Fuel Filter
Old Jun 3, 2009 | 10:04 PM
ChrisD's Avatar
Fuel Filter
I know that Nissan does not sell a filter for our cars, they say it never needs to be changed, I disagree. So, I was thinking, they sell the filter for a 02/03. Has anyone tried to see if the 02/03 Max's filter will fit in our Max's? My 05 is about to hit 100k, I want to do this and change my plugs.
Old Jun 3, 2009 | 10:26 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
You disagree with Nissan and want to replace the fuel filter regardless???
Old Jun 3, 2009 | 10:29 PM
whiteSE's Avatar
im not sure, but i think you can put a 300zx fuel filter on you car.
Old Jun 3, 2009 | 11:02 PM
DEADBOLT's Avatar
Go ahead... try me
Call few dealers and ask. if they tell you the same thing, then don't mess with it. Don't attempt something that you'll regret later bro... be careful.
Old Jun 4, 2009 | 05:44 AM
MadMax07SL's Avatar
You could always replace the assembly underneath the back seat, fits right inside the gas tank from there.
It's called the "Fuel Level Sensor Unit, Fuel Filter and Fuel Pump assembly". I think it's around $3-$400 at best guess.
But I'd do the research first and find out why their filter doesn't need to be replaced.
It may "cleanse" itself while in the tank with each fill up, thus putting the contamination back into the tank.
Which means, you'd probably need to clean or replace the tank and the assembly to achieve a "fully clean" fuel system.
But chances are, unless you got bad gas or someone put rice inside,
you shouldn't need to do this as part of regular maintenance.
Old Jun 4, 2009 | 02:58 PM
ChrisD's Avatar
I own a 03 as well, and Nissan says they do not need to be replaced as well, but sell a filter for it. the filter is indide the pump inside the tank. i replaced that one, very easy job. That filter was only $13, well worth it! The 6th gen's are very similar. Just curios if anyone has tried this yet?
Old Jun 4, 2009 | 03:05 PM
DeusExMaxima's Avatar
I have my rear seats out. Now is the time to do it. Can the fuel screen or filter be cleaned?
Old Jun 4, 2009 | 03:20 PM
chernmax's Avatar
I've had my fuel assembly out to change the fuel pump (Walbro 255), cleaned the whole assembly which was surprisingly clean. Didn't note any filter per say to clean or change but anyway this is the 6th Gen assembly removed.
Fuel Pump
Fuel Pump assembly
New fuel pump installed in assembly
Location under rear seat to remove the fuel pump assembly
NO SMOKING!!!
Disconnect battery!!!
Old Jun 4, 2009 | 03:36 PM
ChrisD's Avatar
looks alot like my 03 did. You have the same car as me.
Old Jun 4, 2009 | 04:01 PM
DEADBOLT's Avatar
Go ahead... try me
What I don't understand is why would someone feel the need to change it every year when we can only use high-grade gas in our Max's anyway? I never used below 91 octane gas, and only use Chevron or Shell V-Power, which keeps the system clean anyway... why change the filter every year?
Old Jun 4, 2009 | 05:56 PM
addicted2pain's Avatar
Grade of gasoline is based on octane rating which is related to it's combustion properties. It has nothing to do with cleanliness. There is also supposed to be a filter in the gas station fuel pump.
Old Jun 4, 2009 | 09:16 PM
ChrisD's Avatar
I never said change my filter every year, my Max is about to hit 100k, and I want to change it.
Old Jun 5, 2009 | 02:27 AM
DEADBOLT's Avatar
Go ahead... try me
oh my bad... i don't know why I read it you replaced it every year in your old car lol... sorry, i just misread it.
Old Jun 5, 2009 | 04:12 AM
ramberg's Avatar
GrandPa
I have over 100,000 miles on my max and so far I see no reason to change the filter.
Old Apr 10, 2012 | 02:47 PM
equangvan's Avatar
hi guy i have 2006 maxima also wanted to try to change the fuel filter but the dealer say i do not need it until the pump go out . can any body tell the part number or where i can get one at thank you
Old Apr 10, 2012 | 06:23 PM
chernmax's Avatar
You should listen to the dealer, the filter is part of the pump!!! It's not a seperate filter that runs in-line with the fuel line like older cars!
Old Apr 10, 2012 | 07:06 PM
timpol's Avatar
And if you're that worried about it, you should really change the tank too.
Old Apr 11, 2012 | 03:41 PM
equangvan's Avatar
thank you for respond chernmax, my 06 maxima got 108000 miles it doesn't want to start up in the morning and runs rough. i took it to the local service mechanic he told me that it seem like there is not enough pressure in my fuel line meaning either the filter or the pump is going bad so make a long story short i try to see if i can clean the filter before change out the pump.
Old Apr 12, 2012 | 10:15 AM
Merlin5150III's Avatar
Would upgrading a fuel pump add performance other than also adding a turbo?
Fuel Pump
Fuel Pump assembly
NO SMOKING!!!
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
Justin Kroll
Oct 1, 2015 07:03 PM
