Anyone here with new Eibach Springs installed since 2008 and having noise problems!
Old May 24, 2009 | 01:23 PM
xorbitman's Avatar
Eibach Springs Correct Installation and Timing Pictures
I have been having the same noise issues since I received my replacement Eibach springs...I had a broken spring about 1 month ago and had the dealeship replace all the top rubber and hardware....to no avail...The mechanic there noticed that the spring is not the same diameter as the stock ones...I'm thinking that maybe all of us here have an issue with Eibach....that the springs manufactured since 08 are wrong....I looked underneath with the wheel turned outside I noticed that the coils are rubbing near the top....if so then the springs are improperly rated and the noises we're hearing are the individual coils rubbing together near the top. If so Eibach better figure something out fast....cause we all did everything by the book here....except some of you may have over rotated the spring to match the indents in the top pad....it's the pad that needs to be rotated. Since so many here are having the same issue, I am inclined to believe that this is a manfacturing flaw...that either an engineer or the fab screwed up a new batch of springs. I need everyone here that has new springs that are having noises in the front end to chime in so that we can collectivley contact Eibach with this issue.
Once again: I turned the left wheel as far left as possible and was able to see all the way up the suspension well and I believe that I see the coils near the top rubbing together as if they are too compressed. If necessary, I can take a picture and post it here.
Old May 25, 2009 | 06:32 AM
xorbitman's Avatar
Hi Guys,
If no one here as noise problems with their modified suspensions...what did you guys do to eliminate the noise?
Rotating the spring about 1 fingers thickness away from the bottom was one suggestion.
Old May 25, 2009 | 12:35 PM
xorbitman's Avatar
Hi Guys, Happy Memorial Day week-end...I hope you all are enjoying your well deserved Holiday....God Bless America!
After spending some time at the dealer with a few mechanics, we noticed that the top two coils are firmly rubbing together which would explain the noises I am hearing. The springs are not supporting the weight of the car...this was not so with my previous springs...they never touched and if they did slightly I had that famous rubber hose to soften the bump! In fact the part number on spring does not match the part numbers on their web-site or the ones on my original box...this was a set of springs that were sent by the distributor located in Ontario...someone screwed up...I will be contacting Eibach tomorrow when everyone is back at work and asking some serious questions!
Looks like I will have to have a new set of replacement springs installed ASAP...hopefully by Wednesday. I will keep everyone posted.
Old May 25, 2009 | 03:57 PM
Staggered357's Avatar
definitely because that was the only complaint i have with my Eibachs...
Old May 26, 2009 | 12:55 PM
xorbitman's Avatar
Well so far Eibach has confirmed that the Springs are OK....Thursday we recheck (Dealership) the entire suspension set-up...It seems that everything now is pointing towards the bearing assembly and it's set-up...
Old May 28, 2009 | 09:32 PM
Playa_FL's Avatar
update?
Old May 29, 2009 | 12:47 AM
xorbitman's Avatar
The dealership took apart the entire suspension assembly on both sides and reinstalled everything according to Eibach's instructions. I'm happy to report that the car is now free of any noises and seems to handle a lot better. The ride seems more sure footed, smooth and sturdy too. From what I understood, the bearing assembly was not flush because the bearing timing was off. It is now centered and the weight is now evenly distributed around the bearing hub. The bearings were able to rotate freely 360 degrees before the suspension was reinstalled. It appears that my suspicions were ill founded. Eibach confirmed that the part numbers all match and that there are no issues with the QC on these parts....As these are progressive springs, the top coils are referred to as "dead coils" and as such are made to "stick" together. The issue was not at all an Eibach one but rather an installation issue by the dealership.
What a relief...at last the car is driving the way it should and the way it did for 3 years with this set-up and the whole thing did not cost me a cent as I had paid for the original repair two and half weeks ago (broken spring replacement). The dealership honored their commitment to warranty repair work. The alignment was also redone too.
All is well that ends well. I will keep a close eye on everything over the next few days.
Old May 29, 2009 | 10:53 AM
Playa_FL's Avatar
this is great, as i'm purchasing eibachs this year. i'll just have to make sure i put everything back exactly as i took it apart.
Old May 29, 2009 | 11:54 AM
coolmax05's Avatar
Eibach springs are "progressive" in nature and the springs actually are designed to touch each other depending on compression of the cars weight.
A very important aspect in getting the strut bearing to turn freely is the alignment of the "top hat" in relationship to the strut. Done properly the entire assembly will be flush and therefore decrease stress on the strut bearing. Which in turn reduce the likeiness of noises and other issues.
Congrats on the dealer doing the right thing.
Old May 29, 2009 | 12:14 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Great writeup and pictures!!!
Old May 29, 2009 | 12:51 PM
Apollos2's Avatar
I don't see any pictures? It's great the fixed you up with no $$ out of your pocket.
Old May 29, 2009 | 04:25 PM
xorbitman's Avatar
Pictures As Promised
Pictures as promised
Thanks for everyone's support!
Eibach Prokit 1
Broken Spring
Wrong Spring Seat Installation
Proper and Correct Spring Seat Installation
Correct Line up and timing of Spring: Notice gap at the end of the seat sill
Old May 29, 2009 | 07:19 PM
rick sambora's Avatar
Hi coolmax,
Great advice. Quick question though, does that apply to stock spring/strut combo as wheel? I recently got the stock setup installed and I went outside to check the orientation of the upper strut plate. The edge that has the hump and the "OUT" written on it is not in line with the lower part of the strut where the knuckle attaches. Recently my car has been having intermittent sway and wind noise. Could this be the cause of it?
Thanx
Rick
Old May 29, 2009 | 08:24 PM
coolmax05's Avatar
Originally Posted by rick sambora
Hi coolmax,
Thanx
Rick
Indeed it is a issue not having them aligned up properly. As far as the wind noise and sway, I can't say for sure.
Align them up properly and report back. Good luck!
Old May 31, 2009 | 03:44 PM
xorbitman's Avatar
Part 2:
Correct line up and timing of bottom spring seat: Notice gap and the end of the spring seat sill: THIS IS NORMAL & CORRECT.
KYB GR2
Ah YES! Slammed and Still Happy!
Old May 31, 2009 | 04:10 PM
ramberg's Avatar
GrandPa
Nice write up. I am going to call you during the week.
Old May 31, 2009 | 08:01 PM
xorbitman's Avatar
Hi Warren!
Thanks! Look forward to hearing from you this week!
Are you planning on going to Maxus? I would like to go however if I do it would be on the 27th...My daughter has her Prom on the 26th. Take care!
Old Jun 1, 2009 | 09:10 PM
xorbitman's Avatar
Moderator, Could you please change this thread's heading to: "Eibach Springs Correct Installation and Timing Pictures"
dank4us
34
Jun 10, 2024 03:45 AM
official_style
Aug 29, 2015 10:10 AM
Economic_Rage
Aug 20, 2015 08:27 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
