Anybody know how to take apart driver info screen on 07?
Old Aug 12, 2009 | 03:27 PM
1hawaii50's Avatar
I am trying to do the LED swap in my 07 SE, and I can't figure out how to take apart the white driver's info screen. In the 07's, there is a driver info screen, and an HVAC control screen. The HVAC screen is encased in black plastic and sits on top of the driver info screen. The driver info screen is slighlty larger than the HVAC screen, and sits just below the HVAC screen, and just above the radio. I got the info screen out of the car, and there are no screws holding it together, just clips. I got the clips popped, but the 2 halves will not seperate. If anybody has taken apart an 07-08 screen, I'd greatly appreciate some help. Here are some pics...
This is the screen I'm asking about:
It seems to be stuck at the seam right near the brass thread, right at the corner where the raised white "T" is here:
There are some stress cracks in the plastic around the brass threaded insert, so I don't want to be putting to much pressure on it.
Old Aug 12, 2009 | 04:00 PM
LucKie1nE's Avatar
I tried doing the same thing in my 08.. I ws think about taking a wizard tool to it and cut it open then just glue it back but change my mind.. But if you do figure it out please pm me.. Good luck
Old Aug 12, 2009 | 04:46 PM
1hawaii50's Avatar
If nobody comes up shooting with a way to get this sucker open, I may just take a wiz wheel to it.
Old Aug 12, 2009 | 06:28 PM
LucKie1nE's Avatar
1hawaii50, if you do, do it.. Let me know how it goes including glueing back together..
Old Aug 12, 2009 | 08:30 PM
1hawaii50's Avatar
Shouldn't need to glue it back together, the only sticking points seem to be on either end, right near the brass threaded insert. If I can just cut the seam there, you should still be able to snap it back together with the tabs. Probably use a little silicon sealer on the cut area just as a precaution. My only concern is cutting through something important, as I have no way of knowing what is behind that area. I'll give it a couple days to see if somebody wants to pony up an answer.
Old Aug 13, 2009 | 05:44 PM
LucKie1nE's Avatar
Keep me informed plz.. Good luck..
Old Aug 14, 2009 | 06:15 AM
papasuede's Avatar
In your first picture of the front it looks to me like there may be a tab on the bottom left side about 2 inches in that would take the black screen cover off. If that can be removed, maybe the electronics inside can slide out the front.
Old Aug 14, 2009 | 03:26 PM
1hawaii50's Avatar
OK, I've been told that it is glued together. It was suggested that I head it with a heat gun/blow dryer, but due to the stress cracks in the plastic, I may just dremel it open.
Old Aug 20, 2009 | 07:29 PM
LucKie1nE's Avatar
Any updates on hitting it with a dremel 1hawaii50..?
Old Aug 21, 2009 | 06:22 AM
1hawaii50's Avatar
I didn't need to. If you slide a razor blade CAREFULLY under a corner of the screen (on the side with the 4 tabs, the side facing up in the first pic), then you can CAREFULLY pull the plastic cover off of the unit. I used a heat gun on the low setting to make it a little easier to get off. There is a double-sided tape holding the plastic screen on. Once the screen is off, you will find 2 small screws holding the white halves together. Once you unscrew them, the case will open easily. I took some photos, just haven't had a chance to upload them yet.
Old Aug 21, 2009 | 07:23 PM
LucKie1nE's Avatar
So you seperated only the screen from the plastic box and removed two screws from inside..? Please post pics bro..
Old Aug 22, 2009 | 02:31 AM
1hawaii50's Avatar
Yes, that's pretty much it. I took a heat gun to the corners of the box...lucky for me I didn't destroy it. I took some pics, and I'll try to get them uploaded tonight for you.
Old Aug 22, 2009 | 08:57 AM
intensitymax's Avatar
Some great info here. This is what this site is supposed to be all about.
Old Aug 23, 2009 | 02:40 AM
1hawaii50's Avatar
OK, here are some pics. On the original pics, where I circled...DO NOT PRY THERE, YOU WILL BREAK THE CASE. You need to lift the plastic screen off of the case, it's held on by some double sided tape...a little hot air will help, but if you use a heat gun, use it on the lowest setting, and DON'T MELT THE SCREEN.
Then you can see the two screws on either side that the plastic screen was covering.
Take the screws out, release the tabs on one side of the case, and you can then open the case.
You then lift the glass panel out of the case, and it will expose the circuit board. The glass panel is attached to the circuit board via a ribbon cable. The ribbon cable is PERMANENTLY attached to the circuit board, so be very careful when handling it. You DO NOT want to damage the cable. Once the glass panel is out of the way, you will have 2 screws holding the circuit board to the case. If anybody has any other questions, let me know.
Old Aug 23, 2009 | 02:42 AM
1hawaii50's Avatar
The two screws at either end are the ones you remove, the two "middle" screws are for the plug, you DO NOT have to take them out, only the two screws at either end.
Old Aug 23, 2009 | 07:20 AM
HMAX08's Avatar
Nice Job Hawaii, i cant wait to see the finished job, what color led's are you going to put in there. you might wanna offer up the service for changing the led's for the other members, I'd be interested for sure.
Old Aug 23, 2009 | 07:26 AM
1hawaii50's Avatar
I've got everything swapped out except for the NIRD-01 display, the steering wheel controls, and the speedo cluster. I've finished the HVAC display, HVAC controls, Radio/Driver info display, all door switches, and the rear sonar/power mirror/traction control/dimmer switches. I'm going to try to work on the speedo cluster today, and I didn't have the right sized LED's for the NIRD display. I just got some new LED's in, so I have to see if they fit the display. I'll post pics this week as soon as I have the whole thing done.
Old Aug 23, 2009 | 08:13 AM
HMAX08's Avatar
sounds nice, i definitely do not have the cahones for something like that. I am not mechanically inclined, hahah. definitely in for final pics
Old Aug 23, 2009 | 12:08 PM
LucKie1nE's Avatar
1hawaii50, Great job bro.. Look's like you accomplished the task.. You just saved a whole lot of trouble for lots of us on the org. Big Up's bro.. This should be a sticky.. Final pics when you get a chance.. Look's like you just gave me another project.. Again, Big Up's..
Old Aug 23, 2009 | 08:12 PM
1hawaii50's Avatar
Stupid NIRD display...LOL...still have the wrong size LED's...guess I'll have to try again! Got the speedo just about done, will finish it up in the morning.
Old Aug 26, 2009 | 07:57 PM
LucKie1nE's Avatar
Post Pics Bro..
Old Aug 27, 2009 | 02:38 AM
1hawaii50's Avatar
I've got everything finished and re-installed. It came out GREAT! Pics are here:
http://forums.maxima.org/6th-generat...ml#post7174807
For now, I left the needles red, I'm kinda liking the contrast.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
The Wizard
24
Oct 1, 2015 08:47 PM
