engine light
Old Jun 19, 2009 | 09:31 AM
avlk613's Avatar
engine light
my engine light is on its not flashing just a steady light i get a o2 sensor code but everything seems fine anyone has any ideas what it can be thanks
Old Jun 19, 2009 | 10:14 AM
RA121625's Avatar
Just cause everything "seems" fine, doesn't mean that it actually is. Try deleting the code and if it comes back then replace the sensor.
Old Jun 19, 2009 | 12:47 PM
addicted2pain's Avatar
Follow the link below for instructions on clearing the code if you do not have a code scanner. It is listed as being for the 350Z, but I have used it on my Max.
http://www.technosquareinc.com/350reset.htm
Old Jun 24, 2009 | 08:33 PM
avlk613's Avatar
engine light
thanks for your help i am going to try it
Old Jun 24, 2009 | 08:48 PM
Oolatec's Avatar
What's the actual code?
Old Jun 25, 2009 | 04:56 AM
avlk613's Avatar
what do you mean by what is tha actual code for what
Old Jun 25, 2009 | 08:07 AM
maximakid06's Avatar
What code did the scanner give you?
Old Jun 29, 2009 | 11:13 PM
avlk613's Avatar
it was for a sensor (oxygen) i thiink it was p230
Old Jun 30, 2009 | 06:21 AM
NmexMAX's Avatar
dot dot dot ...
That will reset it ... not give you the code. There are a few key steps at the end that are different for checking the actual code, vs resetting it.
IMO, the nomenclature for getting the code (counting blinks / using your elft arm, and your right pinky, etc. ) is a little bit on the complicated / hard to follow side, so using a code reader is far more convenient in this case.
Old Jun 30, 2009 | 07:44 AM
As I stated, this is for clearing the code to see if it comes back. The codes can be read for free at your nearest auto parts store which it sounds like was already done since he has the code. I for one would not want to waste the money for a code reader when you can get it done for free.
Old Jun 30, 2009 | 08:37 AM
Oolatec's Avatar
Go to AutoZone and they will scan it for you. I'm not sure P230 is the right code... let us know!
CorollaULEV
30
Aug 9, 2021 08:11 PM
magneto112
Sep 10, 2015 12:52 AM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
