How fast is your tranny to downshift?
Old Apr 3, 2009 | 05:25 PM
Kryogen's Avatar
Sometimes, when I floor the pedal, it takes a few seconds for the tranny to realize that I floored it and it just tries to rev a bit, and then it downshifts, and then it revs. Is a it a sign of a dying tranny or all max trannys are like that? I feel like its not responsive enough, like it lags a bit.
Old Apr 3, 2009 | 09:05 PM
SmokinMaxSE's Avatar
SmokinMaxSE
Flooring it never worked for me so I don't do it. Learn the gears and how it shifts and work with it. I use manual mode a lot since it lets you throw into manual mode and back to drive at any speed. Disconnect the battery for over an hour and then go floor it and see what happens. I think it learns your driving habit from the start.
Old Apr 3, 2009 | 09:30 PM
spmarfatia's Avatar
Tranny
Mine 4th generation does the same thing. Don't know what the problem is!
Sam
Old Apr 3, 2009 | 09:36 PM
Oolatec's Avatar
Any mods? Tuning would fix all of this.
Old Apr 3, 2009 | 11:31 PM
Ryaliu's Avatar
I encountered the same problem. I drive a 07 with cvt and i am becoming scared of future tranny failures.
Old Apr 4, 2009 | 08:20 AM
STARR's Avatar
How many threads you gonna start, I thought you mentioned several times your trans is on the way out, finish it off, drain the fluid out of it, store it in a bottle and drive the car, it's that simple, pour it back in after the trans blows up.
Old Apr 4, 2009 | 08:27 AM
Originally Posted by STARR
How many threads you gonna start, I thought you mentioned several times your trans is on the way out.
You mean like this 1?
http://forums.maxima.org/6th-generat...placement.html
Old Apr 4, 2009 | 08:38 AM
STARR's Avatar
nice
Old Apr 4, 2009 | 09:04 AM
40tounce's Avatar
Tranny
Thats what exactly happened to my 05. Found tranny fluid burnt. Took to dealer to change oil. Found shavings in the tranny oil. Tranny was on the way out. Lucky I had 400 miles left on my power trane warranty. Got it replaced and now I'm good hopefully for another 60,000 miles. B4 then I better get a new vehicle...
Old Apr 4, 2009 | 03:53 PM
Kryogen's Avatar
Fluid is dark with metal bits in it... ill call dealer again I guess.
Old Apr 4, 2009 | 06:49 PM
lobewiper's Avatar
Hey, Starr
Give the guy a break! His threads are way better than, "Here's some pics of my dirty Max..." or, "I spilled Coke in my cup holders, so what should I do?," or, "Today I drove over a toothpaste tube and now my tire tread is all white." (But, I admire your memory for the posts of others...)
Old Apr 4, 2009 | 08:23 PM
zuko's Avatar
the anti rice
drive by wire
don't floor the throttle all the way, noobs
Old Apr 4, 2009 | 08:59 PM
klemenz's Avatar
ease into it.
Old Apr 4, 2009 | 10:33 PM
bashali321's Avatar
My engine is too noisy at low speeds and hear kind of groaning soud, and when I quicky slow down from high speed then I can hear the noise while my tranny shifting gears which can clearly feel and hear, is it a sign of tranny failure??, new to this forum so my apologies if I am not so technical.
Old Apr 5, 2009 | 08:18 AM
STARR's Avatar
Originally Posted by lobewiper
Hey, Starr
I luv those threads
Old Apr 5, 2009 | 04:05 PM
KCMAXX's Avatar
KC's FINEST
I luv those threads
Im pretty sure Kryogen started those threads actually...
And 8 more on changing his own brakes.
Old Apr 5, 2009 | 04:16 PM
Old Apr 5, 2009 | 05:46 PM
Kryogen's Avatar
Thanks for the constructive comments and help KC, as usual, your posts are very revelant.
Old Apr 5, 2009 | 06:09 PM
lobewiper's Avatar
Children, it is now time to put all this to rest, forget about it, and get on with your so-called lives.
Old Apr 5, 2009 | 06:50 PM
KCMAXX's Avatar
KC's FINEST
I think you mean relevant.
Thanks for the sig...
Old Apr 5, 2009 | 07:09 PM
farzin1's Avatar
i think that how all automatics are. not just nissans but almost every car. cause my dad's 04 camry does the same thing and so does my boy's acura TL-S. thats why you shouldve got stick.
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
