Lone Pine Time Trials - 2009
Its that time of year. Some of you know that I race my car in the Lone Pine Time Trials. People are amazed that a 6th Gen Maxima can do so well. Its pretty funny actually. I have gotten as high as 3rd TTD (top time of day) in a field of about 50 drivers. Not too shabby for a 4 door car, eh?
This year i want TTD. I am seeking suggestions to make my car faster. Dont tell me to get a turbo or S/C. Im looking for weight savings and any other easy to do things.
Tires - I have thought about getting Falken Azenis tires:
http://www.vulcantire.com/azenis_rt615_t.htm
I have seen some slightly used ones for about 75-100 bucks each on fleabay. These are 200 wear rated tires which is slightly above the minimum DOT. They are supposed to be very gummy.
BTW, lighter tires can make a big difference in speed. Wider tires are heavier but they have more grip. Its a tradeoff. Bigger isnt necessarily better in tires.
Suspension - Rather than buy expensive coilovers, Ill set mine to full stiff - KYB adjustable rears, and Koni adjustable fronts. Coilovers also save some weight. U know of anyone who has coilovers for cheap?
Weight savings
carbon fiber hood - heavier but vented for engine cooling - about 32lbs
OR
OEM hood - lighter by 16 lbs but no vents.
Battery - braille battery weighs about 11 pounds which is 17 pounds lighter than my already lighter-than-OEM battery. I have 28 pound battery now. OEM is about 48 pounds.
Seats - remove passenger recaro seat - 45 lbs
remove rear seats - unknown weight but Im guessing 30 pounds?? Possibly install superlight fixed back seat just for race and save another 20 pounds??
Exhaust - There are no sound restrictions. Remove rear section of exhaust system?? about 15 pounds?
Body kit - Remove all or part of Stillen body kit plus my rear carbon diffuser? Maybe keep just the front lip to keep air from flowing underneath? I do hit speeds of up to 110 mph+ and most of it is around 80mph. Weight savings - 20 -25 pounds???
Drain windshield washer (1 gallon??) 8 pound savings.
My harness bar is 11 lbs but I need it for harness and it stiffens the chassis quite a bit.
Of course spare tire, jack tools are removed already and I would remove the rear trunk matt (10 lbs) and floor mats (5 lbs?)
I will run 1/2 tank of 91 and 100 octane mix. Anything less might cause fuel starvation.
So far I calculate these savings over what I have right now
OEM hood - 16lbs
Battery - 17 lbs
Passenger seat - 45 lbs
Rear seats - 30 lbs
Lightweight driver seat - 20 lbs
Rear section of exhaust - 15 lbs
Body kit and diffuser - 25 lbs
Windshield washer - 8 lbs
Trunk and floor mats - 15 lbs
Total weight savings:
about 191 pounds. Any other reasonable thoughts?
Weight savings
OR
OEM hood - 16lbs
Battery - 17 lbs
Rear seats - 30 lbs
OEM hood - lighter by 16 lbs but no vents. Good call! With the way you mod your car, I'd just get some vents put into the oem hood by a bodyshop.
Also....is NOS illegal in that kind of racing? Even a small shot might be enough to shave some time off on a straight away (and really tax those brakes coming into the corners!)
Hire a horse jockey to drive it!!!
Coilovers would shave on weight and improve handling and are adjustable in both height and stiffness.
Nitro in the tires is lighter than air. Less fluctuation when they heat up and cool down.
The event will be the last weekend of the month so I have time to prep.
Not sure about whether squeeze is legal but it makes me nervous. It would be nice down the straighaway for sure. Just not sure of the long term effect on the motor.
BTW, I found someone selling a carbon fiber braille battery, a B106c, which weighs SIX POUNDS!!! Selling it for $75.
Looking at possibly a Corbeau Forza seat which weighs 20 lbs for about $220. So for $300, I can save almost 50 pounds, with half of that hanging in the top front of the car (battery).
I would say keep:
-body kit (may add some down force at the high speeds, a reasonable trade off for it's light weight)
-Diffuser ( if you think you made it right and it is functional then it will reduce drag at the higher speeds)
- the exhaust, you don't want to risk loosing velocity and power by being to open. Plus the weight is low to the ground, which is better for your COG, albeit an extremely minor variance
Loose:
-MOST washer fluid, keep a little just incase
-interior seats
-trunk contents
-battery
-cf hood-not so much because of it weight, but because of how high the weight is
and good luck
Loose:
-interior seats
-trunk contents
-battery
and good luck
Great on long straight aways and heading towards the finish line.
Also Kevin007 had commented how his Kinetix intake works better with his NO2 and stock is when he doesnt use it.
