Having electrical problems with cluster gauges , radio controls and console light
Old Jul 21, 2009 | 03:50 PM
ricky7780's Avatar
Ok heres the chain of events. My intterior light switch was starting to break and finally last night it fell off. Prior to that it was loose and when i would play with it , it would cause the little console light That turns on when u turn the headlamps on to go off for a second or two. When the switch finally fell off the little dim console light turned off as well as all the back lights to the stereo buttons, but the air conditioner backlights remain on. Also i cant adjusst the brightness on the cluster gauges ,it just stays on the bright setting. My auto headlamps sensor still works fine, i thought it may have something to do with it. I checked all the fuses in all three fuse boxes and i fixed my interior light switch and that works perfect now. All 3 settings on the switch work perfect. I am truly stumped. What could this be?
Old Jul 21, 2009 | 10:21 PM
ricky7780's Avatar
anyone?
Old Jul 22, 2009 | 06:27 AM
thealliance43's Avatar
its a fuse or your dimmer... i believe its your 15amp fuse though... passanger side fuse box.... to test that it is your fuse... turn on your headlights and try using the dimmer switch.... if nothing happens its your fuse.... good luck and keep me updated
Old Jul 22, 2009 | 09:36 PM
ricky7780's Avatar
Yeah when i turn my headlights on the lil dim console light dont come on and the backlights to the stereo controls dont come on. Also i cant control the brightness when my headlights r on. The brightness stays the same when the headlights r on and off. Ill check my fuses again but more info would be awesome. Thanks ppl
Old Jul 24, 2009 | 07:55 PM
grw624's Avatar
I am having the same problem with my 04. I did the 04 to 07 bumper, headlight and hood swap. This week I finished the wiring for the cornering lights (now in the headlight assembly) and fog lights (now in the bumper). I now lost my dimmer switch, the lights behind the stereo buttons and the auto headlight on/off feature. The gauge cluster stays bright all the time. Anyone have any ideas? I'll check my fuses again also.
Old Jul 24, 2009 | 08:08 PM
its your 15amp fuse on the passanger side... you blew your fuse... its happened to me a bunch of times
Old Jul 25, 2009 | 12:08 PM
grw624's Avatar
thealliance43, YOU ARE THE MAN! You're absolutely right. Blown 15 amp fuse, passenger side, under the hood. I think the diagram said Tail Lights. Go figure. Replaced it and everything works fine now. Did you ever figure out why yours kept blowing? Thanks for the help!
Old Jul 25, 2009 | 12:59 PM
glad i could help....mine kept blowing because i put leds in my cornering lights... another member who did the 08 conversion at my house wired both fogs together that were hids.... (he had the 05 headlights w. fogs and the 08 fogs together) they kept blowing his fuse... so maybe it is one of those problems... glad you fixed everything
Old Jul 25, 2009 | 01:34 PM
grw624's Avatar
Time will tell whether I start blowing fuses also. I shouldn't have any more problems because I don't think overloaded any circuit. I just had to switch the wiring on the fogs and the corners. But thanks again for the help. Members like you are what make this forum great!
Old Aug 17, 2009 | 06:54 AM
tonymarch64's Avatar
I couldn't find any other posts related to my question, so I figured I would use this one, since it's electrical-related:
I just bought a 2007 Maxima and I have a few issues. I wanted to see if this group might have any comments/solution before I bring it back to the dealer to get fixed (it is a certified pre-owned).
1) When I use the hands-free phone, I only hear the person on the other end out of my right front speaker. Should I hear them out of both front speakers?
2) Neither utility outlet worked when I got the car. I fixed the dashboard outlet by replacing the fuse, but I can't figure out what's wrong with the outlet in the center console. Which fuse circuit is that on?
3) Even though it's summer, I wanted to test the heated seats and steering wheel. It seemed like nothing happened when I turned on the driver seat heater, but when I turned it off and turned on the steering wheel heater, it seemed like my seat got hot. With the blown fuse above and this, I'm wondering if there is a bigger electrical problem. Any known issues with these systems in the '07 Max?
Thanks.
Old Aug 17, 2009 | 11:09 AM
brianfu777's Avatar
1) it's normal for the bluetooth to come out from right side only. I don't know why, but that's just the way it is.
vingodine
45
May 21, 2016 12:46 PM
Slamrod
Apr 10, 2016 05:24 PM
homeyclaus
Sep 3, 2015 06:15 PM
JMag90
Aug 25, 2015 09:17 AM
Samedi
Aug 13, 2015 04:05 PM
