Spolier Help Fast
Old Apr 9, 2009 | 01:30 PM
slick101's Avatar
Spolier Help Fast
05 maxima... with an 07 spoiler...
Everything is on... just need the wire connections... it seems not to work
Instructions say connect spoiler red wire to car red wire with think green stripe
and black wire from spoiler to black wire from car
HOWEVER
I have a red wire with thin BLUE NOT GREEN
And i have another PURPLE wire...
CONFUSED
HELP!!
Old Apr 9, 2009 | 01:45 PM
ddelaud's Avatar
red to red will be fine. and the black to black will be fine... purple wire? not so sure.
Old Apr 9, 2009 | 01:55 PM
jsmithsole's Avatar
*moderator*
Did you run it to the OEM 3rd brake light? Get a tester and test the wires. I would assume if you are at the 3rd brake light that the red would be power and purple ground?
I looked at the FSM (which I highly recommend you all do!) and couldn't find wiring for the 3rd brake light...
Old Apr 9, 2009 | 02:14 PM
bambino's Avatar
I did a write up a long time ago,
http://forums.maxima.org/6th-generat...write-ups.html
hope this helps
Old Apr 9, 2009 | 02:18 PM
slick101's Avatar
hope this helps
I still dont understand...
Especially the 3rd brake light
Old Apr 9, 2009 | 02:40 PM
bambino's Avatar
hmm, basically, you have to connect the spoiler cable to the 3rd brake light cable. Where is your cable right now? did you pass it though the trunk rubber tube?
Old Apr 9, 2009 | 03:17 PM
jsmithsole's Avatar
*moderator*
Seems pretty straight forward with that write up, thanks bambino, forgot about that!
Old Apr 9, 2009 | 05:18 PM
2LEET4U's Avatar
i just paid the stealership $40 to do it.... And i was able to keep my original top break light.
Old Apr 9, 2009 | 06:57 PM
jsmithsole's Avatar
*moderator*
I paid $50 but had them remove the top one, it was just to much with both for me...
Old Apr 9, 2009 | 11:30 PM
slick101's Avatar
I stopped looking at instructions and just thought logically... pretty simple...
Kept my 3rd brake light and connected the Spoiler wires to the left Tail light end of questions... works Better than ever
Old Apr 10, 2009 | 12:35 AM
jsmithsole's Avatar
*moderator*
Nice! Glad it worked out...
***Problem Solved, Thread Closed***
lrb6805
Sep 30, 2015 08:12 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
pears
Sep 18, 2015 05:25 AM