Pull out the interior lining of the trunk, it's form fitted and held in place with plastic push pins or rivets, you can also remove the interior door panels, all except the drivers door, they weigh alot
I found some Falken Azenis RT615 size 255 40 18 for $300 plus tax including mount and balance. I want to find a lightweight seat that isnt too expensive. Im taking suggestions.
the guys i work with do circle track stuff rave about how awesome the falken azenis tires are. amazing grip and tread life. definitely get some. they also look mean just sitting still with the slick tread pattern
Good luck this year Deus!
I would say the interior door panels are inbetween 5-10lbs each, rear bench is about 30, rear seatbacks about 5 each. I'll go weigh the seats for you.
What about the Truax mortorsport Chasis brace? It'll add weight, but should outweigh that in better cornering.
I will probably pick up the carbon fiber Braille battery tomorrow. If i do, expect a write up on that.
Also, when I get the Azenis, Ill do a write up on those. I have heard nothing but raving reviews also on those tires but they just wear out fairly fast since they are not ur grandpa's all-season radial Sears tire, lol.
Thanks MaXXX!! Thats almost double what I thought they would weigh. I dont have the Truax chassis brace, so thats not an issue.
Well it would but I think I have enough bracing with the front strut brace and harness bar. Here is a vid from a couple years ago to refresh everyones memory:
http://s4.photobucket.com/albums/y12...t=DSCN0752.flv
And a pic:
And a pic:
I am in pretty good shape now, but i could prolly squeeze off 10 pounds. I have my original hood. I could have vents installed but i have no idea where to have that done or what they should look like. Ideas?
Last weekend of the month.
Here is a pdf formatted flyer of the event
http://members.quixnet.net/free2000/LonePineEntry09.pdf
Id recommend staying at the Dow Villa motel in "downtown" Lone Pine
BTW, here is a thread on an easy way to put in vents in an aluminum hood:
http://www.s2ki.com/forums/index.php...ic=324009&st=0
Got my Azenis RT615 tires today. Also got my Braille B106c carbon fiber battery that weighs only SIX pounds!!!! Its a little bigger than a latern battery, lol. Ill prolly do a separate write up on it. Now hunting around for a really lightweight (13-20lb) cheap racing bucket seat. It will only be used for racing so I dont wanna drop a ton of green on it.
rule of thumb is about 100lbs knocks off .1 on the 1/4 mile. Again that's an estimate. There are calculators out there that people swear by that have you put info in and get estimated 1/4 mile times. I will see if I can find it. I say lower pressure to about 28-30lbs in the front and 35lbs in the rear. Lower the front to distribute a little more weight to the front for better traction. raise up the rear if lowering the front isn't an option. Also there is a company that makes energy suspension components that would help out a ton. Let me see if I can find the link and see if I can get the calculator too. Do you have a sparco racing seat or equivelant? I think you will be amazed on the weight differents plus the luxury of having a 4 point harness. Also short throw shifter if you don't have one. Ohh and don't put donuts on the front tires like some idiots with front wheel drive try to do. That should be done only with rear wheel drive and only if it's needed. Ohh take the mirrors off and install to monitors inside the car and two cameras where the mirrors should be
use this to convert lbs to kg = http://www.convertunits.com/from/lbs/to/kg and input it in the calculator provided to see what your best time could be here = http://www.torquecars.com/tools/quarter-mile-time.php looks like for every 100lbs off gets you .13 sec off of your 1/4 mile
Variety of cars. Lately, there have been about 50 cars total. There are a variety of old school Hondas, there is an newer M3, Corvettes, Evos, STi's, karts, RX7s, BMWs, 350Zs, Sentra SE-Rs. It was a 1992 Sentra SE-R, that was race prepared that beat me last time.
Anyone know how to get the bumper reinforcement bar off the car and much they weigh? This would be the heavy metal part of the bumper. Also, can I put the bumper cover back on if I remove this bar?
Deus; You're the $hit, bud. Kick a$$ and takes names for us! It really does my heart good to hear about your accomplishments.
With regard to improvements: I don't really have anything to add, other than I don't think you should remove the armrest (you need to remain a bit comfortable) and PLEASE don't be tempted to add the "squeeze". I'm sure NOS would up your performance level, but I agree that it probably isn't worth it with regard to the long term effects it could possibly have on your engine. PLUS, adding a NOS system would add weight to your car - and cheapen your victory, in my opinion. ANYONE can add NOS. Your car is a farking CHAMPION, just as it is. Show the world, baby!
I took the cf hood and reweighed both hoods. The OEM hood is 21 pounds and the cf hood is 25 lbs. I thought the difference was more than that but its only 4 pounds. Ill put the oem hood on just cuz both are off now and its lighter and its easy to swap.
I found a fiberglass seat in my garage that weighs only 13 pounds. Ill get acover for that and fashion a bracket to mount it to the floor. That should save 30 pounds over my Recaro seat.
