Hard Start-up
Old Jun 8, 2009 | 05:25 AM
andcolom13's Avatar
Hard Start-up
Got a question....
Lately (for the past 2 weeks) whenever I start up my 07 max after its been off for a couple off hours or overnight it seems to have a slightly rough time starting.
It always starts, but just seems to have a rough time doing so.... Other than that, if I've driven it and the engine is warm, its starts as normal...
Any suggestions? Thanks!
Old Jun 8, 2009 | 06:16 AM
po8pimp's Avatar
How cold is it in Jersey? What type of oil meaning 5w30, 10w30, etc. are you using? How many miles are on your car? Do you have a stock battery? Why are you using such big font? These are all important questions that we need answers to in order to help you figure this thing out.
Old Jun 8, 2009 | 11:14 AM
Cole_Schmitt's Avatar
Those are the most probably causes..
Old Jun 8, 2009 | 12:55 PM
Terrentius's Avatar
Originally Posted by andcolom13
Got a question....
I have an 07 and the same issue.....
Old Jun 8, 2009 | 01:06 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
maybe the starter is going
Old Jun 8, 2009 | 01:45 PM
andcolom13's Avatar
These are all good questions, my bad for leaving the info out.
1. FONT = I'm just crazy and went for it, no reason.
2. Jersey is not cold at all lately, lately its been around 65-90...
3. Max has 43K on her
4. Using stock battery
5. Using Mobil 1 5w 30 full synthetic
6. I should also add that just 5 weeks ago, I had the stealership do an oil change (this time i brought my own for about $40 cheaper from Walmart]). They also cleaned the fuel injectors and cleaned the battery too. I think they also flushed/replaced the transmission fluid....
THANKS again!!
Old Jun 8, 2009 | 02:04 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
you think they flushed the tranny fluid? hahah .. you better find out seeing how this car is known to having tranny probs .. even it you have CVT..
maybe its the STARTER??? hahaha h
Old Jun 8, 2009 | 03:12 PM
andcolom13's Avatar
Ok... My bad it was the power steering flush....not the tranny....
I just got home and looked at the invoice to make sure...
Old Jun 8, 2009 | 05:36 PM
Terrentius's Avatar
I have 45k on mine...
I use Valvoline Full Synthetic.
I put a brand new battery in last week hoping it was a battery issue. Not the case, for I have the same issue as Ancolom13.
Old Jun 8, 2009 | 09:37 PM
po8pimp's Avatar
I would go to the dealership and start up a couple maximas and see if they are starting similar, maybe it's normal what you are experiencing. Maybe the Stealership hooked you up so you would break down and come back. They need to stay in business you know.
Old Jun 8, 2009 | 10:05 PM
denbigh97's Avatar
Maybe corrosion on the battery terminals?
Old Jun 8, 2009 | 11:30 PM
I VIK I's Avatar
Try "Jumping the car, even tho it doesnt need one, If it starts fine then. That means its your battery going although it doesnt seem like battery. Check oil levels. 43K is too early for a starter but it does happen.
Old Jun 9, 2009 | 04:47 PM
Terrentius's Avatar
Yeah, I don't think it is the starter...she starts fine after the first one. Something is off - fire, air or fuel. It will probably have to go to the dealership to actually find out what the issue is. They need to hook it up to their computer and then fire it up. Then they will be able to pinpoint it.
Old Jun 9, 2009 | 05:08 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Any power train problems should still be covered by warranty???
Old Jun 9, 2009 | 05:27 PM
Terrentius's Avatar
I think so..we should be still under the power train warranty. I am thinking it is a sensor and the ECU is all mucked up trying to compensate.
Old Jun 10, 2009 | 01:43 PM
andcolom13's Avatar
I was going to bring it into the stealership tomorrow; but damn work got in the way....it will have to wait for another week or two......
Old Jun 10, 2009 | 02:27 PM
chernmax's Avatar
Battery is suspect but I would also Sea Foam that baby!!!
http://forums.maxima.org/6th-generat...ce-videos.html
Old Jun 10, 2009 | 05:27 PM
Lovemycar's Avatar
Is it turning over? but just not starting try giving it alittle gas
Old Jun 10, 2009 | 05:33 PM
MeSSiaHd's Avatar
It may be the cause of many problems. Battery, ignition coil, spark plug terminals, starter, etc. For your sake I hope your problem is only minor electrical, because if it isn't... Be ready to spend money on mechanical parts. Good luck!!
Old Jun 10, 2009 | 06:07 PM
andcolom13's Avatar
AWESOME videos!!! Did the in-cabin filter about 6K miles ago, but need to do the sea foam!! If I don't have the OBE2 code reader, the check engine light/codes will eventually go away, right? About how long after?
Thanks again!!
Old Jun 10, 2009 | 08:40 PM
po8pimp's Avatar
yes they will go away but you can go to autozone and ask them to clear the codes or you can drive it about 20 miles and then if you still have the cel disconnect the battery for a couple minutes then reconnect and it should be gone.
Old Jun 11, 2009 | 02:59 AM
andcolom13's Avatar
It starts up every time, just seems to have an extra <minor> strain whenever I start it up after its been off for a couple of hours or overnight....
Old Jun 11, 2009 | 03:00 AM
andcolom13's Avatar
thanks for the tip
Old Jun 11, 2009 | 06:10 AM
ubersl's Avatar
Used to have hard starts after the car was sitting for 1+ hours. Fuel pump was the problem.
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
jaydot901
Sep 29, 2015 01:18 PM
