Need Some Help
Old Jul 24, 2009 | 10:58 PM
Drewhos's Avatar
Need Some Help
I just traded my 2000 Max for a 2006 Max a week ago. I have already have an issue that I need some help with.
When I accelerate to about 2000 RPM's I can hear a sqeaking or grinding noise which I believe is coming from under the car. It only happens for a second and I cannot hear it any other time. It does not happen if I am in nuetral at all but only when I am moving.
Does anyone have any ideas what it can be? I would really appriciate any input I can get. I did not purchase any extra warranty because I feel it is a ripe off. Thanks!
Old Jul 24, 2009 | 11:37 PM
NiZMo1o1's Avatar
Could be the Flex pipe , a leak in it.
Could be Brakes ?
Need some more info like if it viberates maybe a vid ?
Old Jul 25, 2009 | 05:58 AM
Apollos2's Avatar
There is an exhaust bracket that breaks under the engine and will cause a rattling/vibrating kind of sound from about 2-2.5 rpm only during acceleration. Grinding / Squeaking are two different sounds to me.
Drive by a wall, or a straigh up curb and listen to it some more, give a little more description.
Old Jul 25, 2009 | 11:53 AM
04MAX_ILLIN's Avatar
Heat shield rattle??
Old Jul 26, 2009 | 07:05 AM
po8pimp's Avatar
could be the transmission too!!! But at RPM's and not in a specific gear then????
Old Jul 27, 2009 | 09:32 AM
Drewhos's Avatar
It is a sqealing noise kind of like when you get break dust.
I have been told by others as well that it is probably the exaust brakets. I found the service bulletin from Nissan. I guess I will take it in and get it checked out.
I just don't understand is why it only makes the noise at 2000 to 2500 RPM's while in gear. I guess that is why I'am not a mechanic.
Old Jul 27, 2009 | 09:59 AM
carlosr's Avatar
If you just purchased it then they should have to repair it, so take it back and stand firm. Does sound like a loose heat shield or broken exhaust bracket.
Old Jul 28, 2009 | 06:19 AM
VigilanteMax's Avatar
If you can imagine how sound travels and resonance, a certain frequency is obtained through your exhaust and at that certain RPM, you get the elusive heat shield rattle and/or bracket vibrating. Sounds like a banshee.
