Cornering lights not working
Old Jun 15, 2009 | 01:33 PM
ILL-Maxima's Avatar
So today i was messing around with my cornering light. I was gonna replace it with LED's 3156 bulbs but autolumination.com sent the wrong ones. they sent the 3157. Anyway while the cornering lights was on (lit up) i unplugged it from the socket, i know i know dumb thing to do . I think i might have blown a fuse because after plugging it back in, neither the left nor right cornering lights would light up when i put on my turn signal. Everything else is fine, the front and rear indicators come on, just the cornering bulbs are not lighting up
My question is, which fuse controls the cornering bulbs? I looked at the chart when i pop off the fuse box by the driver side door but it doesn't say anything about headlights, brake lights, or any other lights that would indicate which would controls the cornering lights. Do you guys know if it's the fuse box in the engine compartment has a fuse that controls this? I tried looking at that fuse box but the chart is completely white out. Any help would be appreciated, thanks.
Old Jun 15, 2009 | 03:21 PM
MaXXXpower's Avatar
name came from hairdryer
In the engine bay, next to windshield wiper fluid. Same a s fogs (pretty sure), bottom right corner.
Old Jun 15, 2009 | 04:45 PM
ILL-Maxima's Avatar
aight thanks man, i'm gonna take a look tomorrow and see if that's it.
Old Jun 15, 2009 | 05:09 PM
MaXXXpower's Avatar
I had this same discusion w/ autolumination last year, and they swear, the 3157 (dual circuit) bulbs work fine in a 3156 (single circuit) housing.
My advise is check your stock non led bulbs and compare the connection wires to the socket. then cover the extra wires on the led bulbs that arent used w/ electic tape. Test them out, see if they blow a fuse. If not, clip off the extra wires on the new led bulb (3157) and hope that it works.
Old Jun 16, 2009 | 05:44 PM
ILL-Maxima's Avatar
Maxxpower, thanks for the help man. it was right where you said it would be. Last blue15 fuse on the right. bought a new one and installed it and everything is working fine now.
Old Jun 16, 2009 | 05:49 PM
MaXXXpower's Avatar
Glad to help!
Old Jun 22, 2009 | 12:04 PM
smittybizzle's Avatar
Man MaXXpower thank you so much the one fuse you stated up top controls a lot thanks you saved me $105
Old Jun 28, 2009 | 03:05 PM
cfr94's Avatar
I'd like to change my cornering lights out too, let me know if you don't blow fuse after fuse. A while back, someone used LED's and it kept blowing their fuse. Also, your fuse might not be blown, but the bulb itself might be in backwards. Strange but true, some of those lights, even though they fit in both ways, only 'work' plugged in one way.
Old Jun 28, 2009 | 07:32 PM
ILL-Maxima's Avatar
it was the fuse. when i took it out i saw the thin strip in the fuse burnt out...
Old Jun 2, 2011 | 09:03 PM
bg1379's Avatar
I'm having the same issue, but the last blue 15 in my fuse box is for the heated seats. Do you remember what the fuse was called?
Thanks a lot.
Old Jun 2, 2011 | 09:33 PM
todd03blown's Avatar
I am new to this board but so nice to see others helping folks out!
Old Jun 3, 2011 | 10:04 AM
mrkhone's Avatar
had that happened to me last week. tried to install the led corners and blew a fuse. it also blew out my taillight. it should bee the taillight fuse.
Old Jun 4, 2011 | 09:32 AM
DAlastDON's Avatar
Thanks a lot.
15amp #41 in the IPDM on the passenger side under the hood.
Old Jun 7, 2011 | 09:35 AM
DeusExMaxima's Avatar
I have been having this same problem (cornering lights not working). Now my fogs dont work so Ill need to check the fuses mentioned here.
Old Aug 10, 2016 | 05:28 AM
arux's Avatar
Hi guys,
I'm looking for some cornering light right relay for cornering lamps.
I have situation that left cornering works ok but on right side i have only turn signal without cornering lamp.
all fuse are ok in ipdm
where i can find it? are the inside of ipdm? in instal schemat of ipdm looks like both are inside
jerrod99_se-l
Aug 27, 2015 08:27 PM
KristyKarina
Aug 23, 2015 09:53 AM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
