?? I'm getting ready to install my hot shot headers this sat. and was wondering if a tune or re-flash needed? will my a/f ratio be safe?
Old Jan 20, 2010 | 11:25 PM
  #95
Oolatec's Avatar
Only necessary to get rid of any check engine lights you may get (not everyone has apparently), and to take full advantage of the performance gains.
I had mine installed last year, and have been driving around with my CEL since, and no problems. But a tune will be necessary in the near future so I can pass emissions.
Old Jan 21, 2010 | 06:03 AM
  #96
MaximusMorpheus's Avatar
ditto...
most of time they will run rich after installing Hotshot Headers so it would be wise to get a air fuel controller and tune it...the o2 sensors might break down more easily if run like that for a long time but you should be ok for a while...
I passed emissions without tuning so should be ok as long as the car is running fine and the code is cleared but tuning would be the best option..
Old Jan 21, 2010 | 10:07 AM
  #97
EVESNAKE1's Avatar
Thanks for the quick reply's fella's. Can't wait to install these headers.
Old Dec 12, 2011 | 03:08 PM
  #98
Stylez_Benji's Avatar
where can i buy them from?..i've been thinking about installing them on my 02
Old Dec 12, 2011 | 05:06 PM
  #99
mrjasonlyrics's Avatar
OK... I wasn't able to upload pics yesterday of the
Cattman Header install. So today I'm posting them
up. This is a project that I will never forget. Actually,
me and my mechanic had fun with the install.
Tons of pics below with more to come
Looking real good man. But doesn't it cause your car to fail emissions??? I might be wrong but I think there's three catalytic converters on the 6thgens and the aftermarket headers and y-pipe doesn't come with it,right???
Old Dec 12, 2011 | 05:21 PM
  #100
RAZ76's Avatar
Cattman makes two different y-pipes one with catalytic in it and one without.
Old Dec 12, 2011 | 05:37 PM
  #101
I called cattman and they y-pipes are pretty pricey shipped to Canada and he also said that I'd have to wait until they get about 10-12 orders before they produce a batch.
I mean i'm all down for the performance but buying a regular y-pipe for $500-600 then brokerage for 5-10hp just ain't worth it. I prefer to get the light wight fly wheel or the stage 1 clutch because the y-pipe without the catalytic converter will just cause my car to fail emissions and I don't intend to go through the hassle of buying it
Old Dec 12, 2011 | 05:39 PM
  #102
Maximus2010's Avatar
Old Dec 12, 2011 | 06:12 PM
  #103
Rods03Max619's Avatar
Your in Canada didnt know they have emissions up there, look at Racingline y-pipe they are a Canada Company....here you go....
http://racinglineperformance.com/sho...?idCategory=24
Old Dec 12, 2011 | 11:19 PM
  #104
Yeah. I mean the 6thgens are really good on emissions and if I remove them and install the aftermarket headers it will definitely fail.
I wanted the cattman y-pipe because of the catalytic converter. Racingline deosn't offer one with it. When I installed my catback the installer said the car might still pass without the y-pipe catalytic conver because there's two others.
He said the only thing I might have to worry about is there might be a change in sound. I probably might just go with the racingline y-pipe
Old Dec 13, 2011 | 11:17 PM
  #105
NiZMo1o1's Avatar
Reggie has been MIA for 2 years,
and we do not have emission in FL
Old Dec 14, 2011 | 06:09 PM
  #106
TAZ's Avatar
TAZ
A car with the (2) OEM precats or Racingline HFPC will still pass ALL emissions testing with a catless Ypipe. The only way you'll fail emissions with just a Ypipe is if your car has no precats
Old Dec 14, 2011 | 07:25 PM
  #107
DeusExMaxima's Avatar
will it pass emissions with no pre cats but with cat in y pipe?
Old Dec 14, 2011 | 08:36 PM
  #108
RAZ76's Avatar
Do you have any codes?
Old Dec 17, 2011 | 05:56 AM
  #109
smittybizzle's Avatar
Where can I get a cheap racingline y pipe ?
Old Dec 18, 2011 | 04:43 PM
  #110
TAZ's Avatar
TAZ
Depends on the Type of Cat and how hot it is. But generally speaking it "should" pass most tests
Old Dec 20, 2011 | 10:02 AM
  #111
seanhuang's Avatar
good work!!
is this gonna fit on the oz maxima!?
Old Dec 23, 2011 | 11:50 PM
  #112
Racingline.com
Old Feb 5, 2012 | 12:08 AM
  #113
kurt1's Avatar
I don't really understand. People are saying the the secondarys before the cat and some said after the cat. Witch one is it? The pics on this thread are after the cat.
Old Feb 5, 2012 | 02:44 AM
  #114
CMax03's Avatar
enjoy......
Old Feb 5, 2012 | 06:10 AM
  #115
I'll be joining the 6thgen headers install soon.
Old Jun 16, 2012 | 01:51 PM
  #116
Gibran's Avatar
Hell yea
Just got my self a part of does headers can wait to see the different of car sound and hp!
Old Jul 1, 2012 | 06:58 PM
  #117
raveen69's Avatar
Where did you get yours from? I'd like to order a set.
Old Jan 15, 2013 | 03:29 AM
  #118
MiaRaider81's Avatar
looks like I slipped by putting a new oem three way catalytic in my 04 max after my original one failed at 74,000 miles.
Old Mar 10, 2016 | 03:44 AM
  #119
maxxrussia's Avatar
Cattman vs racingline
Hey everyone! New to the group and had a question in regards to these Cattman headers!
Been looking at the RacingLine High Flow Cats! Are those a good buy and well worth the $500? Thanks in Advance! 6 Speed fun!!!
MaxLife17
Jun 27, 2019 01:37 PM
Maxboy23
Sep 4, 2015 06:04 PM
Samedi
Sep 3, 2015 01:07 PM
Johnny9595
Sep 3, 2015 05:18 AM
